Old 01-31-2013, 09:10 AM   #32851
Longboardr
Longboardr's Avatar
Oddometer: 144
Originally Posted by ba_ View Post
I was referring to bolt 2 in this diagram:
That looks to be a shoulder bolt, you can tighten to your hearts content. The shoulder of the bolt hits what you're tightening it against and stops you from being able to pinch/bind the pedal from over tightening.
Longboardr is offline   Reply With Quote
Old 01-31-2013, 09:13 AM   #32852
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,263
+1 on the grease. I was going to use waterproof grease
I'm not sure what nut you are referring to
Too many bikes I work on...KTM has nut on backside. WRR threads into frame boss.
Still same advice....just snug....washer and clip will keep bolt from working itself out. If worried, and I think I did this on mine, a small drop of blue(medium) thread locker on bolt. Threaded aluminum is not too strong, so I'd be surprised if torque spec( for that bolt) was any higher than 8-9 ft/lbs.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is online now   Reply With Quote
Old 01-31-2013, 09:51 AM   #32853
jon_l
jon_l's Avatar
Oddometer: 3,369
Originally Posted by DefyInertia View Post
Huh?
You can use whatever rotor on the front and whatever sprocket you want on the rear regardless of wheel size. Wheel size itself does not have a direct impact on caliper location or chain length.
I have a set of 17s for my WRR that swap out in 10 mins. 17s with sticky rubber dot compare to a 21/18 set up with ok street rubber.
My bike is set up for dirt but I can run a good pace at the motard track without adjusting the suspension, but I'm light.
Maybe I misspoke? The WRX caliper and rotor is different than the WRR. I guess with a custom wheel set up correctly, you can swap easier.
It is hard to imagine that dropping the front 2" wouldn't have an impact on handling. When lowering the bike using the shock clevis, everyone raises the forks 1/2"-3/4" to compensate. Lowering amount is a smaller change that 21">17" front swap.
CBF1000 & PCX150
jon_l is online now   Reply With Quote
Old 01-31-2013, 10:18 AM   #32854
ba_
ba_'s Avatar
Oddometer: 2,793
Just make sure you remove the clip off the back before removing the bolt (oops).
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is offline   Reply With Quote
Old 01-31-2013, 10:45 AM   #32855
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,263
LOL....yeah.
Old 01-31-2013, 12:37 PM   #32856
UtahFox
UtahFox's Avatar
Oddometer: 446
FMF Powerbomb.
I'm curious, if you just install this header, does it increase the bikes' HP? I'm also wondering about the volume, does that increase a lot as well?
UtahFox is offline   Reply With Quote
Old 01-31-2013, 02:34 PM   #32857
TwilightZone
Oddometer: 3,149
>"I'm curious, if you just install this header, does it increase the bikes' HP?"
I think the bike reaches max RPM's much easier. Without the header I didn't reach the cutoff-rpm very easily. After the header, it winds much easier to the cutoff point. I also think the header improved the torque through the powerband... (and quite a bit). But I don't think it made much of a difference on the max hp. Am running a quiet spark arrestor, more with the exhaust open... I dunno. (see below)
>"I'm also wondering about the volume, does that increase a lot as well? "
Didn't really notice anything in the volume. I'm running the header with a Q4 exhaust... and an install of the 'Powercore' spark arrestor (the quiet one I can't remember the part number, somewhere here in the thread).
IMHO: Pretty reasonable noise levels.
"I don't really know, I've been too busy falling down."
TwilightZone is offline   Reply With Quote
Old 01-31-2013, 03:45 PM   #32858
DefyInertia
Saratogian
DefyInertia's Avatar
Oddometer: 153
Got it, I didn't get that you meant X swap. I would say buy the x wheel and an R rotor if not wanting to mess with the caliper/MC stuff. Don't really need custom and incremental cost is small. Stoppies all day and fine for street, but my brake hand does get awful tired at the motard track.
Yes it impacts handling, it handles like the X. Whoot! Lower over all with lower front relative to R. This is a good thing, not something that needs to be compensated for like when simply lowering the R for a shorter rider.
My point is, I have sportsman set ups and tard setups, the 17s are the way to go (for second set) IMO and an easy swap.
There's a feeling I get when I look to the West...
