Old 01-30-2013, 03:41 PM   #331
danedg
Horizontally Opposed
Oddometer: 6,686
I'll have to rely on you guys
I'm at a slight disadvantage having never ridden this bike or any like it.. no owners manual. It's got a keyed switch back left and all sorts of buttons and knobs on the dash and now up pops another starter switch!
I'm all over Gregs website. Bless his heart!
In the meantime I'll continue to take many photos:
and rely on you guys to ask the really dumb questions
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic
danedg is offline   Reply With Quote
Old 01-30-2013, 03:57 PM   #332
Bloodweiser
honestly
Bloodweiser's Avatar
Oddometer: 2,618
Originally Posted by F_Sahms View Post
The switch on V7 Sports can also start like a car, by turning past the "run" setting, but it has a starter button as well. I am not sure if my Eldo does it too.
That's how I rigged up my ambo.
Bloodweiser is offline   Reply With Quote
Old 01-30-2013, 04:34 PM   #333
danedg
Oddometer: 6,686
It's gonna be a while
before this key gets turned again (in anger)
But I'll check it tomorrow to see if it has that momentary..
I just ASSUMED! that it did.
Old 01-31-2013, 05:05 AM   #334
nick949eldo
Oddometer: 1,026
Danedg - starting process for my 74 Cali.
Put key in switch by your left thigh.
Turn it on (one click to the right)
On the dash, lift black knob on the right (at about 2 o'clock) up
Put your thumb on the horn-like switch under the throttle
Push.
The motor should turn over, assuming all the wiring's connected and you have a battery.
Nick
Beyond the Coffee Shop: Riding 1970's Moto Guzzis in Northern Canada (Kindle Book) Buy it - it's cheap and good! All my adventures and disasters in one place.
nick949eldo is offline   Reply With Quote
Old 02-01-2013, 12:38 PM   #335
danedg
Oddometer: 6,686
...and a motor,tranny and a few other bits
Old 02-02-2013, 05:17 AM   #336
nick949eldo
Oddometer: 1,026
Yep - that might help too.
Nick
Old 02-02-2013, 12:58 PM   #337
danedg
Oddometer: 6,686
Master cylinder order?
I pulled, cleaned, refreshed. lubed and want to install new rebuild kit in correct order.
Plastic plug, spring,cylinder, flat washer, ...check.
Then gasket and cupped washer?
What should I be seeing from the handle side? Washer or gasket?
Old 02-03-2013, 08:55 AM   #338
danedg
Oddometer: 6,686
Master cylinder setup?
This ought to illustrate better what I THINK should be the correct order for the cylinder.
Missing on the left is the plastic "t" plug, then the spring, then the cylinder, then the flat washer.
Then the rubber gasket with the flange to the right and the cupped washer fitted over the rubber gasket.
The cupped washer has an enlarged edge that points to the right.
This can then be pressed into the housing and then prevents the whole assembly from popping out due to the spring and/or hydraulic pressure.?
Old 02-03-2013, 01:58 PM   #339
danedg
Oddometer: 6,686
Ruh roh!
Old 02-09-2013, 10:06 AM   #340
England-Kev
Oddometer: 3,643
A little inspiration for you....
it is for sale in Italy right now...
http://www.ebay.co.uk/itm/Moto-Guzzi...50709315500%26
England-Kev is offline   Reply With Quote
Old 02-09-2013, 10:09 AM   #341
England-Kev
Oddometer: 3,643
I would love to know where they got the cool mirror mounts from?
Old 02-09-2013, 11:30 AM   #342
davebeef
Buffoon
davebeef's Avatar
Oddometer: 261
Hi,
New guy around these parts. Recently bought this pile o crap in California. Sailin back to UK as I type. May be needin the help o you guys soon!!
Rgds,
Dave.
davebeef is offline   Reply With Quote
Old 02-09-2013, 11:51 AM   #343
England-Kev
Oddometer: 3,643
Dave, fantastic, I am so glad you bought it, you will need to tell me all about it when you get it home. And this is why... http://backstreetthunder.wordpress.com/
respect, my man
Old 02-09-2013, 12:06 PM   #344
davebeef
Buffoon
davebeef's Avatar
Oddometer: 261
Cheers Kev.
Yip took the plunge. Always wanted one, couldn't afford to pay for a minter straight out and little, if any, project bikes of this type available in this country. Price was right and I can restore as I have the funds. Due in end of the month and currently wrestling with her majesty's finest to get a lower rate of import VAT/ duty. Will get a better idea of whats needed when she arrives. Will keep you posted for sure!
Dave.
Ps. Was just about to go for yours some time back when it suddenly disappeared from ebay. Boy did I curse you at the time!! heh heh..
'70 Moto Guzzi Ambassador, '78 FLH Shovelhead
'81 BMW R100, '79 MZ 250/1, '81 MZ 250/1
Old 02-09-2013, 05:05 PM   #345
danedg
Oddometer: 6,686
Originally Posted by davebeef View Post
Hi,
Rgds,
Dave.
You're a better man than I, Gunga Din
Times are GMT -7.   It's 11:53 PM.
