Thread Tools Search this Thread Rating: Thread Rating: 437 votes, 4.94 average. Display Modes
Old 02-01-2013, 12:56 PM   #6811
dlh62c
Oddometer: 1,603
Originally Posted by Emoto View Post
You're welcome. I wonder what happens if you have "rubber-banded" those points into place.
Take the files and modify them as you wish. Remove points and add them back or add more. As you know you can keep track of the via-point total in BC using the route's property window.
daryl
Old 02-01-2013, 01:02 PM   #6812
Rocky TFS
Rocky TFS's Avatar
Oddometer: 590
I believe that's what Daryl DID use. As opposed to the "Insert" button in the Route Properties window. If you use that, the only insertion choice you get is Waypoints.
I sometimes wonder if even a Mensa could really understand the byzantine nature of Garmin's new devices. I sure as hell can't.
Rocky TFS is offline   Reply With Quote
Old 02-01-2013, 01:04 PM   #6813
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Originally Posted by mass-klr View Post
I found out that the Montana will freeze or take a long time to catch up so that it is not usable if you increase the Details setting and drive into the city. Seems like there is just too much things to load and it just freeze. As soon as I get out of the city with less roads and businesses it will work fine again. Is this the same for everyone else?
Firmware 470 was just released yesterday and is supposed to improve this behavior :)
atlas cached is offline   Reply With Quote
Old 02-01-2013, 01:08 PM   #6814
Rocky TFS
Rocky TFS's Avatar
Oddometer: 590
Oh God, not AGAIN!??!? What will be the glitches THIS time? EMMBEEDEE and Atlas, you're up!
Old 02-01-2013, 01:13 PM   #6815
atlas cached
OX Ambassador
Oddometer: 688
never mind...
Old 02-01-2013, 01:14 PM   #6816
atlas cached
OX Ambassador
Oddometer: 688
For starters, Bug 28 was reported to be solved, but I still see the same behavior on my Montana 650 with v470. How about you?
Old 02-01-2013, 01:18 PM   #6817
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,860
Originally Posted by woodsatyr View Post
What defines an earlier unit? Do you have a serial number range or something?
There likely is a serial number range but I have never seen it published. Is yours causing you problems?
Old 02-01-2013, 01:19 PM   #6818
atlas cached
OX Ambassador
Oddometer: 688
If your GPSr supports USB Mass Storage Mode, and you can view internal folder and file structure, you have a newer unit :)
Old 02-01-2013, 01:19 PM   #6819
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,860
What, you mean we're the guinea pigs? Okelydokely!
Old 02-01-2013, 01:35 PM   #6820
advNZer?
advNZer?'s Avatar
Oddometer: 2,925
how does one ascertain the age of a unit in a shop?If i buy one from a local shop i want it to be a NEW one not an old NIB one
aka BMWST?
advNZer? is offline   Reply With Quote
Old 02-01-2013, 01:46 PM   #6821
dlh62c
Oddometer: 1,603
I couldn't agree more!
In BC, If you right click on a via point in a route's property window, a drop down list will appear that will allow you to change its property to ‘Alert On Arrival’ or ‘Don’t Alert on Arrival (Shaping Point)’. Not all gps support non announcement of shaping points. It would appear that the Montana doesn't. and thus treats them as way-points, The 62s doesn't as well, but I think some Nuvi's do. That's why you see the Blue Flags when the route loads.
I feel like I've beat this horse enough for one day.
daryl
dlh62c screwed with this post 02-01-2013 at 02:05 PM
Old 02-01-2013, 02:00 PM   #6822
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,824
Originally Posted by dlh62c View Post
Emoto
Thanx!
That's what I see on my 62s. The route with 51 via-points will load, the route with 52 will not. The routes were made using Basecamp. The routes should be the same except for one via-point being added. Keep in mind, the effort was some what rushed. The route via-point details can be seen in the route property window in BC
The points were added using the route 'Insert' tool. So by most people's definition, these would be considered route shaping points. IMO any point used to tailor a route is considered a via-point. It could be a point placed on a road as a shaping point or a series of way-points strung together or a combination of both.
daryl
A little primary on the frustrating Garmin language:
POI - A formal Point Of Interest. An entry in the internal POI database with a name, location and usually other information associated with it.
Waypoint - Any arbitrary point on the map that you have designated you want to keep track of. Usually stored in the "Favorites" or "My Locations" or whatever your personal navigation device calls its waypoint storage database. Your device will usually allow you to store such things as the location, any arbitrary name you want to supply and other information such as address, phone number, category(ies) and a symbol/icon to be used when displaying it.
Via Point - A point used to create a multipoint route, e.g. Go from Point A to Point B via some other arbitrary point(s) that you will designate. If your personal navigation device supports multipoint routing, the via point can be a POI, an existing waypoint/favorite or any other form of location that is searchable on your device, e.g. address, intersection/junction, custom POI, etc. In most cases, to use something as a via point it must already exist in one of the devices' searchable databases.
Shaping Point - In Mapsource, to "shape" a route to go exactly where you want there are a couple of methods. Just as with the personal navigation device, you can edit the route's properties to insert Via points (these are not shaping points although they do serve a similar purpose). You can also just use the route tool to click on spots on the map to force the shape of a route. When you do that, you are using a location that is not already in one of the searchable location databases. Mapsource does not force you to add these points to any of the formal databases. It simply inserts the actual coordinates invisibly into the route. These are shaping points.
Shaping points occur in another, automatic, fashion as well. Even when you only designate a two-point route, e.g. go from Point A to Point B, there will usually be multiple places, usually intersections, where a change in direction is required. When building the route, the personal navigation device (or Mapsource/Basecamp) will automatically include all of these points in the route.
Old 02-01-2013, 02:03 PM   #6823
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,824
daryl
Nope, changing the property of a via point to non alert does not convert it into a shaping point. It's merely a non alerting VIA point.
Old 02-01-2013, 04:12 PM   #6824
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,860
I upgraded to 4.70 using Garmin Express and it worked just fine. The only thing I've found so far is that all the maps were enabled on the profile which was active when I upgraded, but I found nothing else to complain about in the 5 minutes I've had to check it out.
Old 02-01-2013, 04:47 PM   #6825
woodsatyr
Kitty Boy
woodsatyr's Avatar
Oddometer: 497
I still get the occasional white screen. Otherwise, it seems to be working ok.
Damn!!! I just got it out to check what Atlas said about USB mass storage and when I started it up, I got that white screen!!
woodsatyr is offline   Reply With Quote
Times are GMT -7.   It's 09:11 AM.
