Old 02-07-2013, 09:05 PM   #73516
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Not sure why you need Ubuntu on your handlebars, but good luck with that.
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 02-07-2013, 09:08 PM   #73517
1989THEARK
1989THEARK's Avatar
Oddometer: 347
i dont.
I need my phone,gps,music player on my bars. (EVO LTE)
suggestions?
or just sarcastic replies?
1989THEARK is offline   Reply With Quote
Old 02-07-2013, 09:12 PM   #73518
1989THEARK
1989THEARK's Avatar
Oddometer: 347
Originally Posted by DisTech View Post
Going to require some work for wiring but I'm going to try one of these, AQUA BOX. There are a few different sizes and it's from Ram Mounts so it is mountable.
I contacted REVZILA about needing a phone solution for my bars and that is exactly what they suggested.
im seriously tempted to get it. I just dont like the non waterproof whole the wires have to go through.
BUT i could probably run my pre determined wires through it and seal it up with silicone
solving my water problem.
BUT how much water can this thing handle.
are we talking a full downpour at freeway speeds or just foggy weather or just a light drizzle.
if you get it please let me know how it worked for you.
I actually might order it myself
and i'll PM you with my experience
Old 02-07-2013, 09:13 PM   #73519
TRAVELGUY
Old Traveler
Oddometer: 663
I tried a AQUA BOX a few years ago for a GPS. Was difficult to view screen or use touch commands.
TravelGuy
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY screwed with this post 02-07-2013 at 10:09 PM Reason: spelling
TRAVELGUY is offline   Reply With Quote
Old 02-07-2013, 09:18 PM   #73520
1989THEARK
1989THEARK's Avatar
Oddometer: 347
Originally Posted by TRAVELGUY View Post
I tired a AQUA BOX a few years ago for a GPS. Was difficult to view screen or use touch commands.
TravelGuy
what made it difficult to view the screen?
glare?
clarity?
etc etc
was it difficult to operate with gloves or without gloves?
Old 02-07-2013, 09:31 PM   #73521
falcore
Oddometer: 10
cyclegadgets have a range of mounts an cases that might suit for you to have a look at
Sent from my ASUS Transformer Pad TF300T using Tapatalk 2
here for a good time
falcore is offline   Reply With Quote
Old 02-07-2013, 09:38 PM   #73522
1989THEARK
1989THEARK's Avatar
Oddometer: 347
Cry
they have bin shut down since early 2011
Old 02-07-2013, 10:03 PM   #73523
DisTech
DisTech's Avatar
Oddometer: 616
I have one already, haven't mounted or wired it yet though. The construction leads me to believe it is water proof.
The flexible screen that you operate the touch screen through probably does reduce sensitivity (ha!) but I'm not planning on using this as my main gps. Secondary gps, phone and music (maybe). Hoping for reduced need to interact with it. With my phone plugged in the full power screen is pretty bright so I think I will be able to see it. Have to see if I just end up confirming TG's findings.
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 02-08-2013, 12:24 AM   #73524
N.dica
Oddometer: 109
Some DR parts listed in the flea market if anyone wants to farkle it up with stock gear. wooooot!
N.dica is offline   Reply With Quote
Old 02-08-2013, 02:27 AM   #73525
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,141
I use a Sony Ericsson Xperia Active with a SportyPal bar mount.
Should be robust enough.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 02-08-2013, 02:38 AM   #73526
falcore
Oddometer: 10
Oh crap. Well there you go
Sent from my GT-I9300 using Tapatalk 2
Old 02-08-2013, 06:00 AM   #73527
neo1piv014
ADV in training
Oddometer: 619
Wasn't the Xperia Active already water proof and such?
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 02-08-2013, 08:37 AM   #73528
1989THEARK
1989THEARK's Avatar
Oddometer: 347
Talking BIg Favor
If you already have the case i have a favor to ask. Possibly a HUGE favor to ask.
Could you get the case put some paper towels in it and run some water over it for a few minutes while rotating. To make sure water doesn't get in.
this works for both of us. Ensuring that NO water gets in.. If it keeps water out without the back punched out. Then after i run wires through it i can silicone it sealed and it would be the same as if i never removed the back.
Old 02-08-2013, 08:43 AM   #73529
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,758
I had two sizes of the RAM Aqua boxes and I hated them. They were too big and heavy for what they were and electronics inside the boxes heated up far more than they should be run at. And it wasn't even that hot on the days I tried.
This was the Aqua box with a Garmin 295W I had at the time.
And this is the Arkon box I also bought to try, and also hated. I had the 295W in it to show the relative sizes of things. This shot shows how the case is made.
Granted, the Aqua boxes were fairly waterproof when used with the baffled cable entry point under the box.
But I wouldn't waste any money on either one. Just happy I was able to get rid of them.
A good baggie with a RAM mount would be just as useful, IMHO.
Emmbeedee screwed with this post 02-08-2013 at 08:51 AM
Old 02-08-2013, 10:49 AM   #73530
TRAVELGUY
Old Traveler
Oddometer: 663
Screen was not clear and bright inside the box. Touch screw was almost unusable.
TravelGuy
glare?
clarity?
etc etc
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
Times are GMT -7.   It's 09:38 PM.
