Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 01-28-2013, 02:56 PM   #1006
Buck760
Buck760's Avatar
Oddometer: 191
Back to the Mach 3
Tried the DE for about a month now - birth year Gillette Super Speed, Wilkinson blades. I do the pre-shave oil, brush on the cream, etc. Although I've come close, I haven't hacked myself up yet, but am getting a lot of razor burn. I feel like one little slip and I'll be bleeding all over. Last week I used a Mach 3 throwaway (with Edge Gel) that my wife had which was probably 4 months old, and I got just as good of a shave as the DE, and no drama.
I'm thinking there's good reason the DE's have pretty much gone by the way. YMMV.
Buck760 is offline   Reply With Quote
Old 01-28-2013, 04:13 PM   #1007
Madrox
Like a bat out of hell
Oddometer: 171
DE is all in the technique. The multi blade razors are pretty idiot proof. Personally, I get a lot more irritation and ingrown hairs from multi blade razors.
Oh and if those are the wilkinsons from Walmart they're complete shit. I barely have any facial hair and only get one shave out of them before they start dragging.
Madrox is offline   Reply With Quote
Old 01-28-2013, 09:50 PM   #1008
discochris
discochris's Avatar
Location: Sometimes the Twin Cities, Sometimes NW Wisconsin
Oddometer: 1,335
You do need to be careful. I nicked the corner of my nose this morning and started bleeding like a stuck pig. What a mess that was. No real way to stop it except time.
discochris is offline   Reply With Quote
Old 01-29-2013, 04:17 AM   #1009
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 785
styptic pencil should do the trick... Proraso makes a sting free gel version that works well too. but with a nick like that you may need to apply several times.
tattewell is offline   Reply With Quote
Old 01-29-2013, 04:38 AM   #1010
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,789
Whatever you do, don't keep putting new blades in it.
I'm somewhere around shave 30 with my current blade, and haven't cut myself in quite a while with it.
The goal is not to have a clean shave after a single pass, so don't even try.
Shave oil under a good shave soap is good. I use Prorasso pre-shave for a few minutes first, then apply 3 drops of shave oil and then the lather.
You may be using either too sharp a blade, too, or the razor you bought is too aggressive (there is a reason so many suggest starting out with the 34C - you chose to ignore that).
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is online now   Reply With Quote
Old 01-29-2013, 05:44 AM   #1011
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 785
While I don't subscribe to Mambo Dave's theory of keeping the same blade, he is absolutely correct about the prep work. With the correct prep work and the right technique, you should be able to obtain as good if not better results as any other razor whether multi blade or not.
Blade choice is a huge thing when starting too, and while nobody can say what will and wont work for you, you should get online and get some sample packs. IMHO wilkinson's are trash, I wouldn't give one to my worst enemy to shave his gooch with.
Try different soaps and pre-shave jobbers too, Proraso is popular, but there are some people who cant use it, the saying is YMMV for a lot of stuff in the wet shaving world for a reason.
edit: there are forums for this stuff too obviously, with the biggest advantage being, if you don't like a product, hock it on somebody who does.
There is also a guy online who exclusively sells Samples of products, so you can find things you like without spending alot.
Old 01-29-2013, 08:00 AM   #1012
P B G
Oddometer: 10,001
I did this once with a Mach 3, only it was that bit by the ear, and 3 symmetrical cuts /// like that.
On blades - I have found that he's mostly right, when I just start to feel like the blade is dragging, I rewet my wash cloth, soak the soap that is on my face, then whip a little hot water on my brush and relather.
And continue - that's been fine with the Merkur Platinums, I'm just starting to use some feathers, no cuts, beautiful shave, no ingrowns yet. So I don't know if it will like the same duration of shaves.
Old 01-29-2013, 08:28 AM   #1013
Buck760
Buck760's Avatar
Oddometer: 191
Thanks for the replies. I am using the Walmart Wilkinson's, so maybe that's the problem. I've watched the Mantic videos, and am giving it three (light) passes. From my research beforehand, the razor I bought (regular Super Speed) is supposed to be middle-of-road in aggressiveness - the "Red Tip" being the most aggressive, and the "Blue Tip" the least (typically used by women). I've been using the AOS products for a few years now, and like them. I'll order up a sampler pack of blades and give it some more time.
