Old 02-07-2013, 09:44 AM   #16
jackass dave OP
jackass dave's Avatar
Oddometer: 96
http://s1116.beta.photobucket.com/us...arsgs.jpg.html" target="_blank">http://i1116.photobucket.com/albums/.../fatbarsgs.jpg" border="0" alt=" photo fatbarsgs.jpg"/>
jackass dave is offline   Reply With Quote
Old 02-07-2013, 09:45 AM   #17
jackass dave OP
Oddometer: 96
bugger that didnt work either javascript:void(0);
Old 02-07-2013, 09:46 AM   #18
jackass dave OP
Oddometer: 96
Old 02-07-2013, 09:47 AM   #19
jackass dave OP
Oddometer: 96
at last ,monkey see monkey do ,i knew if i pressed enough bittons sooner or later it would work ,the picture above is the set up i need ..
Old 02-07-2013, 10:06 AM   #20
patrkbukly
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 1,102
Easy...
Ok look...I'm tryin to be easy on you about the pictures but come on....that handle you've got, your giving us too much ammo here.
Yea thats about the setup I have which I like a lot, good beefy adapters, wide enough bar for good control and easy highway too.
Right On Jackass (damn feels weird saying that).
You only live once, but if you do it right, once is enough.
Mae West
patrkbukly is offline   Reply With Quote
Old 02-07-2013, 10:08 AM   #21
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,513
Those appear to just be Rox risers with whatever flavor of 1 1/8" bars. I suggest you investigate the "edit" function rather than creating a new post for every failed pic experiment.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 02-07-2013, 11:37 AM   #22
jackass dave OP
Oddometer: 96
easy tiger ,one step at a time ,pictures first ,then the edit button,who knows ,i could even put pictures and words together .
Old 02-07-2013, 08:26 PM   #23
Phreaky Phil
Oddometer: 1,837
My set up. 3 1/2" Rox risers and Protaper Copntour ATV bend bars.
Phreaky Phil is online now   Reply With Quote
Old 02-08-2013, 12:39 AM   #24
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,424
Two inch Rox with HDB's guards and KLX High Rise bars
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is offline   Reply With Quote
Old 02-08-2013, 12:47 AM   #25
advNZer?
advNZer?'s Avatar
Oddometer: 2,885
all you guys with risers n higher bars,Are the cables long enough?
aka BMWST?
advNZer? is offline   Reply With Quote
Old 02-08-2013, 01:01 AM   #26
Phreaky Phil
Oddometer: 1,837
Yep, no worries with the cables. In reality the bars aren't in that much of a different spot than stock. The Rox risers allow you to put different bar bends on. I wanted the 3 1/2 " risers so I could rotate things rearward so it was comfortable sitting, as I nearly always have a pillion.
Old 02-08-2013, 01:17 AM   #27
advNZer?
advNZer?'s Avatar
Oddometer: 2,885
i need the extra height i am 6 3 when i stand i feel like am still bent over
aka BMWST?
Old 02-08-2013, 01:20 AM   #28
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 663
Rox Risers
I was really jazzed when I came across the Rox risers for the first time a few weeks ago on a brief expedition to Orange Krush and on paper they would seem to solve many problems (universal fit on triple clamps, height, inclination, fat bars).
I would assume most will go for longer risers and flatter bars than the stock GS, so on balance not so much overall height increase for the cables.
@ 6'4, I got 5" risers and high bend pro taper bars - to have a more rally stance, so am ready for a cable conversion... a small price to pay for comfortable standing ergonomics
Ras Thurlo screwed with this post 02-08-2013 at 01:40 AM
Ras Thurlo is offline   Reply With Quote
Old 02-08-2013, 06:40 AM   #29
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,688
I'm running a 75mm rise on std bars.
The clutch cable is just long enough.
Routing is important,
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 02-08-2013, 06:45 AM   #30
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 663
I had 50mm rise and standard bar tilted right up for max height and the cables are fine but with little play left, so would agree that your setup is about max
Times are GMT -7.   It's 08:36 PM.
