Old 01-09-2013, 11:31 AM   #16
thesurvivalist OP
Backcountry Rider
thesurvivalist's Avatar
Oddometer: 551
Is a 2008 xb12x with 14k miles with no luggage and racks for $6k worth it?
Or a 2006 xb12x with full luggage and corbin seat. 22k mies for $4500 a better deal?
2008 Buell Ulysses Xb12X
2015 Honda PCX
Custom Leather Work-Made In England www.lordofleather.com
thesurvivalist is offline   Reply With Quote
Old 01-09-2013, 05:14 PM   #17
unlucky1
unlucky1's Avatar
Oddometer: 265
I have just about 50k on my '06 and I'd ride it wherever tomorrow (after I change the oil), it's as solid as I could ask it to be.
08+ does have several desirable improvements but I wouldn't pass on a 06 or 07 just because of the year, especially if the price was right.
As far as your experience vs. Erik's sense of humor, just take it easy until you muscle-memory those accidental wheelies out of your routine :)
2008 XB12X
What do you call a group of Buells? A failure.
unlucky1 is offline   Reply With Quote
Old 01-22-2013, 10:47 AM   #18
jk3campbell
jk3campbell's Avatar
Oddometer: 57
I would opt for the '08 if I were being forced to buy another one. I had an '06 for 3 years and had nothing but problems with it. It was a blast to ride when it was working but I needed more reliability. If I recall the '08 also doesn't require a trip to the dealer to reset the TPS every 3000 miles like the 06 did.(or you could buy the software to do it yourself$$)
jk3campbell is offline   Reply With Quote
Old 01-24-2013, 04:40 PM   #19
Nookie
Oddometer: 60
I got the 08 XT. Its a blast to ride. I put the 2010 rear wheel and new bearing on it, comfort kit and heat shield. Now I just ride the shit out of it and wear that stupid grin on my face all day.
Nookster
Nookie is offline   Reply With Quote
Old 01-24-2013, 05:06 PM   #20
thesurvivalist OP
Backcountry Rider
Oddometer: 551
I got the 08. The only issues ive had is a dead battery, it still had the factory original from 08. I love the bike. Super comfortable, plenty of power and lots of cool features. What went wrong on yours?
2015 Honda PCX
Old 01-24-2013, 05:08 PM   #21
thesurvivalist OP
Backcountry Rider
Oddometer: 551
Why did pre 08 bikes require a tps reset?
2015 Honda PCX
Old 01-27-2013, 06:37 AM   #22
Hughlysses
Hughlysses's Avatar
Oddometer: 3,401
The pre-08 bikes had a less-sophisticated ECM. They had a manually adjusted stop screw on the throttle body to set the idle speed. To set the TPS, you have to completely back off of this idle screw so that the butterfly is completely shut and the zero position of the TPS can be established and the TPS can be reset. You don't have to do this very often, but it's something of a PITA as you have to warm the engine completely, back off of the idle screw, connect a laptop with ECMspy or similar software to your bike, reset the TPS, then manually re-adjust the idle speed.
The 08-up bikes use an Idle Air Control (IAC) valve, which is automatically regulated by the ECM to maintain the idle speed. When you release the throttle, the butterfly completely closes; the IAV "bleeds" air past the butterfly to regulate the engine idle speed. This also means that every time you release the throttle, the butterfly is completely shut and the ECM can automatically reset the TPS.
Pretty cool, eh?
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses is online now   Reply With Quote
Old 01-27-2013, 06:08 PM   #23
d2wing
Oddometer: 449
I would go with the 06 with the seat and bags if it has upgrade like driver comfort set up. I had an 06 and after setting it up was a ball to ride. It is very quirky. You will learn more on a Uly than any other bike.
d2wing is offline   Reply With Quote
Old 01-27-2013, 06:30 PM   #24
thesurvivalist OP
Backcountry Rider
Oddometer: 551
Thanks for explaining that, Im happy I went with an 08 as that tps reset seems like a hassle. I went on my first adv ride this Saturday. I definately need some dual sport tires once the current ones wear out. I found it hard to steer out of ruts. My confidence improved as the miles racked up. I was very comfortable and dropped the bike once when I was stationary. I blame ill fitting pants and not the buell.
On some other boards I read about the motor stumbling. What exactly does that mean?
2015 Honda PCX
Old 01-28-2013, 03:03 AM   #25
Hughlysses
Hughlysses's Avatar
Oddometer: 3,401
With the stock tune, it seems most of these bikes have a periodic stumble or hesitation in the 2500-3000 RPM range. You'll be putting along in second gear at steady throttle and ~30 MPH and feel the bike sort of lurch periodically. Apparently this is due to the lean fueling; it's not a big deal.
Old 01-28-2013, 07:48 PM   #26
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,639
Originally Posted by jphish View Post
08' XT does NOT have the 47mm forks or increased sweep to 74*. Only X got that change. And other than height, All else is same on 08' X or XT.
CORRECT this was hashed out in the buell bliss thread.
Remember folks, there was 2 models. xt and x
Jayrod1318 is online now   Reply With Quote
Times are GMT -7.   It's 06:32 PM.
