Old 01-31-2013, 10:30 PM   #1546
randel
randel's Avatar
Oddometer: 318
I mounted Sanjoh's Model60 leds directly to front fender right before forks using small bolt and washers. Only had to drill small holes through fender to mount them. I'm quite happy with this setup, lights are neatly located both side of the headlight.
950SuperEnduroR
Beyond clouds 2011
Beyond arctic circle 2010
randel is offline   Reply With Quote
Old 02-01-2013, 02:49 PM   #1547
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,079
Afternoon gents
Our running temps sitting on 5 bars here in Mexico when riding about 60 70 km/hr because of traffic, drops back to 4 bars once we hit 90 km/hr or so but takes a while, will add we are riding in 35 deg c about 95 f.
This considered ok?
When we got into Apatzingan it was 40 c and we were idling at lights for 10 - 15 minutes in town, temp got to 6 bars then the fuel pump squirted some gas out looks like from an overflow so I shut her off for a while.
Anyone else had the fuel squirt thing go on?
Now we just turn her off at the lights so she doesn't keep building temperature.
Please let me know on the above, cheers all.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 02-01-2013, 02:57 PM   #1548
BENRON
Crosscut Certified
BENRON's Avatar
Oddometer: 3,677
Originally Posted by Two Moto Kiwis View Post
the fuel pump squirted some gas out looks like from an overflow so I shut her off for a while..
Ya mean that little tube coming off the top of the stock pump?.... That'd be bad. That's where the points are located... Which Spark.
BENRON is offline   Reply With Quote
Old 02-01-2013, 05:33 PM   #1549
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,079
Originally Posted by BENRON View Post
Ya mean that little tube coming off the top of the stock pump?.....
To be honet I am not sure, I thought it was from there but it may have come from higher which would be carbs then.
Seeing the petrol piss out I shut her off rather than watch it ... for obvious reasons
Old 02-02-2013, 01:43 AM   #1550
Crowley
Crowley's Avatar
Oddometer: 56
Did the it stop immediately after you stopped the engine?
What fuel tank do you have on the bike?
Crowley is offline   Reply With Quote
Old 02-02-2013, 06:40 AM   #1551
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,079
Yes it did no worries there.
Running 30L Safari so suspect the flow is not as good.
Old 02-02-2013, 07:20 AM   #1552
Crowley
Crowley's Avatar
Oddometer: 56
Do you have one of those one way valves on your fuel cap or do you have the overflow pipe?
When it leaked did you open the fuel cap?
Old 02-02-2013, 02:00 PM   #1553
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,079
Got a one way valve on the fuel cap, soon as I shut her off I released the cap, no pressure or vacuum at all.
Seems fuel was squirting down from under the LHS of the tank, my airbox bottom drain tube is not there, could the petrol have bubbled out from a carb and with the fans on it might have sprayed it a bit?
Not a biggy really, I have noted it so will keep an eye on it if she gets warm, will just turn her off while sitting at lights in the heat.
Old 02-02-2013, 02:47 PM   #1554
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,596
Fuel Sensor Oring Gone
Sounds like the little oring around the fuel sensor has let go.
It has done exactly the same to me with the safari tank in the heat due to expansion. Just go to a hardware store and get a slightly enlarged oring.
Afternoon gents
This considered ok?
Hodgo Spot
My North America Trip
RD07 Africa Twin, KTM 950 Super Enduro
www.facebook.com/KTM950SE
Retired.. CR500E & lots more
Hodgo is offline   Reply With Quote
Old 02-02-2013, 07:15 PM   #1555
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,079
Ok, sounds like that could be it, not having had the SE very long I am still unfamiliar with it and finding my way around it so where would I find the fuel sensor? ..
Many thanks Andi
Old 02-02-2013, 08:29 PM   #1556
Crowley
Crowley's Avatar
Oddometer: 56
Many thanks Andi
What Hodgo says +1
Also throw that little valve thingy away as its the cause for the fuel leak. At high temperatures and slow speed the combined heat does pressurize the tank a bit. If you stick to the original pipe setup it never happens but the fuel will run out if the bike is on its side.
