Old 02-01-2013, 04:41 PM   #61
Chip Stevens
Oddometer: 118
Wallowa. There is always some blow by. One can even hear it when they do a compression check on an aircraft engine. My mechanic rockes the prop back and forth to get as high a reading as he can get. The last check averaged 76lbs with 90 lbs input. The manufacture says it can go down to 60 lbs as long as it is not going past a valve. The point I'm trying to make is blow by is greater then most realize. While I'm pontificating, there are some that feel the loss between the piston and the rings is larger then the rings and the cylinder walls. that would mean seating rings also includes the surfaces between the rings and the piston as well as the rings and the cylinder walls. chip
Chip Stevens is offline   Reply With Quote
Old 02-01-2013, 06:32 PM   #62
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,829
Originally Posted by Wallowa View Post
Yup carbonic acid is indeed nasty stuff that you do not want near any bearings.
Carbonic acid is a weakly buffered acid with a pH of ~6.0.
The acid that does the damage is H2SO4, sulfuric acid, a strong acid with a pH near 3. The H2SO4 comes from the combustion of fuels containing sulfur.
Quality motor oils with current API ratings contain calcium and sodium and other components that have opposing buffer capacity and neutralize the acids. Currently, engines fueled with diesel are mandated to use ULSD for on-road use, reducing the need for high TBN engine oils.
So, even your newer HDEO is lower in TBN than a few years ago. An engine oil with a TBN near 8 or 9 is desirable and has adequate capacity to neutralize acids formed by the combustion of even ultra low sulfur diesel fuel. Gasoline engine have even lower requirements for TBN so using a HDEO in a gasoline fueled piston engine provides increased protection from acid and poor quality fuels.
def is online now   Reply With Quote
Old 02-01-2013, 06:53 PM   #63
def
def's Avatar
Oddometer: 10,829
You're correct Chip.
Good piston, piston ring and cylinder design work together to provide long lasting service under extreme heat with high friction and gas pressures. The boxer engine uses high quality pistons and rings from Mahle, a world class manufacturer (when next watching NASCAR on SPEED, note the Mahle fender sticker on your favorite car).
Blow-by is inevitable. If the fuel is wet, then you're going to load your engine oil with moisture increasing the potential for the formation of acids. There are many stations that turn over their fuels slowly, maintain their equipment poorly and dispense wet fuel unknowingly, I fuel only at high volume stations that I trust. If you're travelling, truck stops typically have high gasoline turnover and keep their equipment in good working order. Of course, you can always ask the attendant behind the register. I once asked the local station clerk, "When did you get your last fuel delivery" When I heard two weeks ago, I rode on to another station. Motor fuel does sour with age so, use caution.
If you get water in your crankcase, change the oil and filter ASAP.
Old 02-02-2013, 07:48 AM   #64
Wallowa
Oddometer: 5,508
Appreciate the Education
Thanks for all the infomation on what is not a cut and dried [no pun] topic...water vapor in the crankcase and water in the oil..
Couple of points and then I will withdraw from what has become an off topic discussion from the original question.
While the pH is important for any contaminate, the quantity of any contaminate is also critical and can be the controlling factor regardless of the adverse nature of the contaminate.
Engine blow-by should not be a significant source of engine oil or surface contamination...period. If blow-by is significant enough to contaminate the oil then the motor design, assemble or state of wear is sub-standard. The boxer motor should not have sufficient blow-by to contaminate the oil. And I believe that it normally doesn't.
Compression on my GSA should be 145 psi and at 125 psi it is considered "poor". Airplane motors with 76 to 60 psi are different animals and not in this mix. All motors are not created alike.
As with the amount of contaminates [re: pH] the amount of blow-by is a huge factor; so inspite of some gases or fuel escaping past the rings [rings control the blow-by on both the piston and cylinder walls] this should not be a significant source of contamination in a modern, well designed and maintain boxer motor.
So what is "significant"? Last call, get an oil analysis and quit guessing. You folks have fun...
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is online now   Reply With Quote
Old 02-03-2013, 09:34 AM   #65
TORQUEMONSTER OP
Oddometer: 40
oil looks good
I went for a ride the other day and the foaming oil was gone. When I get the chance I will check the pvc. Does anyone have a diagram of the PVC and how to replace it?
TORQUEMONSTER is offline   Reply With Quote
Old 02-03-2013, 02:47 PM   #66
Wallowa
Oddometer: 5,508
There Isn't A PVC
See Posts 50 & 51 ...your bike does not have a PVC.
"In Wallowas"
Old 02-05-2013, 11:11 AM   #67
tps
Oddometer: 66
Yeah... most of the plastic is ABS. PVC tends to be a bit more brittle.
'04 R1150GS Adventure
'88 K75S, Red - Hellboy
'72 R75/5 Toaster, Blue - BluBawls
http://www.drysideriders.com
tps is offline   Reply With Quote
Old 02-05-2013, 12:20 PM   #68
Wallowa
Oddometer: 5,508
Laugh Ouch..You Got Me!
Done that before...writing "PVC" when it should have been "PCV"....Positive Crankcase Ventilation or in medical terms "Packed cell volume"..
Odd as I get older this happens more often..
"In Wallowas"
Old 02-06-2013, 10:43 AM   #69
def
def's Avatar
Oddometer: 10,829
That should be PCV (positive crankcase ventilation), a one-way valve that uses intake vacuum to remove vapors from an engine crankcase, not PVC, (poly vinyl chloride), a plastic used in plumbing and as insulation for wire.
Old 02-06-2013, 01:37 PM   #70
Dan-M
Dan-M's Avatar
Oddometer: 1,117
Wow. All of this for some condensation.
More riding and less typing is the short answer.
Dan-M is online now   Reply With Quote
Old 02-06-2013, 07:28 PM   #71
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,620
You're new here...huh? We will have..conservatively, 5 threads in the coming weeks about which oil to use and tire pressure..get used to it...
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 02-06-2013, 07:56 PM   #72
def
def's Avatar
Oddometer: 10,829
Give Dan a break...he lives in Illinois where the governor makes the license plates and its currently too cold to ride.
Old 02-06-2013, 09:30 PM   #73
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,620
Old 02-08-2013, 08:18 AM   #74
Dan-M
Dan-M's Avatar
Oddometer: 1,117
Hey, that's two governors Mister. and untold numbers of mayors, congress men and police chiefs.
Old 02-08-2013, 09:06 AM   #75
def
def's Avatar
Oddometer: 10,829
Sorry Dan.
I grew up in Lake Bluff during Richard J. Daley's time. Many of his cronies went to jail. I heard they had to hold city council meetings at the Cook County Jail to get a quorum.
Times are GMT -7.   It's 07:18 AM.
