01-27-2013, 09:55 PM
#1246 | |
![]() but mid 4 figs for the mats? I would NOT have thought more than a thou for two blocks of alum. BUT, i havne't looked it up either. |
01-28-2013, 12:53 AM
#1247 |
Mike
Oddometer: 63
1986 HPN race replica
is some one having pictures of the dash of 1986 Paris Dakar BMW race bikes, or even better parts for sale?
01-28-2013, 05:39 AM
#1248 |
Oddometer: 314
[QUOTE=Seth S;20587662]The two LED products that I know of right now that are very good are the Squadron supplied by Baja Designs and the Rigid Industries lights. I am sure there are others out there but you can look at those two companies to get a feel for what they offer.
Many thanks for the info JM-2008 |
01-28-2013, 06:26 AM
#1249 |
Says who?
Oddometer: 372
Weight on bars.
I ran this setup a few years ago with everything on a Meca System bracket attached to the triple clamps. The weight was never a problem even on 500km days! Even with the organisers GPS which was at least a couple of kgs it's self. A previous poster mentioned that the weight is quite far back (as opposed to frame mounting) and I think this is maybe why this setup works.
"What could possibly go wrong"
01-28-2013, 06:55 AM
#1250 | |
Reforming Neandertal
Oddometer: 867
Otoh, I started with well over 600lbs of mold grade aluminum, where are you getting yours at those prices, I'd love to pick some up for the next tool. |
01-28-2013, 07:28 AM
#1251 |
Allergic to Asphalt!
Oddometer: 5,997
I've got over 1000 miles on my HDB Ralley lite + my home made fairing while I wait for Paul's prettier design to hit production and have not had any issues w/ the set up.
The whole bracket & light assembly is so compact and lite that I do not notice it at all. ![]()
01-28-2013, 10:25 AM
#1252 | |
Oddometer: 193
![]() Quote:
There is no cheap way to make a mould,only less expensive one's!!!!!!!
www.rally-raidproducts.co.uk |
01-28-2013, 10:28 AM
#1253 | |
Safari Scramble!!!!!
Oddometer: 3,202
If it makes you feel any better we have titanium blisks that get forged to shape and them machined to final dimensions. These get used in our jet engines and each blisk costs about $150,000. Occasionally someone screws one up and it gets scrapped Luckily the factory I work in only deals with blades
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE |
01-28-2013, 11:05 AM
#1254 | |
Oddometer: 440
WOW ! ![]() As Paul and Mitch said, this method is way expensive. Even if you owe the CNC equipment it is still expensive and you have to make enough out of whatever you are developing to justify the cost... Otherwise you are left with a pretty aluminium part and a hole in your pocket... It can happen once, or twice but after that you start having troubles with your wife etc ...
Work like you don't need the money Live like there's no tomorrow ... |
01-28-2013, 11:13 AM
#1255 | |
Oddometer: 867
![]() With 2 Squadrons, F2R, horn and IPhone Ram mt, about 6 1/2lbs, ![]() Take off the horn and IPhone mt just over 5lbs, ![]() Take off the F2R, under 3lbs,
01-28-2013, 11:20 AM
#1256 | |
Oddometer: 440
![]() Take off the lights, under 2 lbs Take off the fairing, under 1.5 lb Take off your pants sorry, got a little bit carried out there The amazing thing is that it looks heavier, may be because of its height, but the scale there proves me wrong ... Well done ! ![]()
01-28-2013, 12:56 PM
#1257 |
Oddometer: 867
The fairing, I think my scale is a little off, light by about 1/8lb,
![]() The side plates and Squadrons, ![]() One Squadron, ![]() A Baja Designs SII, ![]() A Rigid Dually, ![]() Here are the relative sizes. ![]() ![]() That's all I got Dimitri,
01-28-2013, 01:10 PM
#1258 | |
Oddometer: 82
I'm still looking for a way to mount my setup on my 350F, would prefer a frame mounted system but not alter the frame in any way. ![]() Would you be able to post a shot of your mounting solution? thanks
cheers hg |
01-28-2013, 01:49 PM
#1259 |
Oddometer: 5,997
Since I know I'm not the only one that had to look it up:
A blisk (or bladed disk) is a single engine component consisting of a rotor disk and blades, which may be either integrally cast, machined from a solid piece of material, or made by welding individual blades to the rotor disk. The term is used mainly in aerospace engine design. The word is a portmanteau of blade and disk, the two components it replaces in turbomachinery. Blisks may also be known as integrally bladed rotors (IBR).
01-28-2013, 01:50 PM
#1260 |
Oddometer: 5,997