You don't have to replace the O ring immediately but it is a good idea to do it when you can.You can also seal it additionally with some gasket sealant to improve the seal - look for a fuel resistant one.
Also keep an eye on the fuel hose as it comes out of the fuel tank at the bottom on the Safari tank. They are quite close to the brace and sometimes they will rub and eventually start leaking. Not a big problem just something to remember when you see fuel pissing out.
Old 02-13-2013, 03:39 PM   #1557
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,739
Doing valves on my SE again, just wondering if there is any need to re-torque the head bolts like the older ADV models?
v8toilet is online now   Reply With Quote
Old 02-15-2013, 11:23 AM   #1558
bigkuri
bigkuri's Avatar
Oddometer: 882
My first post here on this thread, one of many, as I've just joined the SE crowd.
I've owned an Adv R for almost two years, and known since early days I'd "bought the wrong bike"
Just purchased a SE, finally, and have a few questions....
First, my old Adventure....
Questions:
What Adventure parts fit the 950?
Difference in maintenance?
Any must do additional things apply? Bear in mind I had an extremely tricked out AdvR....
Highlights, weird phrasing as I've nicked this from it's advert....
[*]High front fender
[*]Custom fork protectors
[*]No passenger footpegs
[*]GPS mount (the proper one that continues below the dash for strength)
[*]Power outlet within the dash
[*]Suspension from a super-tall 2008 S front and back (this strangely makes the bike taller than any of any year that I have seen, including the 2010 AdvR)
[*]Axle puller
[*]Rust-free wheels/spokes (with part worn Conti TrailAttacks)
[*]Heated grips with very trick switch (part of OEM controls)
[*]Anodised rear top-plate rack
[*]1st and 2nd gear unlimiting mod
[*]SAS removed and blanking plates
[*]Oxygen sensors removed, terminating plugs and blanking bolts fitted
[*]Recent oil, valves, air filters - major service (done by me, as I'd not let a dealer around London touch the bike)
[*]Bearings serviced, head bearings were ok, replaced front wheel bearings and swingarm bearings about 1,000 miles ago
[*]Dubious stickers... ;)
[*]Cut down screen
[*]3mm holes drilled in swingarm (great mod to release water)
[*]New (400 miles) chain (expensive gold link one) and new F&R sprockets, both OEM size
[*]2008 S centre stand, to accommodate additional height from suspension
[*]Obviously all the OEM parts are included in a box
[*]Akrapovic single exhaust with 2 into 1 link pipe
[*]Massively LOUD Seibel air-horn fitted into side cowling
[*]0.64 stiffer springs in forks
[*]GiT bashplate
[*]Black stainless steel radiator guard, great quality not the utter crap KTM one
[*]Chunky & bigger orange alloy footpegs
[*]Camel-toe side stand thingy
[*]Handmade left side tool tube
[*]Brand new lowered geared F&R sprockets
[*]Upgraded side-stand return springs
[*]CJ Racer see-thru Titanium clutch cover
[*]Oberon clutch slave and alloy spacer
[*]HDB handguards
[*]KTM 20mm handle bar risers
[*]Blackdog side stand relocate
[*]Steering dampener (Rallemoto)
[*]2nd right hand radiator fan and lower temp plug
[*]Centech Fuse box properly wired in, and mounted in cowl
Current Bikes: 2006 Honda XR650R & 2015 KTM 1190 Adventure R (build thread at http://www.ktmforum.co.uk/adventure/...venture-r.html )
bigkuri is offline   Reply With Quote
Old 02-15-2013, 11:29 AM   #1559
bigkuri
bigkuri's Avatar
Oddometer: 882
And of course, offers on the "old" Adventure then PM me ��
Old 02-15-2013, 01:55 PM   #1560
JustinT
I will ride my whole life
JustinT's Avatar
Oddometer: 965
What is this?
Full Throttle - it either solves the problem or ends the suspense
JustinT is offline   Reply With Quote
Times are GMT -7.   It's 06:00 PM.
