Old 01-28-2013, 11:26 AM   #2701
itrack
Oddometer: 115
Originally Posted by toddol1971 View Post
wouldnt it just be easier, or at least about the same amount of money in the end to just put a bigger jug on it, or overbore to get the added power. You know nrfd. You get more gain for the same money.
Sure, but I would like an open source ECU and a big bore.
itrack is offline   Reply With Quote
Old 01-28-2013, 11:40 AM   #2702
NJ-Brett
Brett
Oddometer: 6,844
Even some systems on cars would pulse the injectors with a closed intake valve, the mixture just hangs around before being sucked in.
Some bikes must do that as there are no cam position sensors and there is nothing to tell between TDC on the power stroke or the exhaust stroke.
Any thumper without a cam position sensor would HAVE to do this.
Originally Posted by MentalGuru View Post
The injector only needs to squirt every other revolution. It needs a cam sensor or fancy programing do do this.
This system is very close to a pre 0BD2 system but not as advanced. It is very simular to Dodges system they used on early 4 cylinder MPI cars.
NJ-Brett is online now   Reply With Quote
Old 01-28-2013, 11:42 AM   #2703
Ed@Ford
Oddometer: 1,682
[QUOTE=hrcs90;20593436]Honda's PGM-FI doesn't use OBD codes like the car world like you would expect, but a more Honda style. You can pull codes if needed through the RED DLC plug on the bike, by jumping the Brown and Green wires together or purchase Honda special tool "SCS connector". Make the connection and then turn the main switch on and count the MIL blinks.
So, are you pretty convinced Honda does not use the standard OBDII 4 digit codes on production bikes? If so, that means we not only need a way to read the MIL (Malfunction Indicator Light ) blinks....but also a "dictionary" of the code # and their meaning...........
Ed@Ford is online now   Reply With Quote
Old 01-28-2013, 11:55 AM   #2704
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 729
The computer can be programed to sense when the combustion stroke happens by monitering the increase in crankshaft speed. With the proper software it is possible to fire the injector at the corect time with only a crank sensor. Some cars do this when the cam sensor fails so they cam still run in limp in mode...
Win a Free Helmet. xladv.com/topic/258-msr-x-pedition-helmet-give-away-round-1/
MentalGuru is offline   Reply With Quote
Old 01-28-2013, 12:32 PM   #2705
Krono
Speed Junkie
Oddometer: 193
Originally Posted by Ed@Ford View Post
Heres the deal on two O2 sensors on a CRF. Go to the www dot rickramsey dot net web page and look in the introduction of the CRF250L file. One O2 sensor is in the exhaust port on the cylinder head. It looks at O2 level in the exhaust gas. The other sits on the rocker cover box and it looks at O2 in the fresh air that is pumped into the exhaust flow. I do not know if either sensor is heated, or if either is a "wide ratio" sensor. Some of this can be "guessed" if the wiring harness pinout for these sensors are are known. However, since the air induction sensor is looking at fresh air, I'd guess that is a wide ratio sensor. Based on past experience, this seems like an expensive solution to control the metering of air pumped into the exhaust to control hydrocarbon emissions. I am unaware of this method being used on modern engine emission management systems.....but maybe someone out there is more up-to-date on such methods.
There's only one O2 sensor, and thus at the exhaust port.
The title is a little confusing where it's placed, though ...
L
SM510R
Krono is offline   Reply With Quote
Old 01-28-2013, 12:34 PM   #2706
Jinksy
- Jinksy
Jinksy's Avatar
Oddometer: 55
Gear radio
If I change the gear ratio from 14/40 to 13/43 will this give me better performance off the line?
Honda CRF 250l
Honda Shadow Spirit 750
Honda XR 80
Jinksy is offline   Reply With Quote
Old 01-28-2013, 12:45 PM   #2707
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 729
Yes...
Old 01-28-2013, 12:49 PM   #2708
Krono
Speed Junkie
Oddometer: 193
About air induction, after having corcked it and disconnected the O2 sensor, following BDSB suggestions here http://bestdualsportbikes.com/dual-s...honda-crf250l/ and installed a dBkiller of my own, i had many stalling problems. That was cured by re-plugging the secondary air system and setting the first EJK parameter to 0, what got me rid of backfires too. Replugged also the O2 sensor, as i was there.
Doesn't seems logical, since i probably leaned at idle, but that's what experimentation concluded in my case.
Whatever .. i will try to experiment more with teh EJK setting (which you can emulate here http://www.electronicjetkit.com/demos/HPcurve.swf press mode, then + or -)
L
SM510R
Old 01-28-2013, 12:56 PM   #2709
Krono
Speed Junkie
Oddometer: 193
Soooo you're telling me "AI O2 sensor" really means " Air Induction Actuator Valve"? I guess I gotta go look and see if there is a wire going to it.................
They just illustrate both AI and O2 sensor in this picture ...
What is shown with the little arrows
L
SM510R
Old 01-28-2013, 12:57 PM   #2710
StudMeyer
Oddometer: 1
Derp.
New member, as I was recently granted permission to join from a fellow owner Finally purchased a CRF after about 7,000 kms riding on rented machines in Thailand. Mine has 330 kms on it now. Going to get a new exhaust on tomorrow and new aluminum bar. Got other goodies coming over the next month or two.
Look forward to reading about all the mods coming out for the bike.
Here's a video I made in Thailand - footage from 2012. Stock CRF riding down doi suthep with a modified KLX
enjoy
StudMeyer is offline   Reply With Quote
Old 01-28-2013, 01:16 PM   #2711
Krono
Speed Junkie
Oddometer: 193
Originally Posted by StudMeyer View Post
Derp.
enjoy
Welcome and congrats for the video. I can feel the pleasure of driving
SM510R
Old 01-28-2013, 01:40 PM   #2712
gnath9
gnath9's Avatar
Oddometer: 281
13/42 and you won't have to mess with your chain.
gnath9 is offline   Reply With Quote
Old 01-28-2013, 02:07 PM   #2713
Jinksy
- Jinksy
Jinksy's Avatar
Oddometer: 55
This will help make it a quicker bike? Is this a hard process to do?
Honda CRF 250l
Honda XR 80
Old 01-28-2013, 02:08 PM   #2714
Jinksy
- Jinksy
Jinksy's Avatar
Oddometer: 55
Yes...
Thanks man, is this easy to do?
Honda CRF 250l
Honda XR 80
Old 01-28-2013, 02:17 PM   #2715
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 729
An impart driver helps to get the rear sprocket bolts out. The kind you hit with a hammer.
Otherwise it's pretty easy.
Times are GMT -7.   It's 06:04 PM.
