Old 12-18-2012, 08:29 PM   #1
1994klr250 OP
1994klr250's Avatar
Oddometer: 634
Anyone build there own fuel pump bypass cable?
Has anyone built a fuel pump controller bypass cable? I might be able to get an old controller and use the connector off of it. If I can't get a old one anyone know which bmw p/n is the correct one to connect on the fuel pump? I was planning on putting a SAE connector on it for use with my battery tender harness.
2300 miles on a 250 all for a sticker http://www.advrider.com/forums/showthread.php?t=616239
Fall ride on a KLR250 http://www.advrider.com/forums/showthread.php?t=754065
1994 KLR250, 2009 F800GS, 2006 KLX351
1994klr250 is offline   Reply With Quote
Old 12-18-2012, 08:32 PM   #2
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
Easier to just buy one
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 12-19-2012, 04:18 PM   #3
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 817
Answer: yes
See here: http://advrider.com/forums/showthread.php?t=841433
Bucko is offline   Reply With Quote
Old 12-27-2012, 09:06 PM   #4
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Yes, I just built one. Simple to do. Why anyone with access to an old controller would opt to make a cable that
connects to the battery is beyond me.
PM me for instructions if you want.
Spending 30 or 40 bucks on a cable is not worth it, you can roll your own for free.
Old 12-27-2012, 10:32 PM   #5
JRWooden
Oddometer: 4,232
+10
Very simple if you have access to one of the BMW special electrical connectors from a dead controller
Old 01-24-2013, 07:51 PM   #6
Moqui
Oddometer: 10
Plug part numbers
The BMW part numbers for the conectors are as follows.
61-13-8-352-330 Blue plastic housing. Qty 1
61-13-0-007-571 Snap in receptical with wire. Qty 2
These are available from BMW automobile dealerships and cost roughly $12 for all. The wires are 19 inches long and snap right into the blue housing. All that is left to do is either put alligator clips on or install the plug of your choice to match a battery tender type plug.
2010 F800GS
2000 200EXC
Moqui is offline   Reply With Quote
Old 01-24-2013, 11:06 PM   #7
mustardfj40
mustardfj40's Avatar
Oddometer: 141
[61-13-8-352-330 Blue plastic housing. Qty 1
61-13-0-007-571 Snap in receptical with wire. Qty 2]
Cool! Can you please post a picture of it? Thanks.
mustardfj40 is offline   Reply With Quote
Old 01-25-2013, 04:38 AM   #8
MikeMike
MikeMike's Avatar
Oddometer: 4,150
You can look up pictures of the parts on a parts fiche on line.
A duff FPC is free, from that you can easily make a type of bypass that does not have to plug into your battery. Ask around and you will likely find an FPC that has gone south on someone. Having to disconnect the cable every time you stop the motor will get old fast.
Old 02-01-2013, 03:47 AM   #9
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,669
How many fuel pump controller failures have people experienced? If you are on the road and it fails on you, can't you make your own bypass cable with your failed fuel pump controller connector?
- David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 02-01-2013, 04:44 AM   #10
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Of course you can.
But to do that, you better be sure it is the FPC before you take out the cutters.
Having a ready to go cable will give some people who dont have the best troubleshooting abilities some peace of mind.
Others will appreciate the practicality of not having to do splicing again.
Old 02-01-2013, 05:33 PM   #11
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,669
How many FPC have gone bad on the F800? If its a small number, I'll take my chances and trouble shoot the bike whenever I have a problem.
David
Old 02-01-2013, 05:44 PM   #12
David13
David13's Avatar
Oddometer: 610
I never thought of making one for my 800.
However, I did, on a trip to Mexico, start thinking that I should learn how to make one for my 1200, as a lot of people said it would fail.
It did. Just moments after I was thinking about it.
However, I was able to get someone to come and lend me their spare.
What he had done was replace his controller before it went out. Then keep the original one as a spare.
I got a new one for myself, and used my old one to make a by-pass.
That way the cable does not have to pass outside the fairing and into the battery, as it does on the ones that you buy.
Most of those tap into the exterior (to the fairing) outlet for accessories.
That seems a dumb way to do it to me.
dc
David13 is offline   Reply With Quote
Old 02-02-2013, 05:54 AM   #13
MikeMike
MikeMike's Avatar
Oddometer: 4,150
David's post above should answer any doubters.
I had thought of buying a spare but learned the Tim Cullis Morrocan bypass method and kept it as a PDF in my cel phone. Got me home when I was a couple hundred kms away in a mountain here where I live in Mexico.
If you have a black FPC, you might have better luck than a grey one.
Old 03-24-2013, 06:21 AM   #14
lawe
lawe
Oddometer: 141
Thank's!
This is the parts described by Moqui:
This is where to connect:
This is my version of a finished cable:
Please note that you can't power the pump from the stock outlet since it will shut down due to (I guess) the high power consumption from the pump.
And this is where my cable will hopefully rest in peace:
Lars
Umeň, Sweden
BMW F650GS -05, F800GS -08
lawe is offline   Reply With Quote
Old 03-24-2013, 07:59 AM   #15
JRWooden
Oddometer: 4,232
Lars:
Once the wires are inserted in the plug can the be (easily) removed again?
If not, I am thinking of leaving the plug unassembled to the wires ...
I recall Joel saying that sometimes "jogging" the pump back and forth a bit by reversing the polarity of power to it would get the pump unstuck... so leaving the wires free would more easily allow
the jogging routine...
JRWooden screwed with this post 03-24-2013 at 08:07 AM
Times are GMT -7.   It's 07:45 PM.
