Old 02-02-2013, 10:40 AM   #73396
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,925
So, if you don't flip the spring seat, only move the bolt from the bottom to top hole in the clevis, the result is the same amount of lowering, 1.6" ?
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is online now   Reply With Quote
Old 02-02-2013, 11:07 AM   #73397
procycle
procycle's Avatar
Oddometer: 2,280
Yes, same amount of lowering.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 02-02-2013, 11:11 AM   #73398
acesandeights
Asperger
Oddometer: 3,925
Thanks.
Old 02-02-2013, 11:22 AM   #73399
Rumlover
Ed
Oddometer: 707
Yes, like Procycle said the lowering is the same regardless if you flip the spring seat or not. But you will risk the tire hitting the fender (or possibly other components hitting) if you don't limit the travel by flipping the spring seat which raises the bump stop to limit shock travel.
Remember the spring has to also be moved up the shock body (per the manual) when you flip the spring seat.
Personally (although I haven't done any measurements) I think the prelaod settings Suzuki states in the manual also play into their 1.6" claim. In other words you would have to adjust to their lowest preload setting to achieve the maximum height reduction.
Rumlover screwed with this post 02-02-2013 at 11:36 AM
Rumlover is offline   Reply With Quote
Old 02-02-2013, 11:48 AM   #73400
martinfishlog
martinfishlog
Oddometer: 24
New running lights
martinfishlog is offline   Reply With Quote
Old 02-02-2013, 12:04 PM   #73401
acesandeights
Asperger
Oddometer: 3,925
Originally Posted by Rumlover View Post
...Personally (although I haven't done any measurements) I think the prelaod settings Suzuki states in the manual also play into their 1.6" claim. In other words you would have to adjust to their lowest preload setting to achieve the maximum height reduction.
They do.
Old 02-02-2013, 02:52 PM   #73402
Obard
Oddometer: 26
My time as a shade tree mechanic comes to an end
Went out this afternoon to give it hell, and finish the valve adjustment I've been trying to complete for months. Well ... I figured out what the clanging and rattling was. The bike swallowed the lock nut and the adjusting screw off of the rocker arm. Now all I have to do is load up the bike and get it over to the bike shop down the road. Live and learn ... The hard way.
Awe who am I kidding, I'm to cheap to take it anywhere, guess I'll see what the engine inards look like. Hope ya'll don't mind the onslaught of questions I'm likely to be asking.
Obard screwed with this post 02-02-2013 at 04:36 PM Reason: Added last paragraph
Obard is offline   Reply With Quote
Old 02-02-2013, 02:54 PM   #73403
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,428
Ouch, did that with my old 1150 GS years ago. Never did find the nut.
Albie is offline   Reply With Quote
Old 02-02-2013, 06:22 PM   #73404
ER70S-2
ER70S-2's Avatar
Oddometer: 6,292
Originally Posted by BergDonk View Post
I was hoping you'd post that link. It shows how wide the adjustment angle tolerance is on the cam, instead of struggling to find the 'T' in the window: 'one straw please'. And that you don't have to remove either of the two seized inspection plugs in the stator cover. You could put it in Krusty's DR index.
http://www.advrider.com/forums/showthread.php?t=636386
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 02-02-2013, 08:44 PM   #73405
Northyork
Oddometer: 271
DR650 Safari tank, Corbin, maier handguards, GSXR can and more
I am re-posting this since my original post was deleted because i forgot to add prices, my second post was deleted due to forbidden links to Kijiji.
http://www.advrider.com/forums/showt...8#post20637388
Northyork is offline   Reply With Quote
Old 02-02-2013, 10:03 PM   #73406
ER70S-2
ER70S-2's Avatar
Oddometer: 6,292
Sorry to hear about the findings. Folks will be glad to answer your questions. Learn how to post pics; everybody loves pics.
Originally Posted by Northyork View Post
Hi, I have sold my DR650, moving on to a KTM 990 Adventure. DR650 is a great bike, it gave me lots of satisfactions, but it was time to try something new. Anyhow I have a whole bunch of accessories for sale.
Sorry to see you go, I hope the KTM treats you well.
2013 WR250R
Old 02-02-2013, 10:31 PM   #73407
BadDogMax
Oddometer: 160
Question Blew a fork seal!
Was hauling my bike ... and when I went to unload I saw fork oil leaking all over the truck bed!
I had no evidence of leaking or seeping before this.
I've never had one fail this way. In the past when seals failed, there was always increasing seeping and dripping on the garage floor.
Can I just refill the shock oil to the proper level? Or is my seal ruined and I have to replace it?
2007 Suzuki DR650
BadDogMax screwed with this post 02-02-2013 at 10:37 PM
BadDogMax is offline   Reply With Quote
Old 02-02-2013, 10:50 PM   #73408
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,647
jeff ???
Originally Posted by eakins View Post
Hey Jeff - ProCycle,
Do you offer shorter or have found shorter fork boots that compensate when using a fork brace? The stock boots have to be pushed up a good bit to sit above the fork brace. Do your aftermarket fork boots fit better with a fork brace?
Thanks Bill
ps if you can find the supplier for this cap http://www.vstroma.com/oilfillercap.htm it fits the DR perfectly (the exact same cap used on the DR & Vstrom. i compared when i owned both bikes at the same time) and this cap is a great security cap for RTW travelers. have it on my bike - see pic below.
here are the pricier options:
http://www.touratech-usa.com/Store/1...rom-DL650-1000
http://www.touratech-usa.com/Store/P...rom-DL650-1000
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 02-02-2013, 10:53 PM   #73409
shaddix
Oddometer: 647
OMG
So I replaced the wiring harness by myself in like an hour and a half AND IT RUNS. I'm going to put all the little wire ties and put everything back on tomorrow and it will take me another 45 minutes or so so maybe 3 hours tops total. And that dealer quoted me 1300 dollars, said I needed new keys, ignition, battery. I will quote them "the more wires we pulled the more it was burned up and it's burned all the way to the ignition".
What the fuck!! Why would people try to literally fuck you like that? I can't believe how naive I was, I will never go to a fucking dealer service department again. Ugh that makes me sick. I am pissed that I paid them the 200 to tow it to their shop and diagnose it. I'm going to go back and tell them I want the 100 bucks back for diagnosing it because they failed in that task by telling me all this other shit was fucked up when it wasn't. Mother fuckers. I hope I put that shit on my american express. I am pretty sure I did. Those fuckers.
shaddix is offline   Reply With Quote
Old 02-03-2013, 01:31 AM   #73410
BergDonk
BergDonk's Avatar
Oddometer: 3,488
Done
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is online now   Reply With Quote
Times are GMT -7.   It's 05:23 PM.
