Old 02-01-2013, 07:34 PM   #73381
TRAVELGUY
Old Traveler
Oddometer: 663
+1
Originally Posted by carl childers View Post
check the shop manual, there is a better way to lower the forks by swapping the internal fork spacers around than raising them in the trees.
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 02-01-2013, 08:12 PM   #73382
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,140
Originally Posted by acesandeights View Post
The lowering of the rear also includes "flipping" the spring seat. Using an aftermarket spring may require using an aftermarket spring seat, which mine did. The aftermarket part does not offer the ability to "flip" it, so it won't lower the rear as much as you can with the stock spring and spring seat. The forks were lowered by putting the spacer under.
The flipping only limits the travel. It doesn't affect the height at all.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 02-01-2013, 08:23 PM   #73383
Magnum Noel
Magnum Noel's Avatar
Oddometer: 188
Quote:- So yeah.. now instead of riding tomorrow, I get to deal with wiring crap.
Thats a bummer
Magnum Noel is offline   Reply With Quote
Old 02-01-2013, 08:45 PM   #73384
ER70S-2
ER70S-2's Avatar
Oddometer: 6,661
Originally Posted by trailrider383 View Post
Did you loosen the clamp at the top of the fork boot?
Originally Posted by eakins View Post
nice call.
BTDT
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 02-01-2013, 08:57 PM   #73385
Obard
Oddometer: 26
Originally Posted by Adv Grifter View Post
Sounds like you got the valves wrong ... you may need to go round one more full rotation and back on your timing mark to get valves in correct position for adjustment. If set right ... they don't rattle very much.
Mis-adjusted valves won't affect your valve guides. About four hours shop labor to rebuild the head if you chose. If me, I'd just roll with it. You're nick name will be "Smokey Joe".
Ok, so putting the timing mark in the center of the inspection hole isn't exactly enough, right? I think what I am missing, is ensuring that it's tdc on the compression stroke. Please pardon my lack of knowledge, but, how do I know if it's the compression stroke?
Obard is offline   Reply With Quote
Old 02-01-2013, 09:41 PM   #73386
ER70S-2
ER70S-2's Avatar
Oddometer: 6,661
After cleaning out the recess around the spark plugs thoroughly, remove the outer plug. Stick a straw into the hole, rotate the engine slowly (ccw) while wiggling the straw so it doesn't bind on the piston as it rises in the bore. At this TDC, wiggle the rocker arms (side to side, as you're unlikely to feel the small valve clearance with the oil cushioning it), if they're loose that's the TDC you want. Rotate the engine another 360* (straw at full extension again) and wiggle the rocker arms again, they should not wiggle, this is the wrong TDC. Do this two or three times until you're sure when the rockers are tight and when they're loose. Adjust the valves when both rockers are loose. Exact TDC (mark in the window), isn't necessary, as the valves are closed for many degrees on both sides of TDC.
Once you feel it, you're set for life. You can use a pencil instead of a straw, just remember to wiggle it as the piston rises or it might bind and break. Something flexible is safer, like a straw.
2013 WR250R
Old 02-01-2013, 11:21 PM   #73387
nzrian
nzrian's Avatar
Oddometer: 329
Originally Posted by planemanx15 View Post
Bit the bullet today and bought my 790 kit!! Going to change out the clutch while I'm in there and check the NSU. I will post a thread\tutorial on here for anybody that is thinking about doing it.
i would be keen on a thread for this.
good luck with it.
If you don't know where you are going, any road will get you there.
-Lewis Carroll.
nzrian is offline   Reply With Quote
Old 02-02-2013, 12:49 AM   #73388
BergDonk
BergDonk's Avatar
Oddometer: 3,681
Here is how I do it, FWIW:
http://www.advrider.com/forums/showp...&postcount=371
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 02-02-2013, 05:37 AM   #73389
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,678
The rockers will feel slightly loose at TDC. You should have a very small amount of play. If they are tight, your not on TDC.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 02-02-2013, 07:33 AM   #73390
Obard
Oddometer: 26
Well I'm going to give it hell today. Thanks for all the helpful hints. Good news is I'm getting really quick at taking everything off and on. I've been trying to get these darn valves adjusted for months now. I think I'm getting close with last bit of info here on locating tdc(c).
Old 02-02-2013, 07:44 AM   #73391
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,652
Even better, with more familiarity you can consider tackling the blue smoke issue. It's probably nothing more then the valve seals which are cheap, but you will need a valve compressor tool which can be bought for less then $50. So for less then $100 you could fix the problem.
Old 02-02-2013, 07:45 AM   #73392
imprezagm4
imprezagm4's Avatar
Oddometer: 195
Got it done yesterday evening. Just had to slide the boot down to get a better grip. It really helped having the weight off the front wheel but it wasn't fun wrestling the beast to the ground...
I'm definitely aware I didn't do it the way the manual says, now that I know how to do it, I can reverse it in a few minutes... so we will see how it goes.
Thanks for all the tips
imprezagm4 is offline   Reply With Quote
Old 02-02-2013, 08:31 AM   #73393
Obard
Oddometer: 26
Do I have to yank the engine out to work on the valve seals? Nevermind don't tell me yet, we'll get there soon as I get the valves adjusted right.
Old 02-02-2013, 08:46 AM   #73394
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,964
The manual says it shortens the overall length, not just the travel. So you get 1.6" of ride height difference just between the two holes? The two holes are only about 5/8" apart. So, where's the other 1" come from? Not arguing here, just trying to learn. Holding the parts in my hands and looking at them, it looks like you'd limit travel and length by flipping the spring seat.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is online now   Reply With Quote
Old 02-02-2013, 09:25 AM   #73395
procycle
procycle's Avatar
Oddometer: 2,367
The amount it's lowered is measured at the rear axle so the length of the swingarm is where most of the additional inch comes from. Also there is the geometry of the shock linkage.
Flipping the stock spring seat only limits the travel but does also move the location of the spring on the shock body.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Times are GMT -7.   It's 06:53 PM.
