Old 02-01-2013, 08:45 PM   #3256
Wentjo
Wentjo's Avatar
Oddometer: 419
Originally Posted by boostracer View Post
Thanks for answering my questions, guys. I put the switch on & wow, does it make a difference. Wild is a good description for that position! Way too much fun to ride that way! Must be illegal! Thanks again.
I must have missed something, where did you get the switch? I have a 13 500 EXC.
Wentjo is offline   Reply With Quote
Old 02-02-2013, 01:14 AM   #3257
boostracer
Oddometer: 32
It's the Trail Tech switch, bought it thru my dealer.
boostracer is offline   Reply With Quote
Old 02-02-2013, 06:01 AM   #3258
Wentjo
Wentjo's Avatar
Oddometer: 419
Thanks, I'm going to try one of those.
Old 02-02-2013, 11:01 AM   #3259
boostracer
Oddometer: 32
Remember, it won't work with the stock map, I have the euro map in mine.
boostracer screwed with this post 02-02-2013 at 06:06 PM
Old 02-04-2013, 03:13 PM   #3260
YAHBO
Grip and rip since 1983
YAHBO's Avatar
Oddometer: 804
XC-W map?
Will it work with the XC-W map? I have the XC-W map installed in my '13 EXC.
I'm an asshole and I approve this message.
YAHBO is offline   Reply With Quote
Old 02-04-2013, 04:22 PM   #3261
Stifdickerson2006
Stifdickerson2006's Avatar
Oddometer: 138
Originally Posted by yahbo View Post
will it work with the xc-w map? I have the xc-w map installed in my '13 exc.
yes it will.
No Matter Where You Go, There You Are.
Stifdickerson2006 is offline   Reply With Quote
Old 02-04-2013, 06:02 PM   #3262
bill1960
Oddometer: 361
Nope
http://www.trailtech.net/map_switches.html
and btw, the competition map code shown on TT's site is the old version
new version for the 500 xcw is KM787EU12C0701
bill1960 is offline   Reply With Quote
Old 02-04-2013, 08:32 PM   #3263
RSinBC
Oddometer: 249
Which Map?
Originally Posted by bill1960 View Post
Nope
I have been through this thread front to back a bazzillion times, it seems there is new/conflicting info on the re-mapping of the EXC ECU's.
I am going to get my EXC reflashed and have been trying to get the correct info on the "proper" map to use.
It looks like the unrestricted EU or AUS map is the one to load.
There have been conflicting stories on the correct version to use. I understood the KM787EU12C0601 was the program to use IF using the stock exhaust, and the KM787EU12C0701 program was the one to use if using an AKRO or FMF exhaust.
Can someone chime in if both will allow the use of the map switch and if the difference is in the fueling for the exhausts, or is the 701 the only option if you want the map switch.
At this point I plan to keep the stock exhaust on the bike, I may install the map switch if the tune will allow it, but i mostly want the tune the XC-W has and will work with the stock exhaust.
Thanks for clarifying.
Richard
RSinBC is offline   Reply With Quote
Old 02-04-2013, 09:27 PM   #3264
bill1960
Oddometer: 361
Richard
You might find the answers you're looking for in the following thread
http://ktmtalk.com/index.php?showtopic=463906&st=0
Old 02-04-2013, 10:26 PM   #3265
RSinBC
Oddometer: 249
Mapping
It seems the KM787EU12C0601has been superseded by the KM787EU12C0701Map and the switch will work.
I will find out when i go to get the re-flash done.
Old 02-04-2013, 11:11 PM   #3266
boostracer
Oddometer: 32
The 701 was installed on mine.
Old 02-05-2013, 08:46 AM   #3267
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,597
Well the bike did great in the wet this past weekend - rider just ok . Looks like the right side air box took in the most water and random swamp crap. Not enuff to bog it down but back at camp I pulled the cover and noticed where it collected.
Swamp tatcis - skirting the sides to avoid the deep spots . Every hole has a deep section - In this pix it looks like I just pulled out of it.
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 02-05-2013, 02:01 PM   #3268
RSinBC
Oddometer: 249
701 map
Are you still using the stock exhaust on the bike? How do you like the way it runs with this map?
Old 02-05-2013, 02:26 PM   #3269
SoilSampleDave
Oddometer: 1,979
Also, probably good to know whether the little perforated disc near the outlet of the muffler has been removed. The stock muffler flows really well with it removed.
Don't drive like my brother!
"Comparison is the thief of joy" - TR (the good Roosevelt)
'14 690R
SoilSampleDave is online now   Reply With Quote
Old 02-05-2013, 02:31 PM   #3270
AussieClay
AussieClay's Avatar
Oddometer: 59
Maps
'0701 EU map installed with stock exhaust, JD tuner, desmogged and map switch. Works fine. Have had several maps installed. Hardly noticeable difference between any of the unrestricted maps. Only reason I went for the EU map is to allow the switch to work.... do notice the difference but I think it's over rated... you'll be significantly happier with any of the unrestricted maps over the original crap that is loaded on there.
AussieClay is offline   Reply With Quote
Times are GMT -7.   It's 06:32 AM.
