Old 01-27-2013, 10:45 AM   #14416
2old2Bbold
was 2bold2getold
Oddometer: 1,787
Originally Posted by Hotmamaandme View Post
Well I swapped the 98 forks over to my 97 yesterday. So i had to swap the wheel and brake caliper and cylinder( the caliper and master cylinder/brake lever all still connected as a unit so air in the line should not be an issue). I got it all on and was yelling my head sweet I can go for a ride! then I grabbed the front brake to pump it up after the wheel install and the lever pulled all the way to the bar. Pumped it again it doesn't get better still at the bar. Barley enough friction to stop the wheel. Pull the pads they are shot. So i know I need pads. The brake fluid needs changing so i need to do that too. Worst case if for some reason I need to replace the master cylinder seals ie rebuild it i wanted to know what i was getting into. So first things first new pads ordered then Ill flush the fluid then if that doesn't work ill rebuild the master cylinder.
I had to change the front hose on my "98SE, when I first got it, because it had rubbed on the rotor, with this... http://helusa.com/store/product_info...1476fa95a662eb. The only problem was bleeding the air out. Finally had to take the caliper loose and turn it sideways (bleeder valve facing up and spacer between pads), then it bleed first try.
2old2Bbold is offline   Reply With Quote
Old 01-27-2013, 03:27 PM   #14417
parttime rider
in the woods
parttime rider's Avatar
Oddometer: 41
battery
can anyone recommend a battery for 98 dr350se? looking for most cca with less weight and price. battery i have only has 50cca.
ain't got no gas in it
parttime rider is offline   Reply With Quote
Old 01-27-2013, 03:58 PM   #14418
Chicken Helmet
I'm A Stumper™
Chicken Helmet's Avatar
Oddometer: 5,011
RM250 fork swap done. Gotta get the Vapor wired up and figure out how to get the fork "twist" out of it. Hoping to take it on my camping trip next weekend.
1988 KLR 650 Bare frame,swing arm & title For Sale PM for Details 2009 KLR 650 1994 DR 350
Originally Posted by WaterWheel View Post
From what I've heard, riding a DR feels just like riding a KLR except your head doesn't sway left and right constantly scanning the ditches for aluminum cans.
Chicken Helmet screwed with this post 01-27-2013 at 04:08 PM
Chicken Helmet is online now   Reply With Quote
Old 01-27-2013, 04:09 PM   #14419
RuggedExposure
Now with more rugged
RuggedExposure's Avatar
Oddometer: 1,247
Can you do a write up on this?
The fear and dread of you will fall on all the beasts of the earth
RE Fotowerks
Border Road 100 Border Road Rally Raid
'13 Husky Terra 650, '08 Kawasaki Meanstreak 1600, '95 DR350S
RuggedExposure is offline   Reply With Quote
Old 01-27-2013, 04:39 PM   #14420
Chicken Helmet
I'm A Stumper™
Oddometer: 5,011
Theres already been a few. Mr Pulldown has done this swap and has commented on this thread. Here's a link to what I read:http://www.maximum-suzuki.com/forums...?topic=29511.0
Do a search on that forum, rm fork swap and a few good reads. The gist is swap steering stems, press on new bearings, use rm wheel, axle, and caliper of the forks you use. Get creative with speedo and turn signal mounting. You'll need to bush the upper clamp where the stem goes through, I used a copper coupler cut down from the hardware store.
Old 01-27-2013, 05:08 PM   #14421
tonusmaximus
maximus
tonusmaximus's Avatar
Oddometer: 509
ive been in the mkt for a dr650 or TE610 but now I feel as tho I should spend the coin and treat my girl with the suspension love it deserves and make her the all around girl. Can I get a witness for the DR350! rink
tonusmaximus is offline   Reply With Quote
Old 01-27-2013, 05:12 PM   #14422
Chicken Helmet
I'm A Stumper™
Oddometer: 5,011
The only thing I might replace my DR with is a KDX220.
Old 01-27-2013, 05:34 PM   #14423
2old2Bbold
was 2bold2getold
Oddometer: 1,787
I got this one for my "98SE.... http://www.ebay.com/itm/AGM-YTX7L-BS...item5d392f4880 Don't know the cca but it's been in there about 9 months with no problems, no charging at all (don't know how it would work in really cold conditions) sealed AGM. Works good enough I got more for my other 2 bikes. Not a log term test, but, no problems so far.
Old 01-27-2013, 05:44 PM   #14424
brianjonesphoto
Single Track Noob
brianjonesphoto's Avatar
Oddometer: 1,563
Take a look at sycl lithium batteries. Way lighter and about the same cost. Look in venders the guy is an inmate and offers a discount.
Typos and nonsensical words courtesy of fat fingers on a make believe keyboard.
Brian
Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa
www.PhotoSupportNW.com
brianjonesphoto is offline   Reply With Quote
Old 01-27-2013, 05:49 PM   #14425
ADV BUM
Oddometer: 124
No experience with those, but I have been using Shorai lithium batteries and have been very please. Higher price, but last much longer with a 3yr warranty.
ADV BUM is offline   Reply With Quote
Old 01-27-2013, 07:48 PM   #14426
jmderyke
Miner
jmderyke's Avatar
Oddometer: 43
dr brake lines
Anyone know the difference between the dr350s and the dr350 front brake lines?
jmderyke is offline   Reply With Quote
Old 01-27-2013, 09:39 PM   #14427
RuggedExposure
Oddometer: 1,247
No turn sigs and my speedo came off a mtn bike.
doesn't seem too bad...
I still need to get mine running first.
RE Fotowerks
Old 01-28-2013, 03:54 PM   #14428
O'Hooligan
Ken Dodd's dads dogs dead
O'Hooligan's Avatar
Oddometer: 634
My CDI unit went kaput a couple of months ago and I have a replacement on the way. I want to make sure that I did the bypass of the clutch and side stand wiring correctly before I put on the new cdi.
So is it just a matter of connecting both wires together? The bike was running fine, I'm just a little paranoid at the moment that the bypass caused the problem. So can someone please post the correct procedure?
Gerry
O'Hooligan is offline   Reply With Quote
Old 01-28-2013, 04:12 PM   #14429
RuggedExposure
Oddometer: 1,247
Gerry
What symptoms did your bike have that made you know the cdi went out?
RE Fotowerks
Old 01-28-2013, 04:13 PM   #14430
RuggedExposure
Oddometer: 1,247
Parts just came in from tntmo.
Hopefully tomorrow I can get to the bottom of this and see what went AWOL on my bike.
RE Fotowerks
Times are GMT -7.   It's 06:24 PM.
