Old 01-28-2013, 11:56 AM   #4456
khale
ride dirty
khale's Avatar
Oddometer: 557
Originally Posted by RichBMW View Post
That has to be the worst English I've ever read. I gave up after the second paragraph
Same. It's gobbledygook
2013 BMW R1200 GSW | 1972 BMW R75/5 toaster | 2011 Husky TE310
"4 wheels move the body, 2 wheels move the soul"
khale is offline   Reply With Quote
Old 01-28-2013, 11:59 AM   #4457
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,228
Originally Posted by Gros Buck View Post
But if you have ABS on your car, chances are that it does not work anymore at 100K miles ... .
Paul Jr
Sir,
Where were your cars designed and built?
Not by BMW in Europe, I guess. I have more miles than that on my bike, with no problems what so ever.
The bike, by the way, was designed and built by BMW in Europe..
ABS not lasting more than 100K miles - ignorant or stupid.
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 01-28-2013, 01:04 PM   #4458
Emperor Norton
Kilroy was here
Emperor Norton's Avatar
Oddometer: 1,214
... But if you have ABS on your car, chances are that it does not work anymore at 100K miles ...
Odd, my 2000 328i had over 120,000 miles on the odometer when I sold it. ABS system never had an issue. The only real problem was the @#$@#$ window lifts which thankfully I don't have to worry about on a motorcycle, unless they use one for the RTs screen.
Pics of whatever/where ever http://joee.smugmug.com
I used to be indecisive, now I'm not so sure.
Emperor Norton is offline   Reply With Quote
Old 01-28-2013, 02:11 PM   #4459
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,548
Originally Posted by TuonoBiker View Post
While I wasn't around in the 60's I can't imagine the bikes of the 60's and 70's being reliable enough to trek thousands of miles at a time.
Funny you should mention that. That's where the myth of BMW reliability started. A /2 built in the 60s could easily do 50 - 100K miles. That wasn't true of most of the british and japanese bikes of the time where they were often ready for the junk pile at 20K miles.
Today there is no real difference between BMW and any other bike built. All have strengths and weaknesses. All will take you more miles than most will put on the bike before they replace it for something new. Most replacements will be because of "I want" not "I need".
If I like the new bike after a test ride I'll probably order one. Not because I need it. My '05 only has 75K miles on the odo; it is still running strong.
marchyman is offline   Reply With Quote
Old 01-28-2013, 02:26 PM   #4460
cug
Oddometer: 4,945
But if you have ABS on your car, chances are that it does not work anymore at 100K miles ... Sensor this, sensor that, bla bla bla.
Unless you can back that with real numbers from actual facts and not your gut feeling about electronics I call BS. I have owned several cars with more than 100k miles and never ever had trouble with ABS. One of the most reliable systems I have had in car. Hell, windshield wiper motors were failing more often ...
Besides fuel injection, I do not see any real benefit that electronics have brought to a 1200GS in the last decade. It brought just problems.
Again, I think that's not true. Can you point out actual electronic problems you're referring to?
I know about a lot of small and large issues here and there with BMWs and other manufacturers and pretty much all of them are actually mechanical (or chemical (comical?) in the case of the fuel strip).
So, what problems have you seen with the electronic parts of more sophisticated systems?
cug is offline   Reply With Quote
Old 01-28-2013, 02:32 PM   #4461
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
He misses his kick starter
EJ_92606 is offline   Reply With Quote
Old 01-28-2013, 02:44 PM   #4462
TuonoBiker
Oddometer: 808
Excellent point - and I should realize that after looking over a beautiful 1961 BMW at my dealer a couple weeks ago...they did a full restore job on it and it runs like new. Even cooler is the fact the parts are still available.
I agree with the lack of differences between BMW and everyone else in this regard. The design and electronic engineering that goes into an ECU on a BMW is probably no different than my old Aprilia...might even be from the same manufacturer like Siemens or Bosch or Magnetti Marelli. The differences begin at the application level...hardware level? Very similar.
Does make you wonder if BMW has higher standards when it comes to noise, vib, harshness...especially for the enduro class machines.
'12 R1200GS Adventure
'06 Ducati 999S
'11 Harley Street Glide - gone and mostly forgotten
'07 Tuono Factory - gone but not forgotten
TuonoBiker is offline   Reply With Quote
Old 01-28-2013, 03:59 PM   #4463
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 984
Originally Posted by Thinc2 View Post
Motorrad reports that their long term test Ducati has 50K KM's on the clutch with no issues. Ducati has been sourcing this clutch for the last three years from Japanese OEM FCC - this is the exact clutch that is in the new GS.
From here for more of the article in German.
Thank you.
I knew an inmate would turn my hearsay into fact.
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania is offline   Reply With Quote
Old 01-28-2013, 04:09 PM   #4464
I GS 1
I 90S I
I GS 1's Avatar
Oddometer: 645
Originally Posted by khale View Post
First lay down, perhaps? Ouch! Hope the bike was ok!
This concept of water rather than air/oil cooling a GS seems to be really taking off
I GS 1 is offline   Reply With Quote
Old 01-28-2013, 04:22 PM   #4465
vtbob
wanderer
Oddometer: 596
Originally Posted by Voluhzia View Post
Why would one need ABS on their car, it already has 4 wheels
Facebook
Nova Scotia on Explorer
If you drive a car aggressively, or in challenging condition you would quickly see why ABS is a real benefit for cars and pickups. to my knowledge...I believe all new cars and pickup come with some type of abs. some are simple abs and others are quite sophisticated stability control.
the abs on my bike kept me from locking my front wheel on a tar snake...which without it would have put me down in a 6 lane intersection. I will never buy a new bike without ABS
vtbob is online now   Reply With Quote
Old 01-28-2013, 04:32 PM   #4466
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,611
Looks like almost like a trans-Atlantic water crossing....nice!
2015 BMW r nine T | 2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well
oalvarez is offline   Reply With Quote
Old 01-28-2013, 04:34 PM   #4467
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,503
Jim
Old 01-28-2013, 04:44 PM   #4468
Voluhzia
iExplorer
Voluhzia's Avatar
Oddometer: 1,608
Bystander: "idiot"
Facebook
2012 Triumph Tiger Explorer
http://novascotiaexplorer.blogspot.com/
Voluhzia screwed with this post 01-28-2013 at 04:50 PM
Voluhzia is offline   Reply With Quote
Old 01-28-2013, 04:56 PM   #4469
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 848
Originally Posted by vtbob View Post
If you drive a car aggressively, or in challenging condition you would quickly see why ABS is a real benefit for cars and pickups. to my knowledge ... I believe all new cars and pickup come with some type of abs. some are simple abs and others are quite sophisticated stability control. The abs on my bike kept me from locking my front wheel on a tar snake...which without it would have put me down in a 6 lane intersection. I will never buy a new bike without ABS.
Maybe ...
But try to use the same abs in Winter ... It will stabilise those who do not know how to. And you will brake in a much longer distance ... For some people, it may be ok, but personnaly, I pulled the ABS fuse years ago.
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 01-28-2013, 05:18 PM   #4470
I GS 1
I 90S I
I GS 1's Avatar
Oddometer: 645
Facebook
If they have double the amount of wheels that could lock up, wouldn't hey need ABS twice as much?
Times are GMT -7.   It's 02:58 AM.
