Old 06-04-2012, 11:45 PM   #166
cynicwanderer
cynicwanderer's Avatar
Oddometer: 555
Originally Posted by Bultaco206 View Post
Here's my '83. Bought this in a box and did a full resto into a vintage GP racebike a few years ago. It's my favorite bike and in the woods, it's competitive against the modern stuff.
nice bike ! I started racing my '84 in local Enduros and while I'm not very good/fast, I have no problems in technical tight stuff and rocky/rootie hill climbs, against more modern bikes. What tires do you use ?
cynicwanderer is offline   Reply With Quote
Old 06-04-2012, 11:47 PM   #167
cynicwanderer
Oddometer: 555
Originally Posted by error cooled View Post
Gents --
I wiped out and ruined my beloved OEM Enduro Computer. This was the stock speedo on 85/86 XR600Rs and 85 XR350R. Does any one have a good unit that they would be willing to part with?
I would love you forever and ever
Let me know...
It looks like this....
I believe these and parts are still available from Honda [for a small ransom]. I would be heartbroke if I broke mine, too.
Old 06-05-2012, 04:38 AM   #168
Bultaco206
Back-to-back motos suck
Bultaco206's Avatar
Oddometer: 2,414
It's rough with a 17" rear, but I've had good results with IRC Volcanduros.
'07 DL650, '06 KLX351, '97 DR350, '83 XR350R (vintage GP racer), '74 Bultaco Alpina (trials)
Bultaco206 is offline   Reply With Quote
Old 06-05-2012, 08:47 PM   #169
cynicwanderer
Oddometer: 555
yes, that's what I run on the rear and they seem OK. I haven't tried a Volcanduro on the front, yet.
Old 06-06-2012, 06:20 AM   #170
Bounder
ExternallyDisplaced
Oddometer: 929
Heidenau do a K74 in 17" that might suit?
Bounder is offline   Reply With Quote
Old 06-06-2012, 07:05 AM   #171
RED1
Oddometer: 493
Kenda also have a K760 in 17 which is DOT approved and sorta looks like an old metzler pattern.
RED1 is offline   Reply With Quote
Old 06-06-2012, 10:57 AM   #172
cynicwanderer
Oddometer: 555
I use a dunlop k490 in front, but it only lasts a couple of races before the knobs start tearing off the edges.
Old 06-10-2012, 07:47 AM   #173
stater61
Oddometer: 25
Price too high ?
I found an 83' but I won't get to see it for a few days. He wants $1200 for it. I don't know the market for these old bikes but it seems kind of high to me. Do you guys think its high or about right.
Thanks, JH
stater61 is offline   Reply With Quote
Old 06-10-2012, 08:33 AM   #174
Eurobiker
Vintage Cat Herder
Eurobiker's Avatar
Oddometer: 6,008
Thanks, JH
Too much and I'd hold out for an 85 model. Single carb, dry sump, small displacement bump to 353 cc. If you're dying for one and in the region, I'd part with mine for $1K
For Sale 1998 Triumph Tiger
Eurobiker is offline   Reply With Quote
Old 07-16-2012, 07:11 PM   #175
letank
Oddometer: 47
Thanks, JH
a bit late... but Mark's bike seems good, one carb, dry sump, has kept the engine cooler than the lean adjusted hot running 83-84. If the bike is platted and can be a little more... at least in Kalifornia.... where plated light weight bike brings a small premium....
It all depend on the general shape... tires,chain, which are already $300 worth of parts plus your time.
I blew up the headgasket.... 2nd time... the metal has fatigued and the threads are not holding... upon dismantling I found 2 loose bolts... but I could not torque them past 25ft/lbs, I had to remove the head anyway to change the headgasket that burn and was missing a big chunk. Drilled and put new inserts.... not helicoil... It was holding at 35 (specs are 34-38) Need to finish the install and see if it runs better.
I may play with some jetting.
changed pilot jet from 45 to 48 on the 83, started rather well and 45 to 50 on the 84, started on first kick...results for the trail test later with actual temp.
Michel
83-84 XR350 (the runner and the spare)
letank screwed with this post 07-23-2012 at 03:54 PM
letank is offline   Reply With Quote
Old 01-29-2013, 07:39 PM   #176
MaxxTraxx
MaxxTraxx's Avatar
Oddometer: 17
I just picked up a 85 XL350R. dual carbs and all. I'd have it running, but the fuel joint pipe broke and I am waiting on this part to get in. Any of you guys running a larger than stock tank on your XL?
2007 Harley RoadKing
1990 CR250R
MaxxTraxx is offline   Reply With Quote
Old 01-29-2013, 09:32 PM   #177
cynicwanderer
Oddometer: 555
Clarke has a 4.3gal tank that fits the '85 xl600r/xl350r. I have it on my xl600r and get about 200miles before reserve. the orange/red color is a pretty good match for the frame.
http://www.clarkemfg.com/xl600r-8391...-gal-p-89.html
Old 01-29-2013, 09:51 PM   #178
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,753
I thought 85 was single carb?
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 01-29-2013, 10:15 PM   #179
cynicwanderer
Oddometer: 555
'85 XR350R is single carb, but the '85 XL350R is dual carb.
Old 02-02-2013, 11:51 AM   #180
Pigford
British
Pigford's Avatar
Oddometer: 983
Just put a deposit down for this little baby....... good old eBay
Unlike you lucky lot in the "Land of the Free"... prices for bikes is a bit steeper in the UK..... this import XR350R with 10k miles was the equivalent of about $1400
Anyhow, I loved my old XL500R...
and the 350 is a good replacement
Pigford is offline   Reply With Quote
Times are GMT -7.   It's 10:56 PM.
