Old 01-29-2013, 11:42 PM   #1
AMusedRider OP
AMusedRider's Avatar
Oddometer: 16
Question F800GS Weight Reduction
Hello folks..
Any tips and tricks on how to reduce the weight of a F800GS?
I love my bike but would very much like to reduce the weight as much as I can. Got pinned underneath it a couple of times while riding off-road. Couldn't really do much but wait for someone to help me pick it up.
On a good day I would be able to pick it up myself but as I do more off-road riding I am getting increasingly wary of the weight and the fact that I might not always have someone to help me out.
Plus, reducing the weight might make it more attractive an option for long distance off road travel.
I cannot do without the crash bars and the bash plate for obvious reasons but I see the following options to get the weight down.
1. Change the exhaust to a Leo Vince. Will shave off a few pounds.
2. Switch to the Shorai Ultra Light battery. Savings of up to 8 pounds I am told.
Any other ideas that you have tried and tested??
AMusedRider is offline   Reply With Quote
Old 01-30-2013, 01:21 AM   #2
LukasM
Oddometer: 5,426
Other than the battery and the exhaust there are no significant savings to be had, it will always be a heavy bike for off roading.
Going to a single caliper and narrower rims will make it handle better and feel quite a bit lighter while riding, but won't much difference if the bike is lying on top of you.... Same with a catless header, around 1 kg less IIRC.
Old 01-30-2013, 09:21 AM   #3
SlowRide13
Veteran n00b
SlowRide13's Avatar
Oddometer: 1,336
Buy an extra set of shiny new plastics/blinkers/levers, and hang them up on your garage wall. Then, maybe you will jump out from under your bike instead of trying to use your body to protect it during a crash
F800GS Grin Machine
KTM690E Grrr Machine
XR600R Oakey Mtn in the mud http://www.youtube.com/watch?v=bzoU2NpkaoA
www.hoofrehab.com
SlowRide13 is offline   Reply With Quote
Old 01-30-2013, 10:15 AM   #4
BcDano
One Lucky Dude
BcDano's Avatar
Oddometer: 324
Not a-lota
Got to agree with Lukas (battery & exhaust) not a lot of weight savings to be had even if you had big money to spend. For hardcore terrain you are better off to spend the money on a true off road machine or as has been suggested practice a better crash technique.
BcDano is offline   Reply With Quote
Old 01-30-2013, 10:16 AM   #5
DoWorkSon
Oddometer: 276
Workout more? Practice deadlifts and leg press? Fill tank with less fuel?
In all honesty the only way I could see serious weight savings would be to replace nearly every small metal part with carbon fiber which would be $$$ and the overall weight savings would be negligible
Street bikes can get very light because they make carbon fiber tanks, wheels, and swingarms...... I don't think carbon fiber would hold up well off road
DoWorkSon is offline   Reply With Quote
Old 01-30-2013, 10:40 AM   #6
gbtw
Oddometer: 146
Both wunderlich and touratech got it down to about 180 kg from the stock 207 kg. Both of those were for enduro racing so i doubt you will be able to cut more off the thing.
http://www.advrider.com/forums/showthread.php?t=629161
gbtw is offline   Reply With Quote
Old 01-30-2013, 11:15 AM   #7
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 4,129
Hello folks..
What about the F700GS? It is lower, easier to keep it upright. I know, the front wheel is a 19in, and it is cast alloy, and the suspension has less travel. Well, we all deal with compromises.
1. Learn how to crash (get out of the way of the falling mass)
2. Get a different bike and deal with the compromises
3. Ride with someone else who can help you
Reducing the weight in a way that will make a difference is almost impossible.
Whenever we are riding, we are an ambassador to our sport
I'd rather be riding!
Lion BR is online now   Reply With Quote
Old 01-30-2013, 07:33 PM   #8
LJRAT
LJR Adventure Tours
Oddometer: 60
I took 22 lbs off my F8GS but that still wont help when ur pinned under it. Hell my ultralight TE511 is still a lot of weight when ur under it.
LJRAT is offline   Reply With Quote
Old 01-31-2013, 05:37 AM   #9
ebrabaek
Oddometer: 4,805
It would hold up just fine, but it would make for a 40K motorcycle, if you could get the parts.
Erling
ebrabaek is online now   Reply With Quote
Old 01-31-2013, 07:48 AM   #10
Gaspare
Almost dirt rider
Gaspare's Avatar
Oddometer: 64
Some weight can be shaved off with tubeless conversion, too...
Gaspare is offline   Reply With Quote
Old 01-31-2013, 08:29 AM   #11
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,238
Yup, better to actually add some weight in the form of protection parts, i.e.: engine bars, skid plate, etc., then when the inevital becomes imminent, just bail clear of the bike and trust those items to do what they are supposed to do. Works most of the time, but can lead to some "character" marks on the bike.
Also good to do some off road skills training or practice to help reduce the frequency of the inevitable.
Ed
2009 BMW F800GS, 2008 BMW K1200GT
MCMXCIVRS is offline   Reply With Quote
Old 01-31-2013, 10:28 AM   #12
AMusedRider OP
Oddometer: 16
LJRAT, what did you have to do to shave off 22lbs?
Old 02-03-2013, 10:56 AM   #13
toro618
toro618's Avatar
Oddometer: 982
I realize this mod is not for everyone, but eliminating the front right rotor and caliper is worth 6 lbs....and that's unsprung weight.
toro618 is offline   Reply With Quote
Old 02-04-2013, 07:19 AM   #14
BluWolf
Oddometer: 191
Add wracks and panniers. This would add weight but most likely keep the bike off the ground/you enough to slide out and pick it up easier.
alternatively, learn to not end up under your bike.
Marc Langlois
BMW F800GS
BOA #166285
BluWolf is offline   Reply With Quote
Old 02-04-2013, 07:31 AM   #15
Ceri JC
UK GSer
Ceri JC's Avatar
Oddometer: 2,462
This alone will dwarf every other single weight saving you can make.
When you're riding with people on "proper dirtbikes" remember that they only have half, or even a third of the range of your bike. I find out what bikes other people are planning on riding and aim to be at the start (even if that is a gas station) with about 10 miles more range than the shortest-ranged bike.
The "F800GS Wunderlich Light" (Google it) is a good example of a really shaved down F800GS. It's not very pretty and it'd cost a lot to build one, but worth looking at for inspiration.
Good luck!
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back.
Ceri JC is online now   Reply With Quote
Times are GMT -7.   It's 07:33 PM.
