Old 02-04-2013, 12:48 AM   #1
stickit OP
Oddometer: 34
1999 640 Adventuer Questions
Just bought a 1999 model , have a few questions that might seem dumb but need to get solved . 1 ,Do they only start in neutral ? Mine only does it has a center and side stand , but can't see any censes to stop it from starting in gear when the stands down . 2 Are they always hard to start ie , one time starts with choke and stalls as soon as you throttle it off ; then wont start with choke and have to give it throttle to make it run . I did have to shorten up the right hand side fuel line as it was leaking like a sieve. This bike has done 25000ks and from all perspectives it looks in show room condition . Cheers for the help I have ridden her once up the dirt and loved every minute , but can see all the talk on the vib !! I have done a heap of research and been finding it hard to find the right answers for my prob's . Cheers
stickit is offline   Reply With Quote
Old 02-04-2013, 07:24 AM   #2
gunnerbuck
I.Hopp.
Oddometer: 3,131
There is a starter relay switch that ties in with the clutch lever so you can't start the bike in gear without the clutch pulled in... This is a safety feature and it sounds like yours is not working... You can either bypass it by joining the 2 wires together, try cleaning the contacts or replace it...
640 A x 2
gunnerbuck is offline   Reply With Quote
Old 02-05-2013, 12:49 AM   #3
stickit OP
Oddometer: 34
Could you post some pic's so I can fig out where it is . Cheers
Old 02-05-2013, 01:54 AM   #4
gunnerbuck
I.Hopp.
Oddometer: 3,131
I'm used to the later hydraulic clutch models, but yours is probably in a similar location... Just follow 2 wires with a connector that plug into the clutch lever perch... This connector has a tiny spring loaded switch that moves when the clutch lever is pulled...
640 A x 2
Old 02-05-2013, 12:48 PM   #5
bisbonian
bisbonian's Avatar
Oddometer: 904
My '99 has some sort of electrical switch mounted on the clutch side I believe, haven't paid it much attention as it hasn't caused me any problems.
The stalling may have something to do with the carb settings. I found that the idle mixture really made a difference and ended up buying a mixture screw from Loaded at Stenhouse Racing. It might not be the worst idea to take the carb apart to inspect and clean, mine was very worn and needed a bunch of parts replaced when I first bought it.
I replaced most of the fuel hoses on mine. I didn't mess with the molded hoses but anything that could be replaced with straight hose from the parts store got changed out.
My 2009 Alaska Adventure
bisbonian is offline   Reply With Quote
Old 02-06-2013, 12:27 AM   #6
stickit OP
Oddometer: 34
I have figed maybe the prob ; same as your bike traced those wires and they connect to nothing . I have 2 male connectors sitting near it doing nothing . But when I connect the one with a heap of wires it blows the fuse . The other one is connected by one brown wire and the other is broken . Could you have a look and source what yours connects to and maybe I can fig my prob out . Please .
Old 02-06-2013, 12:53 AM   #7
stickit OP
Oddometer: 34
I forgot to mention my fuel lines must have already been replaced as none of them are molded to a shape . They sprang a leak the other day from the right hand tank and have it on the list to replace them . Did they come with molded hoses people ??
Old 02-06-2013, 08:00 AM   #8
DaddyBigDaddy
AKA -Evel Kneilson
DaddyBigDaddy's Avatar
Location: Liberal ShitHole, San Fran-sissyco, Kalee-Fornee-a
Oddometer: 314
Wire
It is just in front of the counter shaft sprocket, there is a kickstand switch too. If the kick stand is down it won't start
DaddyBigDaddy
1998 KTM 620 Adventure
DaddyBigDaddy is offline   Reply With Quote
Old 02-06-2013, 12:19 PM   #9
bisbonian
bisbonian's Avatar
Oddometer: 904
I have no kickstand switches on my '99.
Old 02-07-2013, 12:44 AM   #10
stickit OP
Oddometer: 34
Kick start stand ?? Mine has a side stand as well as a center sand . The bloke I bought it off said he only ever used the kick start once and said take off the side stand to kick her over , but get it right or she well send you over the bars !!
Old 02-07-2013, 12:49 AM   #11
stickit OP
Oddometer: 34
Thought I would do this as a seperate post . I I found the prob .. Pulled the front farring off stuck my noggin in and connected wires together ; HAY PRESSTO !! Prob now is I saw other wire connectors ( three pron male )with no friend in sight . What you think ??
Old 02-07-2013, 07:04 AM   #12
gunnerbuck
I.Hopp.
Oddometer: 3,131
There are some connectors under that dash that are not used....
640 A x 2
Old 02-09-2013, 01:01 AM   #13
stickit OP
Oddometer: 34
So I was replacing the fuel lines this arvo and found a electrical connector comming of the carbie throttle . I can't see any other connectors to attach it to . Ideas boys
Old 02-09-2013, 03:56 AM   #14
Ol'Muley
old, not dead
Oddometer: 76
carb
Carb has proly been replaced it sounds like a later tps connector check bst bible
Ol'Muley is offline   Reply With Quote
Old 02-10-2013, 03:35 AM   #15
stickit OP
Oddometer: 34
TPS ?? Makes me wonder why replace , as carbies are far as I now reliable to the death, just keep it clean and jetted I have been having a heap of trouble with the trip and speedo ; can;t get it to find -1 on the trip diameter . It won't run thru the number + or - . , this makes the speedo go off the scales for speed . This is not the last of my questions !!
Times are GMT -7.   It's 06:33 AM.
