Go Back   ADVrider > Riding > Regional forums > West California, the desert southwest and whatever is left
Old 02-02-2013, 08:39 AM   #1
Yellowdatsun OP
Oddometer: 32
Horseshoe Dam walkway crossing AZ
Anyone know if the walkway under Horseshoe Dam NE of Phoenix, AZ is always open? Wondering if you can just ride up there and go across? Or are there some tips or tricks to it?
Yellowdatsun is offline   Reply With Quote
Old 02-02-2013, 11:46 AM   #2
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,229
always open. no gate or fence.
2 SPOT is offline   Reply With Quote
Old 02-03-2013, 02:56 PM   #3
sawzaller
Oddometer: 17
Was just up there yesterday to survey that situation. No gates or fences for the walkway. There's 2-3 ride reports on the interwebs with pics of riders crossing. The approaches on either side may or may not be a challenge depending on your curb weight and skill. West side approach is rock/dirt and the east side is a good incline but concrete like a khoi pond.
sawzaller is offline   Reply With Quote
Old 02-03-2013, 06:31 PM   #4
Kevinsterner
Kevinsterner's Avatar
Oddometer: 335
If you are doing the loop including sheeps crossing bridge, I would go over sheep crossing first and then down horseshoe. The other way you have to go from the riverbed up a nasty rocky hill to sheeps bridge.
2011 Kawasaki 650 KLR (Current Bike)
2011 Husqvarna TE 449
2013 Honda CRF 250 L
1981 Honda 750 F,1972 Yamaha 250, 1971 Hodaka
you can't fix stupid.
Kevinsterner is offline   Reply With Quote
Old 02-04-2013, 10:10 AM   #5
prsdrat
Oddometer: 754
Can someone refer me to a route map for the Sheep Bridge-Horseshoe Dam
Loop ? And, what's a good time of year when there might/should be
overflow at the dam?
This one's on my bucket list and my window of two-wheeling is closing down.
"Can't never could."-Grandma Belle Marie Bullock-Shuflin
prsdrat is offline   Reply With Quote
Old 02-04-2013, 10:41 AM   #6
750Volts!
India or bust!
750Volts!'s Avatar
Oddometer: 446
In my opinion as the last guy stated it is much easier to go from West to east. I will try to write it out so that the google maps etc will be easy for input.
From where ever you start in the valley make it up to Cave Creek road. You want to head east on Cave Creek road.
Eventually as you go east you will find the intersection of Cave Creek and Bartlett Dam Road (Also known as service road 205) continue on straight ahead on Cave Creek. After you go through several really nice twisties the road will turn to dirt.
At about where it turns to dirt the road is renamed 7 Springs road. Keep on trucking this road continues through the 7 springs rec areas and campground areas. There are 2 nice water crossings. Eventually you will also see forest signs that call this road FR24. (My street car GPS even calls it this) Keep on this road for about a dozen or more miles. It will eventually come to a T intersection. The road to the west goes to(Left) Bloody Basin and the I-17 freeway near Cordes Junction. The East (Right) goes to Sheep Bridge. Both ways are called FR269. Make the right and head east to sheep bridge. Once at Sheep Bridge carefully ride your bike across the bridge. It is a bit narrow but not bad just go slow. Once across the bridge there is a fairly nasty downhill section the leads to the beach area. I recommend that you coast down the hill with your engine shut off. This will prevent whiskey throttle and near death experiences. I am sure that there are plenty of guys that can ride it down but at least on the first try it might be smart to take it easy. Once you get to the bottom of the hill you want to find the road that continues to your left or east that goes to the dam. About 5 miles or so down this road you will see the dam on your right and continue at least a mile or two past where it is visible. There will be a fork in the road and a sign that says (someone's) farm. Take a right at this sign and not too far up you will find the dam. (If you find yourself crossing alot of water and in a river bed you missed the turn. Been there done that.) Once you cross the dam under on that pedestrian crossing there is a nice steep and pretty hairy part from the ped xing to the road. You might want to walk it up. If you slide it is a long way down. Once on top the road from there goes several miles of really crappy road to a T intersection. At the T make a right onto the Bartlett Dam road. You will ride a short ways and there will be another T intersection. This is the intersection of Bartlett and Cave Creek. If you make a left here you will be heading toward Carefree and Cave Creek. Closest gas will be 3 miles ahead on Cave Creek at the Carefree intersection.
I recommend that you ride a light bike. I think that I could possibly do this on my VStrom if my life depended on it, but it wouldn't be fun. The KLR would be okay too but it was really fun on a dirt bike. The KLR was doable just not really alot of fun. I had to work too much. When I rode it on the XR350 it was a really fun day. I think the guys on the DR650s had a good time and Jack rode his KLR and enjoyed it but he is a pretty big guy. In any case watch out for the rocks when you head up the hill leaving the dam crossing it will leave a wet spot in your shorts. Good luck to you. -Paul
P.S. Anytime that the weather is nice. (Less than 100 and not real wet) would be a great time for this ride. It tends to be windier and cooler so it helps make for a nicer ride with gear on. I know that my fat butt gets overheated with all of the gear, but on this ride I was comfortable all day.
750Volts! is offline   Reply With Quote
Old 02-04-2013, 11:59 AM   #7
Kevinsterner
Oddometer: 335
750 has a very good description of the route. I don't think we have had enough rain in the past few years to have the water go over the spillway. If its not going over now with all the rain the past week it will probably be sometime before it happens.
Old 02-04-2013, 01:00 PM   #8
Yellowdatsun OP
Oddometer: 32
Thanks guys. The thread grew further than I thought it would. Good tip on the direction of travel. Our plan was to just go check it out, but maybe we'll do the loop instead. It'll be two KLR's a gen 1 and a gen 2.
Old 02-04-2013, 05:14 PM   #9
F-Pilot
Oddometer: 31
Go right after a huge rainstorm, they usually release water then. It can be pretty spectactular.
Here is the SRP site that lists runoff, just click on the day and scroll down about halfway on the report page.
http://www.srpwater.com/dwr/
http://azdualsport.multiply.com/phot.../Sheeps-Bridge#
F-Pilot screwed with this post 02-04-2013 at 05:23 PM
F-Pilot is offline   Reply With Quote
Old 02-04-2013, 05:23 PM   #10
Yellowdatsun OP
Oddometer: 32
I ended up riding out there today to scope things out. Here's a bunch of pictures so the rest of you know exactly what to expect. I have to say doing a crossing here is not for the new riders. I also don't see how you guys can get past the sharp corners without bashing your bikes on the concrete.
Old 02-04-2013, 06:38 PM   #11
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,229
hard to believe how fast rain can fill up behind that dam. last month horsehoe lake was still non existant verde river.
the walkway is tight but do-able with bikes, just pay attn. two ppl wont be a problem to scoots the rear end around the corners easy.
Old 02-04-2013, 07:10 PM   #12
terb
terb's Avatar
Oddometer: 151
Do you have a picture of the lake?? And what bike did you take?
terb is offline   Reply With Quote
Old 02-04-2013, 07:19 PM   #13
Yellowdatsun OP
Oddometer: 32
The lake was probably half full. I took my KLR, but didn't ride it across.
Old 02-04-2013, 07:41 PM   #14
Crilly
Oddometer: 776
What is harder, the dam or the bridge?
Crilly is online now   Reply With Quote
Old 02-04-2013, 07:52 PM   #15
terb
terb's Avatar
Oddometer: 151
The only hard spot is on the east side of the bridge where the rocky 100 foot down hill is.
Times are GMT -7.   It's 05:34 PM.
