Old 02-07-2013, 06:30 AM   #32986
ggemelos
ggemelos's Avatar
Oddometer: 137
Aftermarket bars
I am looking at picking up a set of Pro Taper Contour bars. I am happy with the stock ride position and was wondering which bars are closest to the stock geometry.
Preparation for big trip and future site of ride blog -> www.onthewanderlist.com
ggemelos is offline   Reply With Quote
Old 02-07-2013, 06:33 AM   #32987
30Bones
30Bones's Avatar
Oddometer: 4,636
Why change bars if the stock ones feel fine?
30Bones is offline   Reply With Quote
Old 02-07-2013, 06:37 AM   #32988
ggemelos
ggemelos's Avatar
Oddometer: 137
Get rid of the cross bar and more resistant to bending in a crash. I also am thinking of a Scotts stabilizer and do not believe it would fit with the stock top clamp and bar setup.
Old 02-07-2013, 07:59 AM   #32989
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,632
Originally Posted by Scott_PDX View Post
So much for the 24,000 mile valve check.
No reason to make an assumption based off of one person's experience.
swimmer is offline   Reply With Quote
Old 02-07-2013, 08:31 AM   #32990
AZ TOM
Oddometer: 4,000
Well said. Just look at the variation in fuel pump problems! Heading to Death Valley end of March, original pump, over 11,000 & no spare pump. Crazy? Maybe? Paranoid no!
AZ TOM is online now   Reply With Quote
Old 02-07-2013, 09:11 AM   #32991
Longboardr
Longboardr's Avatar
Oddometer: 143
I was in the same position and went with the Pastrana FMX bend.
If you decide to mount a stabilizer with an under the clamp mount you could go with a Pastrana MX/RM LOW bend to keep the bars from getting too high.
Pro Taper gives you dimensions of the bars here
Longboardr is offline   Reply With Quote
Old 02-07-2013, 10:59 AM   #32992
UtahFox
UtahFox's Avatar
Oddometer: 446
Anyone know of a tail rack that is compatible with a Rotopax mount? One that no drilling would be needed.
UtahFox is offline   Reply With Quote
Old 02-07-2013, 11:02 AM   #32993
ggemelos
ggemelos's Avatar
Oddometer: 137
Thanks for the feedback. It make sense to pick somewhat lower bars to offset the risers needed for the stabilize.
Old 02-07-2013, 11:40 AM   #32994
oldtrucks
oldtrucks's Avatar
Oddometer: 286
There is a guy that sells a nice billet one on WR Forum, comes in two sizes and works with the RotoPax
http://wr250rforum.forumotion.com/t6...rack-available
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. -Benjamin Franklin
oldtrucks is offline   Reply With Quote
Old 02-07-2013, 11:42 AM   #32995
huron52
Oddometer: 196
What size of socket/ allen wrench do I need to remove the front axle? 17 mm is to big 14mm looks too small Is it a 15mm, if so where do I find one... Or do I even need on to remove the axle?
huron52 is offline   Reply With Quote
Old 02-07-2013, 11:54 AM   #32996
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,943
Deadblow hammer or rubber mallet... remove axle nut (27mm), loosen the four pinch bolts around axle, tap with hammer to remove. If it's gritty or stuck you may have to use a drift (I use a 3/8" extension) to tap it once the nut end of the axle is inside the left fork. The end with the hex is not threaded, but larger than the part of the axle that goes through the wheel, so once you drive it 2" or so (width of the fork leg) it's easily removed.
GSBS is offline   Reply With Quote
Old 02-07-2013, 11:59 AM   #32997
UtahFox
UtahFox's Avatar
Oddometer: 446
Well, I'm all set. Driving down to Palm Springs tomorrow and scheduled to pick up a new (to me) 2011 Wrr. Going to drive it back to Salt Lake via the back roads in Nevada in an attempt to stay as low and dry as possible back up here. Pics to follow :)
UtahFox screwed with this post 02-07-2013 at 12:13 PM
Old 02-07-2013, 01:42 PM   #32998
AZ TOM
Oddometer: 4,000
Now thats some style
Old 02-07-2013, 02:16 PM   #32999
huron52
Oddometer: 196
Old 02-07-2013, 03:39 PM   #33000
UtahFox
UtahFox's Avatar
Oddometer: 446
I just saw the news just now and we're supposed to get 3-6" of snow here starting tomorrow sometime. Hope its gone in 8 days, may have to point it south before north. Any suspension experts in Phoenix I can look up?
Times are GMT -7.   It's 06:53 PM.