Old 01-29-2013, 09:45 PM   #1014
discochris
discochris's Avatar
Oddometer: 1,335
Eventually the styptic did stop it, but it took about 15 minutes, and I had a nice mess of crusty blood in the corner where nose meets cheek all day. Worst part was I'm getting over a nasty cold and I had to be super careful blowing my nose not to wipe the scab open and start it bleeding again.
Not sure why the hate for the Wilkinsons. I ordered mine online - didn't even know Walmart sold DE blades. Granted, my other experiences are some kind of generic Walgreens blades which are horrible, and Gillette 7 O'clock platinums from Russia, which are just okay. I need to try some others.
I do keep my Mach 3 around for traveling as well as to clean up around my ears on occasion.
Old 01-29-2013, 09:51 PM   #1015
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 785
I thought the lady Gillette was used by women? Which is actually a decent shaver. The only other issue that sometimes arises with older razors is that the original coating can get worn down and the underlying metal can cause skin reactions. If your razor is in good shape I wouldn't worry about that though.
PM me your address, I'll mail you a few different blades to try, people have done it for me on other forums, the least I can do for an inmate.
Old 01-30-2013, 06:33 AM   #1016
Buck760
Buck760's Avatar
Oddometer: 191
PM sent. Thank you for the kind offer. This site rocks!
Old 07-31-2013, 05:57 PM   #1017
SteelJM1
Undercover KTM rider
SteelJM1's Avatar
Oddometer: 1,726
Raising this thread from the crypt!
A couple weeks ago I was out of mach 3 cartridges and scoffed at the price for 10 new ones. I figured for the same price I could get myself a decent DE, and I was right. I acquired a Merkur 180 razor with a variety pack of blades and some poraso red.
Then I went a bit nuts. Now I have a B&B boar brush, Poraso green, Mitchells Wool fat and Tabac. And a stand. And some Israeli Personna blades.
I don't really have a dense beard at all, so I shave every two days, but I have to say I enjoy a nice new sharp blade that doesn't clog vs the old M3 carts.
Now that stupid Badger and blade forum has gotten me into natural soaps and shampoo bars! Damnit! I like this stuff so much!
SteelJM1 is offline   Reply With Quote
Old 07-31-2013, 06:10 PM   #1018
lowes48
lowes48's Avatar
Oddometer: 229
^Ha! Glad to another innocent victim stricken with RAD! (Razor Acquisition Disorder). Welcome to the club!
lowes48 is offline   Reply With Quote
Old 07-31-2013, 06:23 PM   #1019
SteelJM1
SteelJM1's Avatar
Oddometer: 1,726
Well I tried justifying it to myself and the g/f as a money saving endeavor.. but we all know how THAT goes
I DO really like the lower environmental impact though. Minimally packaged natural soaps that last a LONG time, along with tiny blades that can and do get recycled go a long way in my strange head. I figure I need to offset the environmental impact of working at a mine and riding gas-guzzling 2-smokes. Though through my short journey thus far, it's proving to me that newer =/= better. Sometimes... perhaps a lot of times, our parents/grandparents, and so on had some things right. And admittedly, I enjoy the novelty. And don't have to worry about some random friend shaving parts unknown with my equipment
I'm not really interested in aquiring more razors myself. For me, a mild razor does just fine due to my light facial hair growth. The soaps on the other hand.. so many good (and some not so good) smells! Now I just need to convince the g/f to let me shave her legs with it
Old 07-31-2013, 08:53 PM   #1020
d mc gee
d mc gee's Avatar
Oddometer: 803
I've turned it from a money saving endeavor to a money making endeavor. I buy old TTO gillettes at used stores, garage sales, flea markets, and any where else I can find them. A quick clean up, and list them on ebay. Paid for my Meurker blades and Porazo many times over. The key is not collecting.
If it wasn't for my graceful wife, my dumbass would be banned already
Doug Mc Gee
01 1150 GS
84 R100RS
74 XL350
d mc gee is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 03:22 PM.
