02-01-2013, 04:12 PM
#6841 |
Procrastinators
Oddometer: 5,790
I upgraded to 4.70 using Garmin Express and it worked just fine. The only thing I've found so far is that all the maps were enabled on the profile which was active when I upgraded, but I found nothing else to complain about in the 5 minutes I've had to check it out.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
02-01-2013, 04:47 PM
#6842 | |
What?!!!
Oddometer: 233
I still get the occasional white screen. Otherwise, it seems to be working ok. Damn!!! I just got it out to check what Atlas said about USB mass storage and when I started it up, I got that white screen!!
I'm still hot... it just comes in flashes now.
02-01-2013, 06:40 PM
#6843 |
Procrastinators
Oddometer: 5,790
Have you tried JaVaWa Device Manager on that gps to see if it finds any problems with it?
02-01-2013, 06:42 PM
#6844 |
What?!!!
Oddometer: 233
Not yet. I downloaded it earlier today. I'll install it tomorrow and see what shakes out.
02-01-2013, 06:43 PM
#6845 |
Procrastinators
Oddometer: 5,790
I don't think a serial number list was ever circulated, but I doubt there would still be unsold old stock. Garmin actually stopped production and quit shipping units while they sorted out the issue.
02-01-2013, 07:07 PM
#6846 |
Oddometer: 196
02-01-2013, 07:12 PM
#6847 |
Procrastinators
Oddometer: 5,790
Yes, I have 2013.30 on my Montana. I reported it to Garmin but have not had anything back from them on it.
02-01-2013, 08:57 PM
#6848 | |
Kool Aid poisoner
Oddometer: 4,827
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
02-02-2013, 03:34 PM
#6849 | |
Oddometer: 196
![]() Here's another post from the BaseCamp forum, including response from a Developer. Shaping points on Montana 600 Hi, |
02-02-2013, 10:58 PM
#6850 |
Birdseye imagery for Thailand
One of the reasons I bought the Montana was because it has the ability to use "custom maps". My idea was that in certain areas in Thailand where no roads appear on the OSM maps I could use the Google Earth images as a guide, driving them with a GPS and then adding those roads to the OSM map later. However, after playing around with this approach for a few days and suffering through the frustrating tedium of correctly geolocating those images I began to reevaluate the idea of using Birdseye imagery for my map making efforts.
I've read quite a bit of the info about Garmin Birdseye imagery and have not been impressed. The customer comments on Amazon are very negative and what I've been able to ferret out in here and on other forums is far from positive. The money isn't the concern -- $30 a year is peanuts for a good mapping alternative to the GE images. But if the imagery is indeed inferior or out of date as many reviewers say, I don't want to waste my time on it. Do any of you have experience with Birdseye positive or negative you'd care to share? And more specifically, have any of you have tried the images for Thailand or SE Asia? |
02-03-2013, 04:56 AM
#6851 |
Procrastinators
Oddometer: 5,790
This isn't really a Montana subject, but Lost Rider seems to love Birdseye. I'm looking for a post of his where he describes using it. Not in Thailand or SE Asia, though.
02-03-2013, 07:54 AM
#6852 | |
Oddometer: 1,562
Yes. Yes. Try 250. daryl dlh62c screwed with this post 02-03-2013 at 08:02 AM |
02-03-2013, 09:40 AM
#6853 |
Oddometer: 193
So I am pretty set on getting a Montana for my first gps... Seems like a solid choice.
1989 KLR 650 |
02-03-2013, 09:45 AM
#6854 |
OX Ambassador
Oddometer: 415
I have nearly a dozen GPSr..... I use my Montana every day!
02-03-2013, 10:32 AM
#6855 |
Oddometer: 79
50 (Shaping/Via) Point Limits on the Montana
All the discussions about 50 (via/shaping) point limits prompted me to perform a few tests of my own. The tests confirmed much of what has recently been discussed here, and my understanding about some of the limitations of the Montana.
In BaseCamp, I created a 30 point (30 via points, according to the route property window) direct profile route. I duplicated the route and converted it to automobile profile routing (so I could see how BaseCamp calculates the actual routing on roads (versus the straight lines shown between the direct routing points). I then transferred the 30 point direct route to the Montana. As expected, when loaded via the "Where To" menu, the route initially displayed as the direct route, while the Montana re-calculates the route, and then displays the route on the roadways, using the via points that I defined. The route calculated by the Montana matched the BaseCamp calculated automobile profile route (same map set loaded on both BaseCamp and the Montana!). I repeated the process, but this time using an 80 (via) point route using BaseCamp (as shown by the route's properties window) and set to use direct profile routing. I duplicated the route in BaseCamp and converted the duplicate to automobile profile routing, again so I could see how the route would display on actual roads. I also converted the 80 point automobile profile route into a track. I transferred the 80 point direct route, the 80 point automobile route, and the 80 point track to the Montana. When the 80 point direct route was initially selected using the "Where To" menu, it initially displayed all 80 points and all the direct line segments between those 80 points (along with the "Go" button). Immediately selecting the "Go" button resulted in a message being shown that states "Only 50 points can be used for follow road navigation." If the "Go" button was left unselected, after the Montana completed calculating the route, the route along the roadways was displayed, but was truncated (did not display) any of the segments after the 51st via point. The route's description box provided the correct length of the route up until the 51st via point (compared to the length of that route as calculated by BaseCamp). When the 80 point automobile profile route was selected using the "Where To" menu, it displayed the full route with direct routing segments, but the "Go" button never appears. Clearly the Montana cannot re-calculate the full route for a non-direct profile route when that route exceeds 51 via points. Next, the track that was generated from the 80 point automobile profile was loaded via the "Where To" menu. As expected, the entire track displayed properly (along the actual roadways) and selecting the "Go" button began navigation using the track. To summarize, direct profile routes exceeding 51 points (which on the Montana includes via points, waypoints, and points of interest) can be used when transferred to the Montana, but these routes will be truncated to use only the first 51 points. Non-direct routes (for example, routes created using the automobile profile) which exceed 51 points in length cannot be used by the Montana for navigation. Routes created in BaseCamp using a non-direct profile (for example, the automobile profile), that exceed 50 points in length, can be converted to tracks and those tracks can be loaded to and used by the Montana for navigation, albeit without the turn-by-turn direction provided by routes. (From a programming standpoint, I assume the via points are loaded into an array that begins with a base value of zero and has a maximum value of 50, resulting in 51 location values being used for the route calculation). My apologies for the long-winded discussion, but I hope this explanation will be of some value to our newer Montana owners, or to those still trying to make a decision on whether to purchase a Montana. Bill Murray screwed with this post 02-03-2013 at 04:20 PM Reason: typo fix |
