Old 01-25-2013, 09:16 AM   #466
humvee
humvee's Avatar
Oddometer: 1,650
Originally Posted by bash3r View Post
Place my order today... we'll post back with install update! They look real good....
Received my Mm10 order a few days ago up in Canuckistan. -30 outside so I have 3 months to decide how to mount them , but the packaging, instructions, lights, wiring and connectors look great. Free sticker too!
To the vendor...
On the instructions have a link to the wiring PDF, but that page is "not found" on your website. Do you plan on putting that back up?
"Explore an unpaved road with a new friend" - Fortune Cookie, September 30, 2013
humvee is offline   Reply With Quote
Old 01-26-2013, 05:31 PM   #467
Eddy Alvarez
Addicited to ALL bikes!
Eddy Alvarez's Avatar
Oddometer: 2,277
I need a set of AMBER MM8's for my DRZ400S, please let me know when they are in.
Eddy
Me: Honda CB1100 BMW R1200GS KTM 525EXC. Gabriel: KTM 50. Elena: Honda CRF70. Lynn: Sugar Momma and Gatorade/snack girl!
Eddy Alvarez is offline   Reply With Quote
Old 01-29-2013, 06:34 AM   #468
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,160
Always good too see the finished product.
-Brian
MondoMotos - LED Auxiliary Light Kits - Tusk Panniers
RoadRUNNER Magazine - Blog
Ride Reports - Four Corners - Amish Country - Costa Rica - Expedition Michigan (or not) - Tellico Plains
The Toad is offline   Reply With Quote
Old 01-29-2013, 06:44 AM   #469
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,160
To the vendor...
First... minus 30 degrees
The instructions and wiring diagram can be found on our website. There is a link at the bottom of each page called "Instructions and Diagrams" or you can click here for a direct link
-Brian
Old 01-29-2013, 06:46 AM   #470
humvee
humvee's Avatar
Oddometer: 1,650
A balmy -7C this morning
Thanks for the link.
Old 01-29-2013, 12:11 PM   #471
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 482
A balmy -40C this morning
Might be worth mentioning again as I've seen a lot of people miss it: Most LEDs are "polarity sensative". If you get the + & - mixed up they do not work at all.
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 01-31-2013, 10:24 AM   #472
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,160
Talking NEW LIGHT (sorta)
The MM12 replacement is now in stock and ready to ship.
It is very similar in shape, size and function as the much beloved and now retired MM12.
To avoid confusion with the MM12 it has been designated the MM8.
MM8
60 Degree Flood beam means a wider spread/shorter range
LED Luminous efficiency compares to 35W halogens
The MM8 is rated @ 12watts (.09amps draw)
Aluminum housing with a recessed PMMA lens
In a nutshell the MM8 is a low priced LED Floodlight (less than $75 a pair)
All the specs can be found on our website.
Or by clicking this link http://mondomotos.com/mm8
Thanks,
-Brian
Old 01-31-2013, 11:29 AM   #473
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 3,007
Thumb
Like the bullets so much on my vstrom I just ordered another set for my bonneville.
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 02-01-2013, 01:19 PM   #474
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,160
Thanks again for your business and let me know how they work out on the Bonnie.
I've had a couple people ask how you mounted them up on the Strom?
Did you bolt the mount to an existing bolt/hole? Any chance of getting a close up pic?
many thanks,
-Brian
Old 02-01-2013, 02:28 PM   #475
goodcat8
goodcat8's Avatar
Oddometer: 3,007
I've gotten a few PM's too. I used the supplied bracket mount on the outside of the fender mount. Looking closer last night I remembered we used the supplied bolts as well but managed to break one off in the fork mount for the fender. Drilled it out, and used a set of bolts we had laying around that matched threads. You could even use stock fender bolts if you grind down the heads in circumfrance to fit in the bracket.
Reading that I'm not sure it makes any sense....
Ill take a pic on my next smoke break.
Old 02-01-2013, 03:10 PM   #476
goodcat8
goodcat8's Avatar
Oddometer: 3,007
Here we go.
Fender mounted Bullet lights, 06 Vstrom 650.
Old 02-01-2013, 04:55 PM   #477
dljocky
Oddometer: 863
Good mounting job. Vstrom looks great too!
dljocky is online now   Reply With Quote
Old 02-02-2013, 02:54 PM   #478
etingelefunts
retem-odo
etingelefunts's Avatar
Oddometer: 815
Just ordered MM10 Bullets
These are about the only bullets you can find these days.
Hey goodcat8...3rd Battalion - 9th Marines - 1st Marine Division - Lima Company - Wpns Platoon - 0331
Less pondering. Simply march ahead, to the ends of this majestic planet.
etingelefunts is offline   Reply With Quote
Old 02-02-2013, 04:39 PM   #479
goodcat8
goodcat8's Avatar
Oddometer: 3,007
Old 02-02-2013, 08:56 PM   #480
etingelefunts
retem-odo
Oddometer: 815
Times are GMT -7.   It's 01:30 AM.
