Old 01-27-2013, 10:34 PM   #3841
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,394
Dunno. Went with the Wossner because we wanted to get away from KTM's rings and the Wossner was great in that respect. Burned zero oil for 200hrs.
jesusgatos is offline   Reply With Quote
Old 01-31-2013, 02:51 PM   #3842
Navin
Navin's Avatar
Oddometer: 8,227
My 41mm carbed 530 is blowing some blue smoke and burning oil so it's getting a Thumper Racing 570 kit and their reground cam, is there a link to a good set of step by step top end instructions?
Thanks.
Navin is offline   Reply With Quote
Old 01-31-2013, 03:02 PM   #3843
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,587
Thanks.
Ned did one right here in this very thread. I printed it out and used it a couple of weekends ago to replace my head gasket. The only tip I would add is to mark the cam chain with a Sharpie on the link next to the TDC mark on the cam.
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 01-31-2013, 05:28 PM   #3844
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,974
Thanks.
These are links to Ned's pictorial.
Start with posts 637, 662 and 663. Good pics and description.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 01-31-2013, 05:42 PM   #3845
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,865
Yep, I used Ned's procedure. Piece of cake, Nav. I can't imagine an overhead-cam engine being any easier to take apart.
Go ahead and replace the valve stem seals while you're in there. They're not too spendy.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 01-31-2013, 08:02 PM   #3846
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,863
Thanks.
A guy in Chico has a complete 570 kit for sale,cylinder/unused piston ready to go. PM me if interested.
The 570 kit sold locally,sorry.
Some bikes around at times
Foot dragger screwed with this post 02-05-2013 at 06:39 AM
Foot dragger is offline   Reply With Quote
Old 02-01-2013, 06:18 PM   #3847
Navin
Navin's Avatar
Oddometer: 8,227
Thanks guys, those pages will be very useful.
I'd take that offer up on the 570 kit but I've already ordered thru Travis but thank you!
The head is shipping out to DJH for a quick going over and a mod to the rocker shafts/seals/cleaning/inspection.
Old 02-02-2013, 08:54 AM   #3848
windyhill
Oddometer: 64
Glad you caught it before any damage. I've got about 100 hours on a Wossner and had zero oil consumption as well. I've already got another piston and will change out this winter for good measure. Any wear on the pin?
windyhill is offline   Reply With Quote
Old 02-03-2013, 12:25 PM   #3849
biopig
biopig's Avatar
Oddometer: 28
Just wanted to say thanks to Neduro and Hodakaguy for their awesome how-to's. Just finished up head rebuild, oil pump gear upgrade, skf fork seals and bushings. Just in time to take advantage of some nice weather here in ks. Thanks again guys
biopig is offline   Reply With Quote
Old 02-04-2013, 04:37 PM   #3850
jesusgatos
jesusgatos's Avatar
Oddometer: 2,394
Dunno. Was trying to get it put back together in time to take with me to King of the Motos, but that wasn't happening, so left it sitting. Just got back last night and am going to try to get this sorted out this week.
Old 02-04-2013, 08:13 PM   #3851
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,571
Got my Highway Dirt Bikes fairing mounted today and had to go for a test spin despite the cold weather:
The fairing works great. I installed mine in the lowest possible position since this is my trail bike. I'm 5'10" and at 80 mph the wind hits me in the goggles. It's a nice clean airflow with no buffeting. I like how it keeps the air pressure off the chest.
I'm using a wide beam squadron as my low beam mounted in the upper position and pointed slightly down to illuminate the area in front of the bike. In the lower slot I have a spot squadron as a high beam pointed straight ahead. The low beam is run through an LED PWM dimmer with a high beam bypass all controlled from the handlebar Hi/lLo switch. This way on low beam only the top spot LED is on at 40% power and on high beam both LEDs are on at 100% power.
Low beam:
High beam:
Side view:
Old 02-04-2013, 08:15 PM   #3852
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,571
Originally Posted by Foot dragger View Post
Hmmmmm, I wonder if a stock piston would last longer? Bob of Ironmandualsport tried a Thumper 570 kit,put about 25 hours on it and the piston cracked right down the middle in line with the wrist pin,way out in the middle of nowhere in Nevada. It went from running great to dead in about a mile. That was on a 07 525 though.
Its nice you caught this quick like.
Hope this is a fluke. I just installed a Wossner piston since I started burning oil w/ the OEM one.
I've got 200 miles on it so far and all is well. Lets hope it stays that way.
Send Wossner a picture and see what they have to say about it.
Old 02-05-2013, 06:38 AM   #3853
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,587
Look sharp!
From what I could see on the HDB website, the fairing and the bracket, etc. mount to the tripple clamps. Right? How does that feel off road? Does it make the steering heavier?
Semper Fi
Old 02-05-2013, 06:48 AM   #3854
Foot dragger
singletracker
Oddometer: 12,863
Originally Posted by YetiGS View Post
Look sharp!
I was wondering the same thing,Ive also forgotten what needed to be done to run an LED headlight,the stator gets something done to it I know. I try to keep stuff as minimal as possible on the front of the bike.
Ive got a knack for breaking headlights and what ever else I put on there.
Old 02-05-2013, 07:07 AM   #3855
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,571
The whole set up is very light so despite it being mounted to the triple it is barely noticeable.
Under 3 lbs:
Times are GMT -7.   It's 10:20 PM.
