02-01-2013, 04:29 PM
#73531 |
Asperger
Oddometer: 2,038
I wonder if they are binding as the wheel wants to go forward and therefore change the angle of the fork tube/clamps. Did you take the weight off the suspension first, raise the bike?
http://breakingbooks.wordpress.com http://www.kenmarshallmetalworks.com/ 2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco. |
02-01-2013, 04:43 PM
#73532 |
Oddometer: 49
All I have is a car floor jack... so to do the rear I just layed the bike on its side. I tried it once again, on the side but still can't move the forks :?
To confirm... there are only 6 bolts requiring removal to loosen them sufficiently... correct? 4 for the lower clamp and two for the top? |
02-01-2013, 04:47 PM
#73533 | |
Mostly Harmless
Oddometer: 1,701
Rob
'96 Suzuki DR650, '10 Kawasaki KLX250S, '01 Yamaha FZ1 The Lane Sharing Works Blog | My SPOT Page |
02-01-2013, 04:51 PM
#73534 | |
on the road o'dreams
Oddometer: 5,373
Mis-adjusted valves won't affect your valve guides. About four hours shop labor to rebuild the head if you chose. If me, I'd just roll with it. You're nick name will be "Smokey Joe". Find someone to help you set the valves. It's quite simple once you know the drill.
02-01-2013, 04:57 PM
#73535 |
Mostly Harmless
Oddometer: 1,701
I hate wiring.
So today I finally decide to go for a short ride on my DR650. I get geared up and head west, figuring I'm gonna see if there are some dirt roads southwest of Dallas (Oregon). I get two miles down the road and notice my right-side LED driving light is hanging by its cord. WTF? I thought I lost the bolt. Nope, the bracket is broken! Crap. So I double back home.
The little brackets from ProCycle for these lights have broken. The other side was just about ready to break. So I go inside and look through my parts bins. I come back out with two longer bolts and two 3/4" long nylon spacers, and replace the lower bolt in the lower triple with the new bolt and the spacer, to force the light out far enough so I can retain the reflector bracket. Takes ten minutes and it's all back together. I test the lights. They come on... flicker, then go off. WTF? No "off" light on the switch. Grrr. Pull the side panels and seat off and try to remember what the heck the fuse block for the lights looks like. After pulling the tank and tracing the wires, I find it. Fuse is fine. Pull fuse, examine, replace. Lights work. Cool, so I reassemble. Once back together, I test again. Lights no work. AUGH. Pull side panel and go back to fuse. Pulling/replacing doesn't work this time. Fine, be that way. Came inside in disgust. Tomorrow, everything comes apart again and I'm ripping the fancy wiring/relay crap out that the lights came with (the Denali lights from Twisted Throttle) and I'm going to wire them up the regular way like I did on my KLX250S and use a conventional toggle switch instead of that silly pushbutton thing. Simple is good. While looking at the wiring mess, I've decided that when I do gut the thing next Winter to powdercoat the purple frame, I'm going to redo ALL the wiring and install a standard fuse block and relay block, both accessible from the side covers, and everything will be labelled. That way, the seat can stay on most of the time. At least that's the plan. :) So yeah.. now instead of riding tomorrow, I get to deal with wiring crap. Rob
02-01-2013, 05:27 PM
#73536 |
867-5309
Oddometer: 2,528
Did you loosen the clamp at the top of the fork boot?
DO WHAT YOU LIKE - LIKE WHAT YOU DO Explain to me again why enjoying life when I retire is more important than enjoying life now? |
02-01-2013, 05:28 PM
#73537 | |
Oddometer: 1,597
Some bikes just have tight bores in the triple clamps. A little something wedged into the gap to spread the clamp might do the trick.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup procycle screwed with this post 02-01-2013 at 06:59 PM |
02-01-2013, 05:57 PM
#73538 |
Butler Maps
Oddometer: 14,421
nice call.
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
02-01-2013, 06:28 PM
#73539 |
Oddometer: 80
Check the shop manual, there is a better way to lower the forks by swapping the internal fork spacers around than raising them in the trees.
02-01-2013, 07:34 PM
#73540 |
Old Traveler
Oddometer: 463
+1
TRAVELGUY DL1000 '05 black DL 650 '07 ( lives in Costa Rica ) DR 650 "08 .
02-01-2013, 08:12 PM
#73541 | |
Armature speller
Oddometer: 6,763
02-01-2013, 08:23 PM
#73542 |
Oddometer: 148
Quote:- So yeah.. now instead of riding tomorrow, I get to deal with wiring crap.
Thats a bummer
02-01-2013, 08:45 PM
#73543 |
Oddometer: 2,535
BTDT
02-01-2013, 08:57 PM
#73544 | |
Oddometer: 26
02-01-2013, 09:41 PM
#73545 |
Oddometer: 2,535
After cleaning out the recess around the spark plugs thoroughly, remove the outer plug. Stick a straw into the hole, rotate the engine slowly (ccw) while wiggling the straw so it doesn't bind on the piston as it rises in the bore. At this TDC, wiggle the rocker arms (side to side, as you're unlikely to feel the small valve clearance with the oil cushioning it), if they're loose that's the TDC you want. Rotate the engine another 360* (straw at full extension again) and wiggle the rocker arms again, they should not wiggle, this is the wrong TDC. Do this two or three times until you're sure when the rockers are tight and when they're loose. Adjust the valves when both rockers are loose. Exact TDC (mark in the window), isn't necessary, as the valves are closed for many degrees on both sides of TDC.
Once you feel it, you're set for life. You can use a pencil instead of a straw, just remember to wiggle it as the piston rises or it might bind and break. Something flexible is safer, like a straw.
