Old 02-07-2013, 09:14 PM   #1
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 1,035
Rear spring
I have a 03 Adventure with a white spring on the rear with the numbers 140-255 printed on them. The rear feels a bit too firm. Is this the standard spring for this year bike?
I have adjusted the remote preload back and on and it seems to not affect it.
I am 75kg, mabey 80 fully kitted up. Most of my riding is solo so want it a bit more cushy on the rear.
Cheers.
rossguzzi is offline   Reply With Quote
Old 02-07-2013, 09:45 PM   #2
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,100
You are a little light for that spring. The code is 140 neutons and 255 mm long. That's about 14 kg/mm, stock for the early ADV's. Later they went to even stronger 150-255 springs. You need to get a heavier girl friend.
The spring preload will not make it softer, it only makes the bike ride lower.
Check your damping settings, back off all the settings about 20%. So, more clicks, more turns, especially the compression settings.
Then you may want to look at a lighter spring.
"Son, you can't do both"
Old 02-08-2013, 04:11 AM   #3
mousitsas
mousitsas's Avatar
Oddometer: 2,913
Do you have the stock or aftermarket exhausts?
From my experience from the SE, a stock bike (140 rear spring) rides similarly if akras and a 130 rear spring is fitted.
mousitsas is online now   Reply With Quote
Old 02-08-2013, 12:23 PM   #4
James Siddall
suspension guy
James Siddall's Avatar
Oddometer: 176
Soft Spring
We make and sell a 130 Newton spring which we commonly recommend for riders of your weight.
I think you would prefer it.
The unique length of the 03 04 Spring at 255mm creates a bit of problem, as we only normally make that spring in 225mm length, but we can space around it.
Drop us a line if you want more specific details.
Cheers
James
www.superplushsuspension.com
Never argue with stupid people, they will drag you down to their level and beat you with experience.
James Siddall is offline   Reply With Quote
Times are GMT -7.   It's 02:49 AM.