DefyInertia is offline   Reply With Quote
Old 01-31-2013, 04:14 PM   #32859
Llamaha
Oddometer: 851
I am thinking of purchasing the 21/18 set for my WRX from wheeling cycle supply, anyone here had any issues with these? It will have to be a straight swap kit or I won't have the time to swap them ever. Can I use the same chain?
Llamaha is offline   Reply With Quote
Old 01-31-2013, 04:44 PM   #32860
Jungle Man
frenzied adventurer
Jungle Man's Avatar
Oddometer: 505
I've heard good things about wheeling cycle supply.
I got my warp 9's new on ebay. They are a direct swap out and only $719 total. They seem to be stout; have handled bouncing on rocks with a flat for a few seconds, and a few hard hits.
http://www.ebay.com/itm/COMPLETE-WHE...b201b5&vxp=mtr
"50% of our maintenance is caused by 50% of our maintenance." -Dave. "If you're too busy to hunt and fish, you're too busy" -Jase Robertson. "...it's not the years in your life, but the life in your years" -Abe Lincoln
Ride it like you stole it
Jungle Man is offline   Reply With Quote
Old 01-31-2013, 05:40 PM   #32861
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,753
I've got the 18/21 SM Pro kit on my X and they are indeed a direct swap. I also bought OEM brake rotors to save me the hassle of swapping those when I want to switch back and forth between street and dirt. Makes it real easy, and the larger diameter rotor up front offers great stopping power. I also bought a 49T sprocket for the rear wheel, and I use a 110 link chain.
You can use the same chain as long as you use the same size rear sprocket, but for dirt, you'll probably want 3 or 4 extra teeth in the rear.
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 01-31-2013, 07:04 PM   #32862
Llamaha
Oddometer: 851
Thank you very much for the responses guys, I think it will give it the green light :)
Llamaha screwed with this post 01-31-2013 at 07:51 PM
Old 01-31-2013, 08:29 PM   #32863
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 587
Programmer Help Needed
I have searched on this thread, but I can't find any response to a question Kingwolf once posed (2years ago). I have a new Attitude Ind. FI programmer model 3.2 coming and wanted to know if anyone here has bought and successfully programed it for their WRR; standard Mods, FMF pipes,AIS & flapper removed. Just looking for baseline numbers to start off with.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 02-01-2013, 08:13 AM   #32864
sodapop
Caffeinated
sodapop's Avatar
Oddometer: 105
I think confusion comes with the difference between X and R hubs. If I understand correctly, the front rotors are not interchangeable.
So, if you are starting with a WRR, which has the small front rotor, you can put on a 17" front wheel made with the WRR hub without changing the caliper. This means you will have a motard setup with a smaller front brake rotor than what Yamaha chose to put on the WRX.
If you are starting with a WRX, which has the large front rotor, you can put on a 21" front wheel made with the WRX hub without changing the caliper. This means you will have an off-road setup with a larger front brake rotor than what Yamaha chose to put on the WRR.
Some people buy the complete other front brake system with caliper, line, and lever. This way they can more easily change rotor sizes without bleeding brakes. Another idea is to have an "X" diameter rotor made to fit on an "R" hub.
Sent from my Nexus 7 using Tapatalk HD
Robb
2008 Yamaha WR250R
Gone: 2007 Honda VFR800A, 2006 Suzuki SV650S, 2002 KTM 125SX, 1994 Yamaha YZF750R, 1992 Honda CBR600R, 1991 Suzuki GSXR750R, 1989 Yamaha FZR600R, 1983 Honda CR80R, 1982 Honda XR80R, 1979 Yamaha GT80
sodapop is offline   Reply With Quote
Old 02-01-2013, 08:39 AM   #32865
30Bones
30Bones's Avatar
Oddometer: 4,650
I used to think two sets of wheels was the cool, flatbill, black socks, bro thing to do, then I found myself going down gravel/dirt with the 17's and commuting on the 21/18....purely out of laziness but the hassle no matter if it's 10 minutes or an hour just wasn't for me.
Not matter how you shake it, it will take lot of tire changes to match the value of two sets of wheels, rotors, chains. Just makes stupid financial sense to me in my older age....then again this hobby has very little that is cheap or that makes financial sense.
30Bones is offline   Reply With Quote
Times are GMT -7.   It's 03:53 AM.
