Old 01-09-2013, 01:16 PM   #1
Ceri JC OP
UK GSer
Ceri JC's Avatar
Oddometer: 2,462
F800GS Alternative Headlight Units
I was wondering if someone could summarise which aftermarket fairings that have headlights in are available for the F800GS? We have pretty stringent (compared to the US) restrictions that require an annual inspection and headlight scraped through last year. Since then, it has deteriorated further (condensation regularly forms on the inside, the reflective material has flaked away in places, misting of the exterior lense has gotten worse) and I suspect it would now fail. So now seems a good time to look into it.
For clarification, I'm talking about replacing the actual bug-eyed thing the reflector/headlights fit into. So, I'm talking more MST Rallycomp, as opposed to the TT Desierto/Britannia Composites "screens"
I currently have HID (both high and low beam) H4 bulbs in my standard headlight unit and ideally would like to keep these and use them to replace whatever comes in the fairings, rather than take a downgrade in the quality of my lighting.
I'd prefer something designed for the F800GS, but I have a dremmel, so I'd also be interested in seeing/hearing about any types others have successfully fitted, even if they were for another bike.
TIAYFFs
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back.
Ceri JC is offline   Reply With Quote
Old 01-09-2013, 03:37 PM   #2
BcDano
One Lucky Dude
BcDano's Avatar
Oddometer: 324
You could check out what Lost Rider did. One big badass light.
BcDano is offline   Reply With Quote
Old 01-09-2013, 03:51 PM   #3
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
As far as I know there is nothing on the market designed for the 800gs that is a bolt on...
I'm using the trailtech 8" HID on my bike... not road legal...
May check out the h4 conversion kit some people sell for the light it may help you.
Britannia Composites also sells bolt on kits that you can retrofit....
here's mine
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 01-10-2013, 02:08 AM   #4
Ceri JC OP
UK GSer
Ceri JC's Avatar
Oddometer: 2,462
Thanks, had no idea that existed (have found the thread now); the idea of having high and low beam in one of those single headlights makes them far more appealing, as if it has any hope of scraping through our "MOT" approval process, it'd be good to be able to set the low beam to a sensible distance.
here's mine
Wow, first one I've seen of the single headlights on an F8 that didn't require the TT tank to look good! I really like that; nice work.
Old 01-10-2013, 06:20 AM   #5
LukasM
Oddometer: 5,418
You are not going to get an aftermarket HID conversion kit through MOT, at least not if the inspector knows what he is doing.
The Rallycomp is the only replacement fairing I have seen, but if you are willing to cut off the bracket on the steering head you have a myriad of aftermarket options, like Ben above with the Trailtech 8" light, or the equivalent from Baja Designs. The most likely to pass option is the TT 8" frame with a Hella high/low light bucket insert that should be available with both "E" and "DOT" markings. Boatman on this forum makes the adapter plates, and Cyclops sells the entire unit with his plate and a Hella insert so you don't have to throw away the TT insert.
Old 01-29-2013, 02:11 PM   #6
onestop
Oddometer: 87
headlight
Hi Iwould like to know more on this headlight fitting as mine has broken and would be agood time to replace .
Could u please give more details on where to buy from
thanks darryl
All roads are great.
onestop is offline   Reply With Quote
Old 02-27-2013, 04:57 AM   #7
MSH
The Salt
MSH's Avatar
Oddometer: 3,183
here's mine
Man, this looks bad @$$! Good work. How was the wiring? Splicing or were you able to hook it to the factory loom?
~KTM 640 Adventure R~
"Lately it occurs to me what a long, strange trip it's been"
MSH is offline   Reply With Quote
Old 02-27-2013, 05:46 AM   #8
ebrabaek
Oddometer: 4,745
I think Ben sold it......
Erling
Old 02-27-2013, 06:10 AM   #9
MSH
The Salt
MSH's Avatar
Oddometer: 3,183
Yeah, I saw that. I still see him popping up on this forum... Thought he could enlighten us. I suppose a PM wouldnt hurt me either.
Old 02-27-2013, 10:35 AM   #10
ebrabaek
Oddometer: 4,745
I think it is painful for him to talk about it, as he clearly by now realize his mistake.....missing his 8GS.....
Erling
Old 02-27-2013, 04:52 PM   #11
blksheep
Oddometer: 35
I cut my plug and wired mine to the hi beam wires so I can turn it off. There's just 2 wires each for the low and hi beam lights. The biggest deal is having to cut the frame bracket off to clear the light housing. This is with the baja designs light tho, I don't know if you have to do that with the trail tech light.
blksheep is offline   Reply With Quote
Old 02-27-2013, 06:15 PM   #12
MSH
The Salt
MSH's Avatar
Oddometer: 3,183
Saw this one too... Looks like its inmate "snowy's"
Old 02-28-2013, 11:46 AM   #13
battlecattle
Oddometer: 271
I am attempting to redo the headlight on my f800 to a 3 LED light setup. I have about 90% of the parts but I am waiting on a part from the machine shop. Hopefully in the next few weeks I might be able to show it off. The hardest part for me is the electrical side with how I want the wiring done.
http://www.batlecatle.com/
CRF250L Service Manual
2014 KTM 690 Enduro
2014 CRF250L - Totaled
battlecattle is offline   Reply With Quote
Old 02-28-2013, 01:13 PM   #14
MSH
The Salt
MSH's Avatar
Oddometer: 3,183
Old 02-28-2013, 08:42 PM   #15
Motorfiets
Motorfiets's Avatar
Oddometer: 2,997
I'm still here!
The wiring completely bypasses the harness. It is wired simply just two wires to the battery thru a on off push button switch.
And yes with the trail tech light the frame mount still needs to be cut.
Ben
My Photo's
Times are GMT -7.   It's 01:26 PM.
