Go Back   ADVrider > Riding > Regional Forums > Australia
Old 01-29-2013, 01:57 AM   #4036
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,762
Originally Posted by digga1111 View Post
without trying to start a tyre war, try an mx71 up front. better spread of tread then the 952. dont bounce as much on tar and will carry load at 14psi
Will it headshake on this bike tho the lack of bounce you stated may be ok - the only front ive had that won'rt is the 952 for some reason - but i had the mx 51 on the 450 and great tyre - and the 952 does catch the sides of ruts or more to the point slip off sides of ruts
But the fact that some geniuses were laughed at does not imply that all who are laughed at are geniuses. They laughed at Columbus, they laughed at Fulton, they laughed at the Wright Brothers. But they also laughed at Bozo the Clown.
Carl Sagan
Beer'o'clock Baz screwed with this post 01-29-2013 at 02:07 AM
Beer'o'clock Baz is offline   Reply With Quote
Old 01-29-2013, 09:37 AM   #4037
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,803
Kenda trakmaster II's are a good cheap tire that work well on the bike too.
Seth S
Seth S is offline   Reply With Quote
Old 01-29-2013, 01:25 PM   #4038
LC4nicator
Certified Wino
LC4nicator's Avatar
Oddometer: 522
Brilliant rear tyre.....DOT approved as well....never tried the fronts though.
Really took everything I could give it on the 525..... in deep sand, Rocky hardpacked tracks & not too bad on the bitumen as well.
Rocky Mountain won't ship them any more......and I've been searching for a replacement ever since!
Conman62 in the "other world"......dirtbikeworld.net
The beatings will continue untill morale improves!
2006 KTM 525 EXC
2005 KTM 950 ADV
ARIEL MCC of SA
LC4nicator is offline   Reply With Quote
Old 01-29-2013, 03:15 PM   #4039
Beer'o'clock Baz
Oddometer: 1,762
Ride with me
this is whats involved with the offset mod you pmed me about - wait till you think you need to do it first
Carl Sagan
Old 01-29-2013, 06:43 PM   #4040
Sol Erzenberg
Lost somewhere
Sol Erzenberg's Avatar
Oddometer: 1,538
Originally Posted by B2 View Post
Ride with me
Struth..
2009 KTM 690 R
"Thats A Sweet Noise You Got There Man, I Had You Picked Clear Across The Mallee"
2006 KTM 625 SXC
2005 Honda XR400R.
1998 Yamaha DT200.
1981 Maico 490M.
1979 Honda CR125R Elsinore.
1978 Suzuki RM 100.
ARIEL MCC
Sol Erzenberg is offline   Reply With Quote
Old 01-29-2013, 07:44 PM   #4041
Hoots
Hoots's Avatar
Oddometer: 1,650
This is whats involved with the offset mod you pmed me about - wait till you think you need to do it first
What actually is this offset mod ...?
What is it to compensate for ... ?
Hoots is offline   Reply With Quote
Old 01-29-2013, 08:25 PM   #4042
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,137
The 690 has 24 -22.5 chagable offset triple clamp, what this does is moves the fork forward or back on the head stem ,wit
In laymans terms longer and shorter . So can makes it turn in faster or slower .
Mudguts is offline   Reply With Quote
Old 01-29-2013, 08:55 PM   #4043
podge NT
Podge NT
podge NT's Avatar
Oddometer: 2,308
It is normally set in the long position from factory, however there have been cases where they are in the short position, The long setting is the best position for general use, shortening it makes it turn faster therefore better for enduro use.
Anybody who is picking up a new 2013 model check that the new airbox mod has been made.
http://share.findmespot.com/shared/f...1IWs2Hg87TZcsW
Plan, what plan, there is no plan
podge NT is offline   Reply With Quote
Old 01-31-2013, 02:58 AM   #4044
positron007
Oddometer: 66
I am thinking of getting this bike. Probably purchase in the next 4 weeks.
Is there anyone in Melbourne who has this bike that would be willing to let me check it out, and discuss the bike with them?
positron007 is offline   Reply With Quote
Old 01-31-2013, 03:12 AM   #4045
D-Rally
D-Rally's Avatar
Oddometer: 50
Clutch
I've had the clutch go from very little feel to nothing at all (lever comes all the way in). Is this simply a matter of bleeding the clutch or another possible issue?
Finding Time To Ride
D-Rally is offline   Reply With Quote
Old 01-31-2013, 03:25 AM   #4046
positron007
Oddometer: 66
Sounds like air in the lines
Old 01-31-2013, 05:56 AM   #4047
Seth S
Seth S's Avatar
Oddometer: 4,803
start by bleeding the clutch with fresh fluid. If that fixes it but the problem comes back then either the seals in your slave cylinder have failed (common..crummy slaves stock) or your master has failed
Seth S
Old 02-01-2013, 10:38 PM   #4048
Hrspwr Hero
wipe off 50 or.....
Hrspwr Hero's Avatar
Oddometer: 79
Cam follower failure
So my 690 is up for its 7500km service. So I pulled it apart to do valve clearance and other maintenance only to be presented with this. Wtf??? This bike gets pampered with oil changes etc. It would not have gone another 500-1000km before a full blown melt down. Not to mention the pitted cam. Off to see if ktm will foot the bill even though its outta warranty. You can't tell me this is acceptable. What if you we're half way thru a 5000km ride?? Kaboom
Hrspwr Hero is offline   Reply With Quote
Old 02-02-2013, 01:58 PM   #4049
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 2,069
Anyone else had this damage, any info on cause etc
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 02-02-2013, 03:21 PM   #4050
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,273
There are reported cases of it, particularly on the supermoto sites and a mate of mine did have it happen to his as well. His bike was still under warranty so cam and lifter were replaced.
We're guessing it's something to do with the decompression pin on the exhaust cam giving the bearing a good old hammering.
I think the bearing could be replaced with one from a 640 if you're handy or complete rockers from the States aren't badly priced.
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Times are GMT -7.   It's 07:48 AM.
