02-02-2013, 07:10 PM
#1 |
Homeless Somewhere
Oddometer: 1,567
Maya's LHS Fork Seal leaking On The SE
Good evening gents
Has aftermarket seals I believe and the green dust caps (if you can believe any of the bullshit from the previous owner) Does anyone know if these are a one piece assembly or like the std ones with separate seal and dust cap. Next thing is where to source a seal in Mexico area, any leads. Many thanks.
Cheers Andi & Ellen...Two Moto Kiwi Grüvers .....somewhere Two Moto Kiwis Home Page For More Of Two Moto Kiwis Photos |
02-02-2013, 07:39 PM
#2 | |
Oddometer: 989
Two pieces. Pull the dust seal down and find something really thin but rigid. A thin feeler gauge works good, but anything will do. The idea is to get between the fork leg and the seal and run it around the fork leg to clean out the dirt or grit that is making your seal leak. It is a five minute job and will more than likely fix your issue. Motion Pro even makes the commercial version called a Seal Doctor. If you have green seals they are SKF, and are the best available. Try this trick before you replace the seal.
'06 950 Adventure S '10 Husaberg FX 450 '01 KTM 520exc |
02-02-2013, 07:47 PM
#3 | |
Homeless Somewhere
Oddometer: 1,567
02-02-2013, 11:10 PM
#4 | |
I love sand !!!
Oddometer: 2,574
My NEW SKF seal (the green ones) leaked at the left fork leg after installation and this trick did not sort it out fully, so i cut a piece of the the finest sanding paper i could find and run it around (with the sanding side facing outwards - towards the seal rubber) a couple of times and that took care of it. I guess there was a minute nick or something during installation inspite of me taking all necessary precautions. But avoid using anything metallic. It might tear/damage the lip of the seal. Mineral water bottle, business card are soft, giving and freely available.
'07 KTM Adv990S No myriad hues of laser lights no bottles that are oozing with nectars from heaven, no beautiful body soft and warm to the touch but, i have a very small desire.. Give me a dark.. long.. winding road, three gears to go and my Hellas on fire.. 950Rally picture thread |
02-02-2013, 11:30 PM
#5 |
Oddometer: 1,376
http://www.amazon.com/2013-KTM-FORK-.../dp/B009PPPJD4 or a 35mm film strip.
the green seals are the SKF's and they don't get any better. You guys need to mellow out and enjoy the trip all you seem to do is bitch about the bike. |
02-03-2013, 02:20 AM
#6 |
I love sand !!!
Oddometer: 2,574
Question is, would you (mellow out and enjoy the trip that is..) ? after having gone through what they have.
02-03-2013, 05:35 AM
#7 |
let's keep going...
Oddometer: 987
Air in Forks
+1 on film/negative strips to clean the oil seal lips (once you pull the dust seal out of the way). If you are on a trip stop by a photo-lab and ask for the ends they throw away- the tractor feed on the edges gives the dirt a place to go so it can be pulled out of the sealing area, just wipe it off when you're done!
If you don't have fork air bleeder valves on your bike, they are a great investment (now less than $20USD). Even after a short ride you'll be suprised how much pressure builds up when you push the buttons the first time. The buildup helps create leaks- dedicated offroad riders around here release the air multiple times a day & don't get leaks for years while riding in nasty, dirty stuff. Good Luck on your Adventure!
Britt '06 KTM 950 Adv 'S' '03 KTM 250 EXC '88 KLR650 - +170K miles "looks like you've had a lot of fun on that bike..." |
02-03-2013, 06:28 AM
#8 | ||
Homeless Somewhere
Oddometer: 1,567
Re the bike, as you know it was bought seriously misrepresented, we paid top dollar to pick up a bike that was mint with everything done so we could continue and we were lied to big time. It has caused us untold greif and losses, what you see on here is very much only the tip of the iceberg, if I were to list everything that still needs doing you would be bored to tears. The arsehole left us out $1156 US just to get her sorted in which I sold a lot of farkles just to cover repairs which I am not happy about having paid for them, then we have had a myriad of issues that still need fixing, some need money, some need attention, should a rear top shock bush be fucked in 1700 miles??? ... NO!!!. I put this to you and you can really mellow out here and be the big guy you seem to want to be .... our paypal is twomotokiwis@gmail.com, you square us $1156.00 US which we paid out for only on the initial stuff and I promise I won't say another thing. Then I can mellow out for the 3/4 month travel budget which I saved my arse off for and the fuckwit has stolen from us .... deal?, I look forward to your payment. Quote:
Hopefully an easy fix.
02-03-2013, 07:20 AM
#9 | |
Oddometer: 1,376
Bikes break, maintenance is constant you just got more of it than you bargained on. I've been there with my 950 when I first bought, not to the extent you where but more than I was ready for. |
02-03-2013, 02:56 PM
#10 | |
Homeless Somewhere
Oddometer: 1,567
Yes our trip comes first but just remember we NEED the bike, we can't just take it home at night and fix it as you can do!, I am happy as and wioll be even happier once I have finished moping up, I look forward to wearing shit out!
02-04-2013, 03:39 AM
#11 | ||
Oddometer: 4,994
http://www.ebay.co.uk/itm/Fro-System...item2319b93f54 If the forks are still leaking, how’s your eyesight. Take off the fork stanchion protector, look closely and feel for pits in the chrome around the common band of travel, there were voids under the surface on one of my SE legs or you could have a stone chip. If so get some fine wet and dry sand paper and rub the pitting to remove the rough sharp edges, loosen the fork tube in the triple clamp and turn a couple of mm so the seal is not rubbing on the imperfection. Tighten the triples and get the stanchion sorted when home. Quote:
charlie264 screwed with this post 02-04-2013 at 03:46 AM |
02-04-2013, 04:49 AM
#12 | |
I love sand !!!
Oddometer: 2,574
02-04-2013, 05:25 AM
#13 |
Oddometer: 4,994
I hate cold fingers too.
02-04-2013, 06:52 AM
#14 | |
Homeless Somewhere
Oddometer: 1,567
..... I have short hair so I should be ok
02-04-2013, 09:16 AM
#15 |
Oddometer: 4,994
Could just be a seal damaged when it was replaced.....easy done if you're a novice.
