Go Back   ADVrider > Riding > Regional Forums > Northeast - Greater Flugistan and home of the carpet baggers.
Old 01-30-2013, 02:36 PM   #1
Happy Seal OP
Happy Seal's Avatar
Oddometer: 2,538
Bench syncing carbs in Ct
Does anybody in Ct have a way and know how to bench sync a set of carbs?
I just took apart and cleaned a set of carbs off of a Nighthawk 700SC and want to sync the carbs before I put them back on the bike.
with his videos I've been able to crash into trees even faster than before. ( Darius re Shane Watts)
Happy Seal is offline   Reply With Quote
Old 01-30-2013, 03:04 PM   #2
baloneyskin daddy
bikaholic
Oddometer: 2,176
Long ago we used to bench sync big smoothbores by using 4 equal lengths of solid wire, about 3 inches and put a right angle bend about an inch from the end,all4 identical. Then back out the idle screw untill the slides were totally closed and slip a wire unde each slide with the bend pointing to the side. Then open the throttle and adjust until each wirebend began moving to a vertical position at the same time.
baloneyskin daddy is offline   Reply With Quote
Old 01-30-2013, 03:09 PM   #3
thomas.tc.young
Oddometer: 866
i hold them up to a light, then look at the level of smile poking through. vacuum sync is the proper way to get everything perfect though
1969 CL350 permanent project
2013 Ninja 650
1987 XR600R
2001 TTR-125L
the klr/versys project: http://advrider.com/forums/showthread.php?t=810279
thomas.tc.young is offline   Reply With Quote
Old 01-30-2013, 04:39 PM   #4
akarob
Green Cantern
akarob's Avatar
Oddometer: 7,940
What he said. Make sure the plungers are sitting at as close to the same level as possible. I have a home made manometer that will sync 4 carbs if you want to come pick it up. I have it filled with green fork oil, visible and better than getting water in your carb. The only catch is that you have to keep it, I have no use for it and I was considering selling it for like $20.
In action...
akarob is offline   Reply With Quote
Old 01-31-2013, 06:40 AM   #5
Speedo66
Transient
Oddometer: 6,936
Don't know if you need them, but many Nighthalk S parts here on CL , not mine:
http://newyork.craigslist.org/mnh/mcy/3555641496.html
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 01-31-2013, 03:04 PM   #6
Happy Seal OP
Happy Seal's Avatar
Oddometer: 2,538
Thanks Speedo!
Times are GMT -7.   It's 06:20 PM.
