Old 01-28-2013, 08:09 AM   #16
def
Ginger th wonder dog
def's Avatar
Oddometer: 9,991
Originally Posted by TORQUEMONSTER View Post
How common is it to have oil pump issues?
Very rare...so, don't listen to this old f _ _ t. Also, the OP is filling his engine with the correct amount of oil so, whipping the oil is not the issue.
But, excessive water in engine oil from condensation is a concern. If condensation is the source (and it appears that it is) further investigation is needed or, a change in riding habits.
Now, I'll just go to the garage and repair my 20 year old Maytag Neptune washing machine.
def is online now   Reply With Quote
Old 01-28-2013, 08:20 AM   #17
def
def's Avatar
Oddometer: 9,991
Originally Posted by wario View Post
eggzactly!
But, not to start a "oil" thread - but, a warm engine is a warm engine. I do not believe that the motor knows the difference in temps between when its hot from riding, and hot from idling.
I do believe the key is to get the motor hot - period. If its idling, then it needs to idle until the temp gauge reaches normal operating temperature. Otherwise, you will not bake/cause evaporation of the condensation out of the oil and the muffler/exhaust...
The wet oil needs to exceed 212 F. in order to boil off the condensation. This means a ride of adequate length and the engine oil at 212 F. + for an extended period.
You'll likely get comments regarding idling the engine to operating temperature rather than riding the engine to operating temperature.
Also, I believe the crankcase vent will expel the crankcase gasses and condensation. So, check your crankcase vent for moisture (JVB, I believe the vent terminates in the air box?).
Old 01-28-2013, 12:16 PM   #18
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,014
You should rethink that.
Heat in these motors is directly proportional to fuel burned, and a lot more heat is generated by high rpms than by idling. Especially when the high rpms are associated with trying to drag the bike though the air at high speeds. A period of idling after a high-speed run is likely to cool your motor down.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 01-28-2013, 12:39 PM   #19
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Definately start with color. If it looks like coffee with creamer or lighter it is likely water.
Where do you live? What is the weather like lately? Stored indoors or outside? Been riding in rain? Offroad with stream crossings, even if shallow?
I am with JVB that it is likely not a serious engine problem like a cracked block or bad oil pump unless there has been some sort of trauma to the bike like a crash or some crazy over heating issue.
Condensation happen when temperatures change, think of a glass of ice water with sweat on the outside. The cold glass from the cold drink inside pulls water from the warmer air around the glass and it condenses on the glass. The crankcase in vented so there is air in the crankcase. Get the outside air cool enough and shut off a warm engine and it could pull moisture out of the air in the crankcase and condense it inside the cases. Start the bike and the running motor collects that oil and whips it into the oil, frothing it up like whipping cream.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 01-28-2013, 03:04 PM   #20
Chip Stevens
Oddometer: 117
Just a side note. One of the reasons we don't use auto oil in small airplanes and stick to aviation oils is because of the foam inhibitors used in aviation oil. altitude affects foaming. chip
Chip Stevens is online now   Reply With Quote
Old 01-28-2013, 04:28 PM   #21
Wallowa
Oddometer: 5,365
Question Red Flag?
Anyone have this problem. Warmed the engine up and drained oil. It came out all frothy. Put the new oil in started it up and watched it whip up in the sight window.
R1150GSA 2004
Frothy needs definition and description...what was the color [as mentioned], what % was 'frothy' and then describe "whip up". These descriptors could be signs of differing causes...some serious, some of no concern.
When oil is drained, for grins, mix it vigorously and put as much as you can in glass jar. Let it stand for a few hours and then look for separation in the liquid or solids in the bottom.
Better yet send a sample to Blackstone Lab for analysis.
Oh yes, water does not always 'boil' at 212 degrees; sometimes [altitude] it boils at lower temps. Personally I have never had enough moisture enter an engine from atmospheric sources to create any visual changes in the oil....but then again I live in an arid part of the country. If an engine needs to periodically run to high temps to "burn off water vapor", then the engine is poorly designed...regardless of the style of riding. Just my take and of course I could be wrong.
I am new to boxer motors and do not know if being overfilled will cause frothing due to rods churning up oil. If my engine oil was off color or frothed when I drained it...I would stop right there and send off a sample of oil for analysis.
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline   Reply With Quote
Old 01-28-2013, 04:45 PM   #22
def
def's Avatar
Oddometer: 9,991
You think your boxer uses too much oil and is cranky at cold start?
Watch this...
http://www.youtube.com/watch?NR=1&v=...ture=endscreen
Old 01-28-2013, 09:18 PM   #23
weeman
weeman's Avatar
Oddometer: 58
Watch this...
Beware off topic. I couldn't help but comment on the video. As a kid in the 50's and a Navy brat my family logged many air miles in a Super Connie. My father was a flight engineer on a Martin Mars (Hawaii) seaplane based in Alameda, Ca or Hawaii and when we moved it was either by plane or ship. Fun memories.
weeman is offline   Reply With Quote
Old 01-29-2013, 08:07 PM   #24
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,863
eggzactly!
Leaving your engine to idle for the sole purpose of warming the oil is inane. Just wait to do that maintenance chore until you have an opportunity for a ride. If it's the dead of winter and you won't be riding until spring then you're better off leaving the bike alone anyway.
Best is to get back from a nice long ride, park the bike on the side-stand until the engine has cooled to the point you can hold your hand on the sump, then put it on the centerstand and drain the oil.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast screwed with this post 01-29-2013 at 08:28 PM
slartidbartfast is offline   Reply With Quote
Old 01-30-2013, 01:39 AM   #25
Garba
Oddometer: 5
Then the question is, where is all that water coming from?
Water could get past a badly seated round head gasket.Had it once on my R11..
Garba is offline   Reply With Quote
Old 01-30-2013, 03:43 AM   #26
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,217
Sir,
The air-cooled 1150 will overheat, fry the HES up front, and be dead if left to idle with no airflow over the heads of through the oil cooler.
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 01-30-2013, 11:05 AM   #27
Dan-M
Dan-M's Avatar
Oddometer: 979
Originally Posted by JimVonBaden View Post
Generally multiple short trips where condensation doesn't have a chance to burn off. This is why you should do one trip a week of at least half an hour.
Jim
This is it in a nutshell. Have seen it many times on short trip vehicles.
No laboratories needed.
Dan-M is offline   Reply With Quote
Old 01-30-2013, 04:23 PM   #28
Britome
Get Free
Oddometer: 1,142
Foam=water. Have you done any water crossings?
Britome is offline   Reply With Quote
Old 01-30-2013, 04:57 PM   #29
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,521
Put it in the trash, especially if you have black mold around the seal.
scooteraug02 is offline   Reply With Quote
Old 01-30-2013, 06:07 PM   #30
tvpierce
tvpierce's Avatar
Oddometer: 373
As I understand it, the accepted best practice is to drain oil hot -- while contaminates are suspended in the fluid. That way most of the contaminates are expelled with the oil.
To wait for particulate to settle out of oil you're about to drain seems misguided.
The laws of the road are superseded by the laws of physics.
"But I had the right of way!" makes a pretty crappy epitaph.
tvpierce is offline   Reply With Quote
Times are GMT -7.   It's 01:48 PM.
