Old 01-27-2013, 09:11 PM   #76
rectangular OP
Oddometer: 61
Originally Posted by larryboy View Post
Did I miss the oil pump inspection? Hate to see you waste the engine again with a scored pump.
Ahhh... crap.
Is this something I can defer to after my 20-minute break in? I'll be checking the oil screen at that point too.
(I think I already know the answer to this...)
rectangular screwed with this post 01-27-2013 at 09:19 PM
rectangular is offline   Reply With Quote
Old 01-27-2013, 09:53 PM   #77
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 8,014
Originally Posted by DirtyDog View Post
...Continue with the socket theme, but fashion one that "pulls". Use a series of sockets and some threaded rod or a bolt. You can press that seal right out with no issues. Check out the MarkNet KLR site for a pictorial.
Originally Posted by rectangular View Post
I'm not sure I follow. That was the old seal that we had to drive out. It's the way the Clymer manual specifically described removing the old seal. We ended up punching a hole through the old one accidentally trying to remove it. It was easy enough to remove by just using a larger drift which spread the force over a larger area.
I really like the tip for tracing the outline in cardboard and placing the bolts in the cardboard. Seems like it completely prevents any chance for future error!
Look at the link I provided above. Tough to describe without pics. I've removed the seal with both methods. At this point, I prefer a puller over a drift on any such removal... bearings, seals, etc. Slow, even pressure vs. smacking a pointed object against a delicate one. Makes sense to me.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 01-27-2013, 10:51 PM   #78
rectangular OP
Oddometer: 61
I see! Yeah, that does actually seem like a lot better way to remove or install. Keeps it nice and even, much less chance of it getting jammed. I'll have to remember that next time I have to install a bearing or a seal. The water seal in this instance seems like the perfect use for this method.
Old 01-28-2013, 07:26 AM   #79
Kawidad
Kawidad's Avatar
Oddometer: 4,977
Ahhh... crap.
It's a good idea, but..........
If you used silicon or such on the gasket, I'd leave it. The bike only has 12k on the clock and you found the reason for the oil starvation. You didn't note excessive metal, which would have trashed the oil pump. Gummy worms won't. If you just used the OEM gasket, then it wouldn't be a bad idea, but not really necessary. Personally, I'd run it.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 01-28-2013, 08:04 AM   #80
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,038
Ahhh... crap.
I wouldn't risk it, if the top end was starved of oil, so was the pump. The bottom is splash lubed, the pump is a metal on metal type of pump, it has to have oil to lube itself. It's one wasted gasket, take it apart and check it.
larryboy is online now   Reply With Quote
Old 01-28-2013, 08:50 AM   #81
ADW
'tard bike restos
ADW's Avatar
Oddometer: 575
OEM/Kawa
Also, I've noticed these K&N oil filters don't fit worth a damn. Go with the Hi-Flo variety instead.
No, go with an OEM oil filter from Kawasaki. Oil filter aftermarket manufacturers only have to make an oil filter they think you'll buy. Kawasaki's oil filters have to pass a validation test developed by Kawasaki that ensures it will stand up to temperatures, pressures and flow rates that Kawi knows for that engine.
EDIT: no slam meant on DirtyDog, BTW.
08 KLR, 06 KLR w/Sputnik sidecar, 09 WR250R, 72 CB350F
ADW screwed with this post 01-28-2013 at 09:18 AM
ADW is offline   Reply With Quote
Old 01-28-2013, 08:56 AM   #82
rectangular OP
Oddometer: 61
Will do. It shouldn't take very long anyways. I'm getting pretty familiar with both sides under the engine covers.
Old 01-28-2013, 09:12 AM   #83
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,038
If you're careful you might be able to save the gasket. The oil pump surface should have a mirror surface, use a hand impact driver to get the screws out.
Old 01-28-2013, 09:20 AM   #84
ADW
'tard bike restos
ADW's Avatar
Oddometer: 575
A tip I learned a while ago is when you're putting on a new gasket, coat one side of the gasket with a light film of grease. Just a light apply, not much. That will be enough to prevent it from sticking to the metal when you remove the cover again someday but won't hinder it sealing.
I tend to grease the side than goes toward the engine, not the case. This is because it's easier to scrape the gasket off a case that you can take to the bench or whatever than the engine itself.
Old 01-28-2013, 10:06 AM   #85
rectangular OP
Oddometer: 61
I don't have a hand impact driver :(
And it won't cause issues with coolant leaking? Interesting. I might have to give this a shot.
Also, I haven't found a definitive answer if the side cases on the KLR should have silicone gasket maker (rtv bond/hondabond/etc) applied to the paper gaskets or not. Are the paper gaskets just applied as is? Seems strange to me.
Old 01-28-2013, 10:18 AM   #86
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,038
Then use your biggest fattest phillips head and tap on the handle with a hammer while turning. Impact driver is about $10, can be found everywhere.
The only place a KLR engine needs sealant is the center cases, no paper gasket there, you found the result of using too much goo on the center cases. A dab of RTV on a new valve cover gasket will help hold it to the cover when you install it, don't go crazy, apply long before you want to put it back on.
Awesome tip on the grease idea, ADW!!
Old 01-28-2013, 10:58 AM   #87
rectangular OP
Oddometer: 61
Edit: Nevermind, the oil pump is phillips head. I follow now.
Also, I'm probably going to be going in and checking on the oil pump tonight. Anything specific that I should look for once I remove it?
rectangular screwed with this post 01-28-2013 at 11:08 AM
Old 01-28-2013, 11:06 AM   #88
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,038
Make sense. Although, the KLR side covers are held on with 8mm hex bolts though.
Oil pump man, come on, I'm trying to help you here.
Scoring, it should have a mirror finish...no lines of any sort.
Old 01-28-2013, 11:20 AM   #89
rectangular OP
Oddometer: 61
Yeah. I'm a little slow today.
I figured out what was going on once I started looking up pictures of the oil pump.
Old 01-28-2013, 11:43 AM   #90
Kawidad
Kawidad's Avatar
Oddometer: 4,977
Don't forget to prime the oil pump after disassembly.
Times are GMT -7.   It's 10:44 AM.
