Old 01-27-2013, 08:01 PM   #73216
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,540
Originally Posted by Kommando View Post
A binding clutch cable could have been a culprit too.
Or even a lack of play in the cable.
Old 01-28-2013, 12:54 AM   #73217
LexTalionis
Inciteful
LexTalionis's Avatar
Oddometer: 441
Originally Posted by neo1piv014 View Post
Are you using the stock tank? My IMS goes down pretty far. I can barely see my Carb without taking the other stuff off.
Sent from my LG-P999 using Tapatalk 2
OE tank. If you stated your tank is an IMS in your previous post, I missed it.
Lex
The older I get, the better I was.
LexTalionis is offline   Reply With Quote
Old 01-28-2013, 06:16 AM   #73218
SCExpat
SCExpat's Avatar
Oddometer: 635
Originally Posted by Adv Grifter View Post
I agree. Not many DR's lose the clutch. Very few I've heard about ... but synthetic oil with friction modifiers will do it. If the rest of the bike looks OK ... could be a good deal. Clutch is easy and relatively cheap to replace.
Originally Posted by 1989THEARK View Post
I ran royal purple
and valvoline in 2 seperate bikes
by accident.
moral of the story dont ever "ever" Ever! !!!EVER!!
run energy conserving oils i your bike.
liquid evil i tell yuh.
But great in cars
Thanks for all the reply's. Good info. I'll check the steering head bearings, clutch cable and never use energy conserving oil in a bike. There is a lot of people who use ATF in their trials bikes. Just change it frequently as it is cheap. The clutch on my (and most) trials bike is like a light switch - on or off. I bought the ATF and was ready to dump all 500cc's in and I couldn't do it. It's only 500cc and I just wanted to use oil made specifically for a 2 stroke wet clutch gear box. Cost a lot more but I sleep better.
SCExpat is offline   Reply With Quote
Old 01-28-2013, 06:19 AM   #73219
SCExpat
SCExpat's Avatar
Oddometer: 635
Originally Posted by Emmbeedee View Post
Somebody may have put "Energy Conserving" oil in it and caused the clutch to slip, requiring a change of plates. It might not have been "worn out" but still needing replacement for that reason.
Originally Posted by Carl Childers View Post
Clutch wear comes down to riding style, some use it as a torque converter and the life is much shorter than someone who uses it in a more conservative manner. Keep in mind the current owner may love to power wheelie and that eats up the clutch faster and is also tough on the head stock bearings so when you look at the bike grab a handful of brake and try to rock the bike back and forth listening and feeling for movement in that area.
Thanks for the reply. They were cut out of the multi due to the small novel about the evils of energy saving oil in bikes. JK. Thanks for all the ideas. Going to have a look today.
Old 01-28-2013, 07:32 AM   #73220
Sic Semper Tyrannis
Oddometer: 584
DR650 on Bike Exif...
more here:
http://www.bikeexif.com/suzuki-dr650
Sic Semper Tyrannis is offline   Reply With Quote
Old 01-28-2013, 08:38 AM   #73221
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,002
Originally Posted by motolab View Post
The only time this makes no difference is with 50% opening, where it obviously doesn't matter whether you say "1/2 throttle" or "1/2 opening".
Regards,
Derek
or at -40 degrees Celsius or Fahrenheit.
When people say 1/4 throttle, 99 & 44/100ths percent, mean 1/4 open regardless of what the dictionary says.
Why do you have to be such a stickler? When I say stickler, I mean Tool. look that up. When people say choke, they mean the thing the operate when the engine is cold.
I see the same thing on gun forums where new people refer to magazines as clips. (google it to see the difference) There is always some knowledgeable "stickler" that feels the need to lecture the new guy about the difference.
Derek, you are a very knowledgeable stickler. I almost never do this, but I'm gonna hit my ignore button for a while, buh-bye.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 01-28-2013, 08:40 AM   #73222
Rusty Rocket
Life behind "Bars"
Oddometer: 9,002
Originally Posted by Sic Semper Tyrannis View Post
JFW! That's a new one for just f'ing WOW! I love that.
2009 DR650
Old 01-28-2013, 09:07 AM   #73223
procycle
procycle's Avatar
Oddometer: 2,252
Originally Posted by rusty rocket View Post
when people say 1/4 throttle, 99 & 44/100ths percent, mean 1/4 open regardless of what the dictionary says.
+1
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 01-28-2013, 10:42 AM   #73224
motolab
motolab's Avatar
Oddometer: 2,529
In this case, as in all cases, I am attempting to raise the bar. I can see no downside to improving the precision with which we communicate. I see it as indicative of the general sad state of affairs that someone would disparage another (even to the extent of name-calling) for such a thing.
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-28-2013, 11:42 AM   #73225
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 872
Originally Posted by TIGERRIDER007 View Post
Thanks to all the info on tires, I've decided to get the Metzeler Unicross and keep the Bridgestone as a backup plan.
I appreciate the help and will be posting soon...I hope!
One more question, then I'll shush about tires....can the DR650 run a 80/100/21 up front?
Seems like more choice for that size...okay, I'm done!
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is offline   Reply With Quote
Old 01-28-2013, 11:59 AM   #73226
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,139
If it still had knobblies, then it'd be a WOW!
NordieBoy is online now   Reply With Quote
Old 01-28-2013, 01:45 PM   #73227
ram1000
ram1000's Avatar
Oddometer: 1,833
After many weeks of waiting and working on the DR I finished my project, except for new tires next month. Just turned the key off after starting to make sure it still runs. The project was:
1. strip the bike down to its frame and powder coat the frame black
2. clean up all the rims and hubs exhaust and any other component that needed a thorough going through
3. disassemble the previously installed RMZ450 front forks to change the oil to a lighter weight and at the same time shorten the overall travel from 12.2" to 11.5"--- this allowed me to drop the forks into the triple clamps farther than before and tighten up the steering for serious off road handling, while turning the rear preload down a little for a more trail oriented ride
4. also installed a new set of fat bars that I think I will like even better than the previous bars
5. I previously had purchased a new ULY front headlight assembly but opted to put the stock lights back on and sell the ULY headlight since I also recently bought a 2009 KLR for my road riding adventures
6. rewired the BMW plug and cig lighter plug a little nicer
A good adventure bike will get you to where you wish you had a good dirt bike! (and back)
:2014 XC800 :2012 WR450
ram1000 is offline   Reply With Quote
Old 01-28-2013, 01:54 PM   #73228
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,364
Looks good. Are the red parts powder coated also?
Old 01-28-2013, 03:42 PM   #73229
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 163
Look what Santa brought.......!
As my lovely wife likes to say to our boys,..."Its Christmas everyday for your Dad"
VooDooDaddy is offline   Reply With Quote
Old 01-28-2013, 03:45 PM   #73230
Rusty Rocket
Life behind "Bars"
Oddometer: 9,002
Looks like a Cogent. Cool Santa you have.
2009 DR650
Times are GMT -7.   It's 01:05 AM.
