Old 11-18-2011, 03:48 PM   #16
photorider
photorider's Avatar
Oddometer: 283
Have you tried just rotating the ones you have forward a bit? Not trying to sound like a smart-ass and you've probably already tried this but changing the angle on those high bars can make a big difference in riding position.
photorider is offline   Reply With Quote
Old 11-18-2011, 05:47 PM   #17
trophymoto
MACDADDY!
trophymoto's Avatar
Oddometer: 444
K75 C bars are a bit higher than s bars. A buddy of mine has them on his RS, nice fit!
trophymoto is offline   Reply With Quote
Old 11-19-2011, 12:45 AM   #18
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,398
What about R100GS bars, with the cross bar?
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is online now   Reply With Quote
Old 11-19-2011, 09:21 AM   #19
ratsass
Oddometer: 4
Thanks all - lots of great ideas here. Will play around w a few. Looking at gs bar dimensions, those might just do the trick.
74 Airhead R90/6 - bone stock after 25 year "rest"
78 Airhead R100/7 - work in progress
69 Triumph TR6C - on way to returning to desert sled roots
06 Ural Tourist - the beater
07 Triumph Bonneville - cafe
ratsass is offline   Reply With Quote
Old 11-19-2011, 10:12 AM   #20
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,534
I had a pair of Guzzi T3 bars on my 90/6. They were a nice compromise between the Euro and US airhead bars.
Rob Farmer is offline   Reply With Quote
Old 11-19-2011, 11:27 AM   #21
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,011
Update to my reply back in 2009...
I scored some aluminum alloy bars for mid-90s Ducati M900 ( owned one for 6 years myself) for a good price. Put them on the ST immediately before a 1400 mile round trip test ride to the Old's Cool Spring fling up in TN.
Perfect set up for me! I already knew I liked that bend from experience with my Monster. But the surprise payoff was that the new body position also makes the stock seat almost comfortable for 12-13 hour days.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 screwed with this post 11-20-2011 at 10:14 AM
mark1305 is offline   Reply With Quote
Old 11-19-2011, 04:35 PM   #22
the velvet hammer
airhead @ heart
the velvet hammer's Avatar
Oddometer: 241
Originally Posted by ratsass View Post
Bike currently has the stock US bars. Looking for something a little lower and and wider. Have seen some folks discuss installing -- anyone gone ahead and done it?
- Cable swap required?
- Riding comfort / control impact?
Thanks!!
I switched from some taller bars to low/wide sidecar bars on my 100s (w/ a sidecar)--I switched from a set of /2, taller bars that were on the bike. I love the low/wide bars for comfort and riding position! The cables didn't need to be changed, maybe by luck, but maybe the height traded for the width (?).
More photos here if you want:
http://thevelvethammer.smugmug.com/M...86821768_Hxwxa
the velvet hammer is offline   Reply With Quote
Old 11-19-2011, 11:44 PM   #23
Country Doc
Wanderer
Oddometer: 2,707
Looks good Rob. I'm looking for something part way between the US high bars and my current S bars on my /5 which I find slightly too low and forward, especially with the Corbin seat.
Where did you get the t3 bars? Any specific model? Any mods to make them work on the BMW?
dc
Country Doc is offline   Reply With Quote
Old 02-08-2013, 10:51 AM   #24
Hi Viz Guy
Hi Viz Guy's Avatar
Oddometer: 327
thanks
just ordered a set of Euro-Bars from my local tucker rocky guy for my r90 Winter "project" bike... what a difference a MM makes!!!!
Be Seen & Be Safe
Hi Viz Guy is offline   Reply With Quote
Old 02-08-2013, 12:14 PM   #25
Boon Booni OP
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,430
Wow, forgot about this thread.. As an update I ended up with a set of daytona bars as reccomended by Bigger Al in this post..
LINK
I had to sand the throttle tube area of the bars some to allow for free rotation of the throttle tube. I love the bars, exactly what I was looking for, and at $23 bucks or so, definitely the right price.
So, in fact, in the OP of this thread I was wrong, you can buy just any old set of bars, you just gotta remove a little material from under the throttle tube. Everything else works just fine.
Where the fuck...
Where the fuck is the bike?
You gotta be shitting me.
Where the fuck is the road?
Old 02-08-2013, 12:57 PM   #26
craydds
craydds's Avatar
Oddometer: 1,156
Originally Posted by Boon Booni View Post
I realize I can't just buy any old handlebar because of the 21mm size of the beemer bars, so what are the options out there?
The Beemer bars are 22 mm. A 7/8" bar is 22.225 mm. Some say that the extra 0.225 mm is a problem. What say the inmates?
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 02-08-2013, 01:21 PM   #27
craydds
craydds's Avatar
Oddometer: 1,156
also searching
I also would like to find another handlebar. Pictured is the "S" bar below and the "RS" bar above:
I want a flat bar (no rise) like the RS bar, but with less pull-back than the original RS bar. See the RS pull-back compared to the S bar? It has way too much pull-back and hits the gas tank when turning to full lock, actually hits the tank before the steering stops hit. The pull-back on the S bar is just right, but I want a flat bar. I will go out and make some measurements and drawings so I have some dimensions on width, pull-back, etc. I see suppliers listed in some of the posts above; will I have any luck finding what I need? Can someone custom bend a handlebar for me?
ABC #12947
'75 R90S
Old 02-08-2013, 02:25 PM   #28
Prutser
Prutser's Avatar
Oddometer: 969
Rizoma
Two examples of Rizoma handle bars, one mounted on an R100R the other on an R80.
They are great IMO.
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is online now   Reply With Quote
Old 02-08-2013, 02:38 PM   #29
Boon Booni OP
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,430
Sand down the throttle area
Where the fuck...
Old 02-08-2013, 02:43 PM   #30
craydds
craydds's Avatar
Oddometer: 1,156
ABC #12947
'75 R90S
Times are GMT -7.   It's 05:40 AM.
