Old 01-30-2013, 11:58 AM   #1
1224R OP
Oddometer: 2,117
Hard wiring a 60csx ??????
Ok I have a 60csx.
Got the power cord cigarette plug deal
Want to power it to battery just run it to the battery with a female plug wired to battery and plug in riiiiight???
Can I cut the male end off and go right to batt??
It sounds silly to ask as I would just do it but just want to make sure....
Thx...
I thought YOU had the map......
1224R is offline   Reply With Quote
Old 01-30-2013, 01:00 PM   #2
250senuf
250senuf's Avatar
Oddometer: 2,427
The answers/options are here. Different unit with the same power connector.
http://www.advrider.com/forums/showthread.php?t=859002
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 01-30-2013, 01:23 PM   #3
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 869
Originally Posted by 1224R View Post
Ok I have a 60csx.
Thx...
Why not save that one and use it in your car for practice and buy a wire off -ebay?
But to answer your question : Yes, I hardwired mine to the battery with a 2 amp fuse in line
Twist your own throttle
FlyingDutchman is offline   Reply With Quote
Old 01-30-2013, 03:04 PM   #4
mcnut
Oddometer: 1,383
Disclaimer; I'm full of it, use the info at your own risk!
The 60Cx has 2 power connector options, the mini USB and the big round plug. The mini USB has a step-down transformer in-line, sometimes in the male cig plug in which case cutting it off and wiring to the battery will fry the GPS.
The round plug if memory serves can input up to 36V DC and can be wired directly into 12V DC.
Bruce
mcnut is offline   Reply With Quote
Old 01-30-2013, 09:44 PM   #5
Countdown
Oddometer: 5,793
The round plug if memory serves can input up to 36V DC and can be wired directly into 12V DC. Bruce
Disclaimer was very wise. Step-down transformer for DC is a very new invention and not yet written up in the text books, so I am not familiar with it.
There are several ways to get 5 Vdc from 12Vdc but none of them are good in the vibration & wet of a motorcycle and the USB plug is a hand granade on a motorcycle.
Only real choice is:
http://www.cycoactive.com/Store/2473...-176C-60-76-78
Jerry Counts
Countdown is offline   Reply With Quote
Old 01-31-2013, 08:18 AM   #6
wbbnm
wbbnm's Avatar
Oddometer: 2,282
I ran my 60cx directly off the battery of two bikes, a KLR and a KTM 450. I just tapped into a wire coming from the battery up near the headlight and into a ground wire. I cut the cigarette lighter connector off the wires to the round connector to the GPS unit and put SAE two conductor connectors on each end.
I still use that setup with my Montana.
I also use the same connector to charge the battery.
wbbnm is online now   Reply With Quote
Old 02-02-2013, 05:49 AM   #7
1224R OP
Oddometer: 2,117
So just cut the cig adapter off and wire to battery not the USB one the round plug one and I'm gold riiiiight???
Old 02-02-2013, 07:41 AM   #8
wbbnm
wbbnm's Avatar
Oddometer: 2,282
In a word yes. At least that is what I would recommend. I never tried it, but I have heard of a lot of people having problems trying to use the USB power port. These were on units that did not have the round connector.
Old 02-02-2013, 07:44 AM   #9
KG6BWS
KG6BWS's Avatar
Oddometer: 895
Use the round plug. Cut off the cig adapter, or like someone else said save it for your car and buy a bare end cable, and put a 2 amp fuse inline. Works like a charm. Mines been that way for 5 years. I also have a hard wired cable in my truck, wired up the same way.
"But I swear, a woman's breast is the hardest rock that the Almighty ever made on this earth, and I can find no sign on it." Bear Claw Chris Lapp
Justin
01 F650GS Dakar
KG6BWS is offline   Reply With Quote
Old 02-02-2013, 08:26 AM   #10
DragonNester
DragonNester's Avatar
Oddometer: 464
I cut the opposite end off the round four pin connecter and put on an SAE plug so as to use it with the fused battery tender connecter I already had running from the battery. No problems!
Happiness is wanting what you get.
DragonNester is offline   Reply With Quote
Old 02-02-2013, 08:39 AM   #11
1224R OP
Oddometer: 2,117
Awesome!! Thank you guys!!!!
HTML code is Off
Times are GMT -7.   It's 07:19 AM.
