Old 02-02-2013, 06:32 AM   #1
dogsslober OP
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 1,078
Welding on frame
Need to do a little welding on my frame, will be using a mig. Should I unplug CDI or does it matter?
dogsslober is offline   Reply With Quote
Old 02-02-2013, 06:57 AM   #2
WIsixfitty
ceiling unlimited
Oddometer: 2,347
better safe than sorry.
unplug cdi/ecu, battery, plugs or ignition coils and set your ground clamp as close to where your welding as possible.
sideways and smiling
WIsixfitty is offline   Reply With Quote
Old 02-02-2013, 07:41 AM   #3
Tiggersteve
Oddometer: 42
Definately agree with the above
Sent from my Sony Ericsson arc s using Tapatalk 2
Tiggersteve is offline   Reply With Quote
Old 02-02-2013, 10:42 AM   #4
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 820
If your frame is Cromoly make sure you have the right wire for your mig,,, not the standard iron wire..
And if its Chromoly make sure you read up about normalizing welds..
Cheers.
Dave
pdxmotorhead is offline   Reply With Quote
Old 02-02-2013, 03:21 PM   #5
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
Yes BSTS but I have had my bike welded on all across the americas with only the battery disconnected.
DeepInIt is offline   Reply With Quote
Old 02-02-2013, 03:39 PM   #6
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 696
Better safe then sorry for sure. i
BigNastybrp is online now   Reply With Quote
Old 02-02-2013, 04:26 PM   #7
KustomizingKid
Oddometer: 678
Chromoly welds just fine with mild steel wire... Now I only use tig for anything motorcycle related for a number of reasons but you should be just fine. I have welded lots and lots of 4130 tubing with ER70S2 and a tig.
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 02-02-2013, 05:06 PM   #8
dogsslober OP
dogsslober's Avatar
Oddometer: 1,078
Thanks guys
Going to load it in my truck( with every thing un plugged) and go to work early to do it. I was happy to hear mild steel wire will be ok. All I'm welding is my center stand stop brackets,a whooping 2 inches of weld. With out them the chain rubs the stand when up.
Old 02-02-2013, 09:04 PM   #9
pdxmotorhead
Oddometer: 820
Guess it depends on the chrome-moly alloy your using, and how well you do keeping heat down on the tubing.
I've seen many cracked frames and roll cages when chromoly was welded with the wrong alloy and not normalized after..
BTW std off the shelf wire from say home depot is very high carbon iron (At least in my local store) and he was talking mig not tig right?
All I suggested was verifying the alloy and read up on chromoly weld normalization so he understand the potential issues..
Dave
Times are GMT -7.   It's 07:23 PM.
