Old 02-02-2013, 11:57 AM   #1
Danzo OP
Oddometer: 27
sound in tank
I have a new f700gs with about 250 miles on it. I have only filled it up once. Today I gently moved the bike while on side stand and noticed something was tapping on the inside of the gas tank near the rear of the bike behind the fuel neck. Rocked it side to side a few times and confirmed this. Bike has about a quarter tank of gas in it. Is something located in the tank that may have come loose??? Bike has been running fine and have not noticed it before today. Thanks.
Danzo screwed with this post 02-02-2013 at 12:31 PM Reason: found out it is normal
Danzo is offline   Reply With Quote
Old 02-02-2013, 12:34 PM   #2
BOETJE
Oddometer: 158
My 650 twin does that as well, especially with a half to near empty fuel tank. Something to do with the fule level float I think.
I don't worry about it.
BOETJE is offline   Reply With Quote
Old 02-02-2013, 12:34 PM   #3
Danzo OP
Oddometer: 27
After searching the f800riders.org forums I found out that it is normal. Cheers.
Old 02-03-2013, 07:50 AM   #4
JRWooden
Oddometer: 4,249
Likely it is the "tip-over" valve....
There is a pendulum weight in the back right corner of the tank that closes a valve and keeps fully from leaking out of the tank if your bike takes a nap
Old 02-03-2013, 09:15 AM   #5
MikeMike
MikeMike's Avatar
Oddometer: 4,150
It's the float sensor, for the record, I keep my tank between half and totally full as often as possible. That sound pisses me off for some reason.
Times are GMT -7.   It's 08:55 AM.
