02-06-2013, 06:24 AM
#1 |
Oddometer: 115
SE suspension question.
I am trying the standard settings listed on the label, I like the suspension on the soft side. Will LESS rebound damping keep the rear wheel on the ground more over washboard? When climbing and turning switchbacks the rear hops more than I think it should.Thanks.
02-06-2013, 06:59 AM
#2 |
Oddometer: 173
I think that less rebound will help on washboard but the key is to test it yourself until it feels right. Go through the same section with a lot of rebound and then with very little and see what direction produces the desired effect. But a shock revalve will do wonders to the ride. Superplush fixed mine.
Good luck |
02-06-2013, 11:52 AM
#3 |
Oddometer: 115
Rear shock preload.
My suspension sticker has rear preload in mm. What is measured to get this spec ?
02-06-2013, 12:55 PM
#4 | |
Homeless Somewhere
Oddometer: 1,589
I am like you I prefer to run it softer, for your high speed compression on the rear you are pretty safe to turn it out completely, that is the 17 mm nut, for your low speed compression damping take that out about 3 - 4 clicks at a time or you will not notice any diference, don't be afraid to play with it way outside of the stickers parameters as you can always bring it back. Lesser rebound will certainly help on washboard but may be springy on the open road, to me than is a small price to pay to get our fillings in place as we are not going warp factor two anyway. Make sure your adjustments for softness for low speed compression damping and rebound damping are similar or you may experience packing, this is caused by to firmer rebound not allowing the wheel to return quick enough. Hope this helps, any queries fire away.
Cheers Andi & Ellen...Two Moto Kiwi Grüvers .....somewhere Two Moto Kiwis Home Page For More Of Two Moto Kiwis Photos |
02-06-2013, 01:58 PM
#5 | |
BeniciaKTM?
Oddometer: 1,000
PS - Enjoying your adventure blog! Pic:
02-06-2013, 02:44 PM
#6 | |
Oddometer: 173
02-06-2013, 07:02 PM
#7 | ||
Homeless Somewhere
Oddometer: 1,589
Sounds like you may have other issues depending on the valving and sound like it has been revalved fo someone heavier. Quote:
, we run our high speed completely out but remember there is a cross over point as well and it is just how we like it.
02-08-2013, 12:39 PM
#8 |
suspension guy
Oddometer: 167
SE suspension answer
To the original question, a faster rebound clicker setting (more open), will likely improve the function over tightly spaced washboard by allowing the shock to recover before it encounters the next bump. a shocks inability to do this is what is commonly referred to as "packing"
The 17mm nut outside the shocks compression clicker is what is called the "high speed" compression adjuster. It is a bit of a misnomer, as real high speed movements are more regulated by the compression stack inside the shock. The high speed adjuster actually increases or reduces spring preload against a miniature stack that is contained within the compression adjuster itself. This allows the bleed circuit to either hang in for longer or be overcome more easily, thus making it an adjuster for the adjuster if you will. In practical application it works as sort of a dynamic ride height adjuster, either resisting or allowing squat to the rear. Hope that helps, I find understanding the mechanism often help make understanding its function much clearer. Cheers James
www.superplushsuspension.com Never argue with stupid people, they will drag you down to their level and beat you with experience. |
02-09-2013, 11:13 AM
#9 | |
0.0
+1 Always nice when a pro offers some wisdom that be comprehended- thanks James
KTM: 06 KTM950S & 10 KTM450EXC (690E sold) BMW: 08 R1200GSA & 74 BMW R90/6 Ducati: 08 S2R1000 MONTESSA: 82 COTA 349 "The White Wonder" |
02-09-2013, 12:13 PM
#10 |
SE990R
Oddometer: 1,928
Most honest answer to a suspension question ever posted... ![]() ![]() ![]() .
~ Ken |
