Old 02-07-2013, 11:25 AM   #73501
barko1
barko1
barko1's Avatar
Oddometer: 3,375
Originally Posted by Richguzzi View Post
So true....I've looked at some real nightmares that POs have managed to perform on bikes before.....
I dropped a mini thermometer into the gas tank of a Triumph Tiger. Guess the next owner didn't realize he got a thermometer with the bike, kind of hard to read though.
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 02-07-2013, 11:36 AM   #73502
dljocky
Oddometer: 863
Soltice mounting Brackets?
Good day all,
For anyone who has mounted AUX lights using the Soltice mounting brackets, I was wondering if you had any problems mounting it on the side that the front brake hose guide? Looking to mount them on the lower fork clamps, but seems that the guide/hose is in the way. I'm afraid to just take the guide off, the hose might bind up on the light?
Any thoughts are appreciated.
dljocky is offline   Reply With Quote
Old 02-07-2013, 11:43 AM   #73503
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,612
Vacuum petcock update.
It was sticking open. I opened it up, and it was clean inside, but the piston was seemingly stuck in place by either the o-ring or in its sliding connecting-rod. I pulled it out of the main petcock body, rotated the o-ring around for a better, or different, surface seal, and put it back together.
Works fine for now.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is online now   Reply With Quote
Old 02-07-2013, 12:47 PM   #73504
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,191
Tool Tube Update
First, thanks to the person who suggested the Aerostich tent pole sack, that's a great idea!
But... I removed the skinny tube today and replaced it with a fullsize one. I got to thinking about it last night, and thought maybe I could fit the big one in there, as I had seen other people do it before... just was never sure how. So with a little fiddling and a new bracket, the regular-sized one is in place. This is perfect since all of my most commonly-used tools are in there, in a nice zipper pouch from Walmart ($5). It eliminated the need for my Wolfman fender toolbag... which is nice, but is hard to get into, and it isn't waterproof, so your tools end up all rusty.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 02-07-2013, 01:31 PM   #73505
MADurstewitz
MADMark
Oddometer: 159
Originally Posted by planemanx15 View Post
MADurstewitz, I see that your from Jersey... is this you?
Nope.
MAD
(yes, those are my real initials)
MADurstewitz is offline   Reply With Quote
Old 02-07-2013, 01:39 PM   #73506
MADurstewitz
MADMark
Oddometer: 159
Originally Posted by gjcarving View Post
How have you been liking the 790? Any issues? Did you do a new cam with it? Also, why did you change out the bearings and other things? Thanks!
I love it. The only issue is a tiny oil leak, probably from the cam chain tensioner that I haven't had time to fix. Stock cam, stock exhaust dynojet with K&N filter, highway gearing, oversize kibblewhite valves and I had the machine shop open the head up a little while they had it. I replaced the bearings because the input shaft bearing failed. I caught it just before it flew apart. With all the metal bits in the motor it would have been dumb not to replace them.
The difference between the stock bearings and the SKF's was amazing. They were so much smoother and easier to move it was ridiculous.
MAD
Old 02-07-2013, 01:51 PM   #73507
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,991
Giant Loop Fandango Tankbag on IMS tank w/ Acerbis gas cap.
Awesome fit and it does not get in the way when i stand.
http://www.advrider.com/forums/showp...6&postcount=76
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 02-07-2013, 08:23 PM   #73508
1989THEARK
1989THEARK's Avatar
Oddometer: 346
Not sure where to post or where to go BUT
I need a waterPROOF case for my EVO LTE.
dimensions are height 6 inches ( with headphones in)
width 4 inches(with chargin cable plugged in)
depth .38 inches
MUST mount to 7/8 bars
i am a 4 seasons rider. My phone acts as my GPS. music player.
and anything els i can find a purpose for.
whatever it is it MUST
MUST!!
stay rigid at 100mph
1989THEARK is offline   Reply With Quote
Old 02-07-2013, 08:25 PM   #73509
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,191
depth .38 inches
MUST!!
What about this?
http://shop.htcpedia.com/htc-evo-4g-...campaign_id=11
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Old 02-07-2013, 08:29 PM   #73510
1989THEARK
1989THEARK's Avatar
Oddometer: 346
Originally Posted by Rob.G View Post
No way to mount to bike.
cannot use touch screen.
Cant run cables into box to charge of plug in headphones.
Old 02-07-2013, 08:32 PM   #73511
ER70S-2
ER70S-2's Avatar
Oddometer: 6,655
Originally Posted by BergDonk View Post
Done
Originally Posted by Mambo Dave View Post
Thank you, and thank you to ER70S-2.
Originally Posted by greer View Post
.......And ruins the brake pads and soaks your boot and pant leg.
Sarah
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 02-07-2013, 08:42 PM   #73512
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,191
Yep that'd be a problem. Not to start a war, but ever consider an iPhone?
Reason is, the Android phones change so frequently that there is little motivation for case companies to make GOOD cases for 'em... no way they would ever sell enough of them to justify the R&D.
I have the Lifeproof case on my iPhone 4S (and there's an iPhone 5 version too)... it does everything you want. There's even a native handlebar mount, though it doesn't attempt power input. If you want that, there's a real nice semi-generic RAM mount that I've seen people use.
http://www.lifeproof.com/en/
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Old 02-07-2013, 08:43 PM   #73513
DisTech
DisTech's Avatar
Oddometer: 616
Going to require some work for wiring but I'm going to try one of these, AQUA BOX. There are a few different sizes and it's from Ram Mounts so it is mountable.
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech screwed with this post 02-07-2013 at 08:52 PM
DisTech is offline   Reply With Quote
Old 02-07-2013, 08:49 PM   #73514
ER70S-2
ER70S-2's Avatar
Oddometer: 6,655
Originally Posted by procycle View Post
I'm willing to bet you know more about it now than they ever did. Too many dealership service departments don't have a clue and it puts the unprepared bike owner at their mercy.
I hate the new reality.
Originally Posted by Carl Childers View Post
A bad experience or two like this have turned a lot of us in to do it your selfers. For over 30 years now I haven't let any one touch my cars, trucks, or motorcycles. I don't even enjoy the work all that much on the cars and trucks anymore but hate to pay someone my hard earned money to f#%& it up. There are still some good shops out there but they are few and far between.
+1
The internal valve is stuck. They are not lubricated from the factory and a tiny bit of corrosion will make it stick. It's an easy fix. Disassemble the petcock, clean up everything, put a little grease on the piston and bore.
Time for a little maintenance.
2013 WR250R
Old 02-07-2013, 09:01 PM   #73515
1989THEARK
1989THEARK's Avatar
Oddometer: 346
Rob
Flame war activate.
although i hear what your saying. the simple answer is no.
i actually have an S4.
BUT its no longer a phone
its currently running ubuntu and i use it for many things im not going to mention.
impossible you say?'
........almost
its really slow and jittery
Times are GMT -7.   It's 05:14 AM.
