Old 01-29-2013, 01:46 PM   #2761
Avi8tor
ADV Poser
Avi8tor's Avatar
Oddometer: 218
Back on topic...
I love the Highway Dirtbikes setup on Rox Risers. I mostly went with the HDB setup for a place to mount Powerlets and switches. Works really well and is solid. I used KX High Protaper Contours.
I was skeptical about the mirrors, but decided to try them anyway. They give a nice view...bigger than what I thought they would.
Also tested out the Rotopax setup. Decided on that vs a bigger tank.
CURRENT: None
PAST:
2013 CRF250L - 2009 DL650 - 1997 GL1500SE - 2005 DR-Z400S - 2008 DL650A - 2008 ST1300 - 2009 KLR650 - 2002 DR-Z400S - 1987 RM 250 - 1980 KD-80
Avi8tor is offline   Reply With Quote
Old 01-29-2013, 01:47 PM   #2762
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
[QUOTE=SAPB;20603093]
Originally Posted by NesquikNinja View Post
There was slight uphill section where the bike dropped to 55mph....but I was afraid to downshift to 5th due to not having a tach and having no idea where that would leave me RPM-wise?
I have not yet "bounced" mine off the rev limiter. First bike I've had in a while without a tach. Anyone with an aftermarket tach who can say where the rev limiter kicks it?
I ran the LRP wide open for hours and hours, for days, including dropping into 5th on hill climbs at highways speeds. This motor needs to rev to make power, I wouldn't worry about over revving it personally, that what the rev limiter is for.
A guy on a crb250l with the same motor rode from Miami to Prudo Bay Alaska wide open the whole time, day in day out, no issues.
Lost Rider is offline   Reply With Quote
Old 01-29-2013, 01:51 PM   #2763
positron007
Oddometer: 66
Originally Posted by Lost Rider View Post
You are still off-topic posting in here and not helping us owners keep a good resource for us all to use without sifting through non-ownership posts and comparisons.
All of your posts in this thread are part of our problem with too many posts not pertaining to ownership, we don't care what you used to ride, I suggest you read the OP again and help out the community by following the guidelines. I see you just joined ADVrider, we have guidelines and rules to make it better for everyone and easier to find the info anyone is looking for, it's called thread topics.
I understand wanting owners opinions, but that's part of being a part of the ADV community, sifting through the opinions in the appropriate threads and deciding who you should listen to. Not just polluting our owners threads because you feel like it.
OK. I won't ask for advice at this thread.
Thank you for making me feel welcome.
positron007 is offline   Reply With Quote
Old 01-29-2013, 01:56 PM   #2764
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
xladv.com
MentalGuru is offline   Reply With Quote
Old 01-29-2013, 02:01 PM   #2765
Ed@Ford
Oddometer: 1,671
SHEEITT! We don't need no frikkin' forum police....we'll just sick MentalGuru on their asses!!!
Ed@Ford screwed with this post 01-29-2013 at 02:01 PM Reason: increase rudeness
Ed@Ford is offline   Reply With Quote
Old 01-29-2013, 02:01 PM   #2766
Krono
Speed Junkie
Oddometer: 193
Originally Posted by MentalGuru View Post
Cmon .. there are some other threads, all about CRF250L that will suit alternate interests beside racks
http://advrider.com/forums/search.php?searchid=22378612
L
SM510R
Krono is offline   Reply With Quote
Old 01-29-2013, 02:05 PM   #2767
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
Now you get it.
Once you buy a LRP and have questions pertaining to anything that is owner related I will be happy to give you a big hug and welcome you in this thread, just help us all out and try to follow the rules to make a better ADV community. You could shoot me a PM if you have a question for me, but not ask it in this particular thread would be better.
It's not just you, it's many folks in here and it's time for some sort of reality check. There's plenty of other threads with actual owners opinions about the bike and how it compares to other bikes, but the owners thread is supposed to be a place for owners to easily find info that's on topic.
L
Exactly.
