Old 01-27-2013, 11:45 AM   #1
Britome OP
Get Free
Oddometer: 1,154
Story of Rebuilding a Totaled 2006 GSA
I'm going to catalog all that is being done on my son's GSA. It was a low side on ice that resulted in no human Damage but enough bike damage to warrant the insurance totaling the bike.
I took the price of the bike including 5k of farkles minus the buy back of the salvaged bike for $2,600. I also had to get a salvage title.
First step was to peel away all that was broken. Then to make my parts list. I got some used stuff off eBay and ordered the rest of the parts. There are sure to be more part orders to follow.
New beak ordered from Beemer boneyard after the front frame assembly was bent back into acceptable shape with a crow bar.
valve cover cracked. These two holes had to filled with a helo coil and surrounded with epoxy.
Now waiting for the first round of parts to be delivered. If you have tips, I'm all ears. Meanwhile I'm hoping to help someone in the future who may encounter a similar challenge. Thus far the financial models are heavily in my favor.
We bought the bike from a good friend so we know all the history. Currently has 61k on the odometer.
Britome screwed with this post 02-28-2013 at 08:00 AM Reason: Better Title
Britome is offline   Reply With Quote
Old 01-27-2013, 03:31 PM   #2
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 389
Great fun
I purchased a crashed r1200gs a couple of years ago. great fun.
I replaced the following:
Main new components I got were:
New forks. Both. - Decided not to muck about with forks. One was stuffed but other was only slightly bent.
They are light tube and I decided it could not be reliably repaired.
New bearings in front end. (Wheel bearings, steering etc.)
Found a wrecked bike in Australia. (I'm in NZ)
From wreckers I got the following:
Front frame. (Cut the frame number off the old one and glued it to new one)
Sub frame for speedo etc
Telelever from beemer boneyard. (3 day delivery from US to NZ)
=> This was from an r1200RT and was actually different to the GS. On the RT the hole for the ball joint is set slightly back. I worked out that it steepened the steering about 1 degree. You change the geometry more jacking up the shock a few turns at the back. It rode great.
I fixed/repaired a lot of components as I was happy with the quality.
Rocker covers both worn through. I got them welded up and painted. They have lost their writing but look fine.
My best tips:
1- BMW repair manual.
2- gs-911. This tool enabled me to reset the errors resulting from the crash. (ABS etc)
I included gs-911 in my budget and have kept it. Went to x-challenge after my 1200 and now have an F800gs.
It was great fun.
Kiwi Tinkerer is offline   Reply With Quote
Old 01-28-2013, 09:29 AM   #3
Dark Helmet
Dark Helmet's Avatar
Oddometer: 701
Glad everyone is ok Brian, your title worried me that you had been in an accident. Glad your son is ok.
DH
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD -40. If it shouldn't move and does, use the duct tape
BMW 1200 GS Adventure
BMW 1970 R75/5
Suzuki DRZ 400S
Dark Helmet is offline   Reply With Quote
Old 01-28-2013, 01:28 PM   #4
Britome OP
Get Free
Oddometer: 1,154
DH
I appreciate your concern. All is good. On another note, I'm still looking forward to hooking up and having that conversation you wanted to have.
Old 01-28-2013, 08:45 PM   #5
rgb2cmyk
rgb2cmyk's Avatar
Oddometer: 255
You were able to buy yours back for $2600!? My 09 GSA was totaled in Sandy, the engine and electronics were corroded and shot (salt water), yet the insurance by back was $9000....!
_
14 R1200 GSA (Hopefully lasts longer than 2yrs)
12 R1200 GSA ("Sandy") (Hit by DUI)
09 R1200 GSA (Totaled by SS Sandy)
06 Husky TE450, 04 R1100s BCR, 03 F650CS
rgb2cmyk is offline   Reply With Quote
Old 01-29-2013, 03:56 AM   #6
Britome OP
Get Free
Oddometer: 1,154
Actually, their first offer was 2650. I negotiated down to 2,200. I don't mean to gloat or rub it in. Rather, your post is confirmation that they were treating me ok. They said their buy back option was unusually low. Now I believe them.
Meanwhile... Still waiting for parts.
Britome screwed with this post 02-16-2013 at 05:49 AM
Old 01-29-2013, 08:39 AM   #7
Britome OP
Get Free
Oddometer: 1,154
Insurance Adjustment
Dairyland took good care of me but I had to change carriers. They would not insure a salvaged Title. Even with accident on record, Geico was good to go.
Old 02-08-2013, 03:07 AM   #8
Britome OP
Get Free
Oddometer: 1,154
When the bike crashed, all spokes were broken.
When I got it off the truck at home I thought the front axel was being hung up in the spokes Si I drove it out with a punch. Actually what happened was there were still 3 threads to go before the axel was released.
Therefore, my threads in the lower fork were jacked and the threads on the axel were jacked as well as the end being gnarled by the punch.
My dremel regrouped and shaped the axel. This mongo tap took care of the fork. All is good and waiting for the rebuilt wheel from woody's
Britome screwed with this post 02-16-2013 at 05:51 AM
Old 02-08-2013, 03:08 AM   #9
Britome OP
Get Free
Oddometer: 1,154
Front end back in order...
Old 02-08-2013, 03:09 AM   #10
Britome OP
Get Free
Oddometer: 1,154
The old cover...
Old 02-08-2013, 06:34 AM   #11
eric2
®egister this:
eric2's Avatar
Oddometer: 3,797
The financial models may seem to be in your favor now, but that may turn if the engine suffered main or rod bearing damage
from oil starvation while running on its side. Does your son know if It kept running after he went down?
Looking at the valve cover damage, its hard to tell, but maybe ice hung up the rocker arms, or was in gear high enough to stall the motor and prevent further damage. Luckily, used motors are more common than used FD's and pretty cheap.
Eric
'06 R12GS, '13 s1000RR
Originally Posted by Big Steve View Post
I've yet to see a poor person driving a real gas hog......
lottery: A tax for people bad at math
eric2 is offline   Reply With Quote
Old 02-08-2013, 07:13 AM   #12
Britome OP
Get Free
Oddometer: 1,154
Engine was shut off immediately. When I adjusted the valves, compression was solid. As soon as I get my new coil, ill fire it up and let you know.
Old 02-11-2013, 05:57 PM   #13
Britome OP
Get Free
Oddometer: 1,154
I found switches from an 05 gs and they were different looking than the 06 GSA. Different color orange signals and a hazard button but works perfectly.
Old 02-11-2013, 05:58 PM   #14
Britome OP
Get Free
Oddometer: 1,154
Upper tank bars bent and banged into acceptable shape. Saved me hundreds.
Old 02-11-2013, 06:00 PM   #15
Britome OP
Get Free
Oddometer: 1,154
Put a new coil in and added 2 quarts of cheap oil to be replaced after first road test. Fired right up!
Just waiting on front wheel rebuild from woodys and ill give it a road test.
Times are GMT -7.   It's 05:46 AM.
