Old 02-01-2013, 03:33 PM   #73366
Obard
Oddometer: 26
Newbie here
Not new to cycles or forums, but new to working on my DR650, and new to this forum. Not sure whether to post questions here or not. Here goes ... Why does my dr smoke blue exhaust when it's cold, then when it warms up, no smoke at all?
Obard screwed with this post 02-01-2013 at 03:44 PM Reason: Auto correct kills me.
Obard is offline   Reply With Quote
Old 02-01-2013, 03:34 PM   #73367
BenYork
Oddometer: 86
OK. Idle mix screw is under brass plug? Will pull that out and clean. Thank you very much.
BEN
BenYork is offline   Reply With Quote
Old 02-01-2013, 03:39 PM   #73368
procycle
procycle's Avatar
Oddometer: 2,277
BEN
Make sure the passage between the idle mixture screw, the pilot jet and into the carb throat is clear.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 02-01-2013, 03:59 PM   #73369
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Valve guide seals most likely. No big deal. You could do a valve job to fix it ... but is really of no consequence, won't affect over all performance and the amount of oil used is minimal.
BEN
I would pull the Carb off, then pull off the float bowl. Inspect the Pilot jet,
and pull float out and clean under float needle (little rubber tip) Blow out with compressed air, carefully reassemble.
Filters: You have a little filter in the metal fuel inlet tube. It's a tiny white
filter. Pry it out ... check it for crud.
Pull petcock out of fuel tank and clean intake filter stem.
From here you should install an extended Idle mix fuel screw. Much easier to adjust. Keep reading here to learn all the ins and outs of tuning the simple DR650.
Best!
Old 02-01-2013, 04:18 PM   #73370
Obard
Oddometer: 26
Thanks, that is some peace of mind. I just did a valve adjustment on it, but am uncertain about my competency in this department. Lack of quality tools, and experience being the biggest factor. How do I know if I did it right or wrong? It rattles and clanks quite a bit up there. Btw, it did the blue smoke thing before I adjusted the valves, so I don't think I made it worse.
Obard screwed with this post 02-01-2013 at 04:21 PM Reason: auto correct again
Old 02-01-2013, 05:16 PM   #73371
imprezagm4
imprezagm4's Avatar
Oddometer: 174
Ok.... so I'm lowering my DR today, did the rear no problem, going to raise the forks in the triple clamp... get everything all loosened up (top and bottom clamp) and they won't budge? Are there any tips and tricks or maybe something I missed?
imprezagm4 is offline   Reply With Quote
Old 02-01-2013, 05:29 PM   #73372
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,923
I wonder if they are binding as the wheel wants to go forward and therefore change the angle of the fork tube/clamps. Did you take the weight off the suspension first, raise the bike?
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 02-01-2013, 05:43 PM   #73373
imprezagm4
imprezagm4's Avatar
Oddometer: 174
All I have is a car floor jack... so to do the rear I just layed the bike on its side. I tried it once again, on the side but still can't move the forks :?
To confirm... there are only 6 bolts requiring removal to loosen them sufficiently... correct? 4 for the lower clamp and two for the top?
Old 02-01-2013, 05:47 PM   #73374
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,165
Yeah that's it. I suggest getting the front end in the air and removing the front wheel. It's MUCH easier than trying to do with the wheel on it.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 02-01-2013, 05:51 PM   #73375
Adv Grifter
Oddometer: 6,128
Sounds like you got the valves wrong ... you may need to go round one more full rotation and back on your timing mark to get valves in correct position for adjustment. If set right ... they don't rattle very much.
Mis-adjusted valves won't affect your valve guides. About four hours shop labor to rebuild the head if you chose. If me, I'd just roll with it. You're nick name will be "Smokey Joe".
Find someone to help you set the valves. It's quite simple once you know the drill.
Old 02-01-2013, 05:57 PM   #73376
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,165
I hate wiring.
So today I finally decide to go for a short ride on my DR650. I get geared up and head west, figuring I'm gonna see if there are some dirt roads southwest of Dallas (Oregon). I get two miles down the road and notice my right-side LED driving light is hanging by its cord. WTF? I thought I lost the bolt. Nope, the bracket is broken! Crap. So I double back home.
The little brackets from ProCycle for these lights have broken. The other side was just about ready to break. So I go inside and look through my parts bins. I come back out with two longer bolts and two 3/4" long nylon spacers, and replace the lower bolt in the lower triple with the new bolt and the spacer, to force the light out far enough so I can retain the reflector bracket. Takes ten minutes and it's all back together.
I test the lights. They come on... flicker, then go off. WTF? No "off" light on the switch. Grrr. Pull the side panels and seat off and try to remember what the heck the fuse block for the lights looks like. After pulling the tank and tracing the wires, I find it. Fuse is fine. Pull fuse, examine, replace. Lights work. Cool, so I reassemble.
Once back together, I test again. Lights no work. AUGH. Pull side panel and go back to fuse. Pulling/replacing doesn't work this time. Fine, be that way. Came inside in disgust. Tomorrow, everything comes apart again and I'm ripping the fancy wiring/relay crap out that the lights came with (the Denali lights from Twisted Throttle) and I'm going to wire them up the regular way like I did on my KLX250S and use a conventional toggle switch instead of that silly pushbutton thing. Simple is good.
While looking at the wiring mess, I've decided that when I do gut the thing next Winter to powdercoat the purple frame, I'm going to redo ALL the wiring and install a standard fuse block and relay block, both accessible from the side covers, and everything will be labelled. That way, the seat can stay on most of the time. At least that's the plan. :)
So yeah.. now instead of riding tomorrow, I get to deal with wiring crap.
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Old 02-01-2013, 06:27 PM   #73377
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 3,257
Did you loosen the clamp at the top of the fork boot?
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 02-01-2013, 06:28 PM   #73378
procycle
procycle's Avatar
Oddometer: 2,277
Sometimes the rubber grommets in the headlight bracket stick to the tubes. A little WD40 might help.
Some bikes just have tight bores in the triple clamps. A little something wedged into the gap to spread the clamp might do the trick.
procycle screwed with this post 02-01-2013 at 07:59 PM
Old 02-01-2013, 06:57 PM   #73379
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,629
nice call.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins is online now   Reply With Quote
Old 02-01-2013, 07:28 PM   #73380
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 678
Check the shop manual, there is a better way to lower the forks by swapping the internal fork spacers around than raising them in the trees.
Carl Childers is online now   Reply With Quote
Times are GMT -7.   It's 10:07 PM.