My contribution to the owners thread:
Old 01-29-2013, 02:08 PM   #2768
Ed@Ford
Oddometer: 1,671
Originally Posted by jsmithy View Post
Back on topic...
J Smitty:
Is that the National Cycle windscreen?
Is that the RotoPax storage pack? Are you satisfied with the amount of goodies you can cram in it? I've got an older 1.25G rotopax gas can...and the storage pack looks interesting.
Have u had any issues with the red gas can (also 1.25G) filler leaking?
Old 01-29-2013, 02:29 PM   #2769
Ed@Ford
Oddometer: 1,671
Here's a top notch owner question....AutoZone has a boatload of magnetic drain plugs...cheap....most bike places want about 3x price....what is the thread diameter (metric, probably 12 or 14)...but more importantly...what is the pitch?...for example...my KLR650 is an M12 x 1.5.....because right now...from zero miles to the first oil change is when the most nasty iron bits are swirling around in the crankcase as the transmission gears are bedding into each other.
AAAAND..while on this topic, CRF's only sells a big donut shape magnet that goes on the end of the oil filter..sure oughta catch lotsa nasty iron bits....anyone out there ever use one of them? Does it come out all furry with iron bits (i.e. it's doing it's job!)?
Old 01-29-2013, 02:44 PM   #2770
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Back on topic...
So how do you like your LED aux lights???
xladv.com
Old 01-29-2013, 04:18 PM   #2771
Ed@Ford
Oddometer: 1,671
For what it's worth, the Honda CRF parts fiche says the drain plug is 12mm...but no pitch....guess i gotta go make a mess and see if my klr plug fits...m12x1.5
Old 01-29-2013, 04:28 PM   #2772
Irish769
Irish769's Avatar
Oddometer: 81
Finally.....
After placing an order at the end of November, I picked up my CRF today. It's 30 degrees and wet but I took a litle ride just because. I know I'm going to enjoy the hell out of this bike. I am a little concerned about the braking power. I realize the pads need to break in but I would like some information about stainless steel lines. A couple of guys have inquired but I haven't seen any response. Is the benefit worth the cost and effort?
2008 Concours 14 (Traded)
2004 Yamaha Roadstar
1975 KZ 400
2013 CRF 250L
2014 BMW GSW
Irish769 is offline   Reply With Quote
Old 01-29-2013, 04:33 PM   #2773
Avi8tor
ADV Poser
Avi8tor's Avatar
Oddometer: 218
I like them. They are advmonster model 44s. This is the fourth bike they have been on. I can't run them much in the dark...they really piss other drivers off. I use them mostly for daytime conspicuity and trail rides during twilight.
CURRENT: None
PAST:
Old 01-29-2013, 04:39 PM   #2774
Avi8tor
ADV Poser
Avi8tor's Avatar
Oddometer: 218
J Smitty:
Yes. National Cycle Spitfire. It works well. I used it on my DR-Z where it fit and looked a little better.
Yes. Rotopax storage pack. I'm a little disappointed with the room in it. Not quite as much as it appears, but it is secure and convenient. It has room for two tubes and tire tools with room to spare.
I haven't put gas in it yet and I hope it doesn't leak. Most people are happy with them. This is 1.75 gallon size
CURRENT: None
PAST:
Old 01-29-2013, 04:45 PM   #2775
yyz
Oddometer: 40
Hey Mental Guru, I spotted this on the WRR thread, that's not really a nice thing to do
MentalGuru
Brain Damaged Inmate
Oddometer: 695
Need a good laugh??? Read the following quote from the CRFL owners thread.
Follow the link and share your thoughts... It's only fair....
Originally Posted by mtntrails
CRF250L Owners.... Please chime in on this thread...
http://advrider.com/forums/showthread.php?t=858964
If you don't like my response ask for a different voice.....
Let us consider that we are all partially insane. It will explain us to each other; it will unriddle many riddles; it will make clear and simple many things which are involved in haunting and harassing difficulties and obscurities now. - Mark Twain
yyz is offline   Reply With Quote
Times are GMT -7.   It's 07:10 AM.
