Old 10-17-2012, 04:24 PM   #31
KLXmcrider
Oddometer: 194
I'm feeling a little envious of your rebuild. I want something similar so I'll be watching
this thread , day dreaming as always........
KLXmcrider is offline   Reply With Quote
Old 10-17-2012, 09:01 PM   #32
focallength OP
You're Welcome
focallength's Avatar
Oddometer: 5,049
Originally Posted by 955616846 View Post
I don't think that the case inserts will be necessary and you still don't know the state of the crank or transmission...
Crank is being replaced, whole new hotrods bottom end, the onlything that may remain are the gears, (if their good, which they look ok from what I can see, ill know by friday )and countershaft, everything else is new (bearings/seals). The timeserts are just insurace, dont want to break a headbolt, it is possible, so better safe than sorry. Especialy since I wont know until it happens then id have to tear the engine apart again, $80 to be safe is money well spent. Plus those threads will never break with titanium inserts. Ive had a bad experience with a head seperating on a bigbore and ive heard enough war stories...not dealing with that crap again. Ill most likely even order some better head bolts, if im building this thing I might as well make it unkillable.
[IMG][/IMG]
what was the greatest thing, before sliced bread?
focallength is offline   Reply With Quote
Old 11-26-2012, 06:51 PM   #33
focallength OP
You're Welcome
Oddometer: 5,049
Sorry for the delay, got the cases back yesterday, bottom end is together and in the frame.
I had the timeserts put in, they were drilled a little deeper so I can put in longer head bolts. Maybe overkill but better safe than sorry.
Replaced all of the seals, bearings, the bottom end is brand new aside from the gears, they were in good shape. New hot rods crank.
Next is a 434 bb kit, just send the sleeve and for $419 I get a bored out sleeve, piston and rings.
The big hurt is the head, itll all be brand new, a blank head is 575
I need to replace the clutch and basket another $400
And ill get new bigger radiators to support the bigbore and increased compression as well as the hot cams.
Pics soon...
Old 12-03-2012, 03:52 PM   #34
focallength OP
You're Welcome
Oddometer: 5,049
Im going to try out mylers for the radiators. They sell oversized radiators for 135 so i ordered one to make sure it fits ok, ordered the millenium 434 bb kit.
They said it should fit ok with a clarke 3.9 tank. They look great and the added cooling should help with the 434 kit , increased compression and hot cams. I should have the radiator thursday and the bb kit some time next week.
Ill get lots of pics as the parts roll in.
Old 12-29-2012, 01:43 PM   #35
focallength OP
You're Welcome
Oddometer: 5,049
Ok, got the cylinder and piston installed
Millenium, with je piston 434 kit.
126/focallength/2012-12-19121132_zps0d198887.jpg[/IMG]
Painted the cylinder red, for a little pizazz, lets people know theres a little something special inside.
Gapped the top ring 0.02 mm smaller for a bit more compression.
I bought a new radiator to test it out, very well made, sides twice as thick as stock. Myers super cool radiator
Ill buy a new left one from them too. They say they can rebuild one of their radiators for iirc $45, even if its pancaked flat. The sides are easily twice as thick as stock, if not more.. I dont see them crushing, unless ran over by a dumptruck.
Im buying parts for the head, all kibbewhite, just trying to score a new head
So heres the score, hot rods bottom end, millenium bb kit with 434 je piston, myers super cool radiator. Kibblewhite springs/valves, fcr carb.
Titanium timeserts, with a little extra length for some uber head bolts.
All new gaskets and bearings, plus oil jet.
focallength screwed with this post 12-29-2012 at 01:52 PM
Old 01-02-2013, 08:19 AM   #36
bobfab
bobfab's Avatar
Oddometer: 1,499
If my DRZ motor ever dies ill be heading a similar route!
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 01-03-2013, 06:50 PM   #37
rgp332
Oddometer: 149
Check out Evans coolant to replace the antifreeze,cools alot better and wont boil over ! Use it in a 2stroke I have that was running hot in the slow stuff after that no problem !
08 DR 650
08 V-Strom 650 -Sold
08 KTM 300XCW - Sold
I must have sumthin about 08's
rgp332 is offline   Reply With Quote
Old 01-03-2013, 09:44 PM   #38
Bobby Ginger
Cat Herder
Bobby Ginger's Avatar
Oddometer: 1,034
Thumb
Just found this, picking up a DRZ tomorow. If I ever have issues this will be handy.
2009 GSA 2008 Husky TE450 2006 KTM 950 SM
IBA 50407
Bobby Ginger is offline   Reply With Quote
Old 01-24-2013, 09:39 AM   #39
focallength OP
You're Welcome
Oddometer: 5,049
so a little update, got a new head and all the parts for it, except the hot cams which are on back order for a month. i just need the clutch primary gear and plates. a left radiator and right radiator sensor. i got a e model air boot and throttle cables for the fcr. aside from the cams and clutch primary gear i just need to order a header, ill prob. get a fmf powerbomb. so the parts are trickling in slowly and ive been organizing them and double checking. ive replaced almost every single part on the bike with new,oem or aftermarket. school has the bike on the back burner but ill get pics up as soon as everything is in.
Old 01-24-2013, 09:53 AM   #40
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,039
I would highly recommend that you waste a few gaskets and check your valve squish, you know, modeling clay and check for proper valve to piston clearance.
Stiffer valve springs I hope?
Old 02-01-2013, 08:03 AM   #41
focallength OP
You're Welcome
Oddometer: 5,049
Got my new header in yesterday
[/IMG]
Old 03-21-2014, 09:24 AM   #42
deepcdiver
Nobody Special
deepcdiver's Avatar
Oddometer: 788
It's funny that what started as a "$800-900" rebuild ends up a 2.5-3x monster build :) It's a disease I tell ya....but should be worth it.
Pain is just weakness leaving your body
deepcdiver is offline   Reply With Quote
Times are GMT -7.   It's 05:37 AM.
