Old 01-28-2013, 12:46 PM   #91
rectangular OP
Oddometer: 60
Originally Posted by Kawidad View Post
Don't forget to prime the oil pump after disassembly.
On it! I should underline that step in the Clymer manual.
I should have posted build threads like this ages ago. It's good to find out all the stuff I'm doing wrong. I don't have any actual mechanical training. All of my "experience" is a combination of always taking stuff apart my whole life, and tips from friends or threads on the internet. It's nice picking up better methods and craft from other users that have much more experience.
rectangular is offline   Reply With Quote
Old 01-28-2013, 01:35 PM   #92
Dan in Grand Rapids
Dan in Grand Rapids's Avatar
Oddometer: 54
Why did you have to have the cylinder honed at a machine shop? I thought the jugs from Eagle Mike were ready to bolt on without having to go to a machine shop.
Dan in Grand Rapids is offline   Reply With Quote
Old 01-28-2013, 02:31 PM   #93
Beezer
Oddometer: 5,796
if you reuse the copper gaskets on the oil fitting banjo bolts you should anneal them. they work harden when torqued up. get them on a coat hanger or something.... heat them to red & dunk them in water. they will be soft as butter. if there are ridges in the washer I file or sand them out before treating
I usually stick the gasket to the cover with RTV & grease the side that goes to the case. it can be removed many times with no damage
the 2 cutouts on the valve cover gasket need something to help them stick. the book shows putting a bead of goop along that whole side, I don't do that. I put a big fat dot of RTV on the outside of the head & over the rubber of the cutout. this is easier to clean up when checking the valves & nothing falls into the engine. YMMV
only thing I would have added to the doo change is to put a couple punch marks on the woodruff key... that keeps it from getting pushed out of the crank when the rotor is installed. this has happened... later in life the rotor slips & the ignition timing goes off
Beezer is offline   Reply With Quote
Old 01-28-2013, 02:59 PM   #94
rectangular OP
Oddometer: 60
I didn't get a jug from Eagle Mike. There's a pretty awesome local motorcycle machine shop. I had them do all the machine work on the cylinder jug that came with my bike.
Old 01-28-2013, 03:03 PM   #95
rectangular OP
Oddometer: 60
I have some new copper gaskets for the banjo bolts.
Sounds like using grease is the way to go so that gaskets can be reused. I like it!
I'm a little paranoid about modifying the woodruff key in case I mess something up. Probably a better chance of me botching that than the woodruff key getting pushed up.
Old 01-28-2013, 03:16 PM   #96
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
Must have missed this, what's up with your woodruff key?
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 01-28-2013, 03:18 PM   #97
rectangular OP
Oddometer: 60
Nothing is wrong. Beezer mentioned above to put some punch marks in it. But, I think I'm going to pass on that. Pretty sure I would mess that up.
Old 01-28-2013, 05:51 PM   #98
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,952
Originally Posted by ADW View Post
No, go with an OEM oil filter from Kawasaki. Oil filter aftermarket manufacturers only have to make an oil filter they think you'll buy. Kawasaki's oil filters have to pass a validation test developed by Kawasaki that ensures it will stand up to temperatures, pressures and flow rates that Kawi knows for that engine.
EDIT: no slam meant on DirtyDog, BTW.
We aren't gonna turn this into an oil or filter debate, but your paranoia regarding oil filters is odd to me. I suggested Hi-Flo due to the price point (half or less of OEM).
Let's not kid ourselves about the tolerance levels and high performance specs of this motor from 1980's vintage technology. A KLR would probably run for years with a wadded up shop rag jammed in there instead of an oil filter.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 01-28-2013, 06:18 PM   #99
newcastleadam
Artful Tagger
Oddometer: 3,455
Brilliant
Adam
Old 01-28-2013, 07:48 PM   #100
DanishDR
Oddometer: 6
First, I agree that the tiny difference will probably make no difference in filtration on this motor. That being said, I was surprised when we pulled the K&N to see such a premium filter with such blatant seal issues. Perhaps it wasn't the right filter or the seals had some issues.
DanishDR is offline   Reply With Quote
Old 01-28-2013, 10:13 PM   #101
rectangular OP
Oddometer: 60
Oil pump pictures!
I had some spare time tonight to get in and look at the oil pump. It seems to me that it has some signs of wear, but I don't think it's to the point of affecting it's function. The surface feels considerably smooth. I think the photos make it look more scratched that it actually is. It feels completely smooth to the touch. Rotating the gear also seems to be extremely smooth. It doesn't feel like it catches or hangs unequally at any point.
I think it's fine to use, but I'd love some second opinions. Is this considered scoring? Or would this be borderline? This seems to be in just as good, if not better condition than all the oil pump images on ebay.
The Clymer manual states: "Visually inspect all parts for obvious wear or damage. Component specifications are not available for the oil pump."
(Inadvertent middle finger!)
Unfortunately, I wasn't able to completely get the gasket off in perfect condition. So, I'll have to wait until I pick this gasket up before I can re-re-assemble the right side cover. Fortunately, I think it will go pretty quickly. I'm getting a lot more familiar with this engine.
Old 01-28-2013, 10:53 PM   #102
Beezer
Oddometer: 5,796
looks like new... run it
as for the punch marks... just a couple small dimples so the key fits the slot tighter. this can really reduce the frustration level when reinstalling the rotor, the key is very easy to knock out of place
Old 01-29-2013, 02:40 AM   #103
ADW
'tard bike restos
ADW's Avatar
Oddometer: 557
My day job is with a large auto manufacturer, and I am in the engineering team that sees the results of aftermarket oil filters that can't handle the job. So it's not paranoia, it's actual personal experience in an engineering environment. The KLR may well be an older design, but my statement still stands. I want a filter the manufacturer has signed off on being able to complete the tasks they expect it to. And agreed let's not hijack this thread, the OP's doing a great job of documenting a rebuild.
08 KLR, 06 KLR w/Sputnik sidecar, 09 WR250R, 72 CB350F
ADW is offline   Reply With Quote
Old 01-29-2013, 07:10 AM   #104
Kawidad
Kawidad's Avatar
Oddometer: 4,843
Agreed
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is online now   Reply With Quote
Old 01-29-2013, 08:57 AM   #105
rectangular OP
Oddometer: 60
Glad that everyone agrees the oil pump is good-to-go! Now I'm basically just waiting on gaskets and my refreshed head from Eagle Mike.
I picked up some 10w40 non-synthetic castrol motorcycle oil for engine break in.
Also... it has been snowing a lot in Salt Lake City. I won't be able to start it up until the roads clear a little bit so that I can properly complete break in. But, I'm probably getting a little bit ahead of myself.
Times are GMT -7.   It's 05:22 PM.
