Old 02-08-2013, 06:52 AM   #24736
tunp
tunp's Avatar
Oddometer: 290
rear shock bolt 38.5 lbs
fork triple tree bolts 18.4 lbs
rear wheel 100lbs
front wheel 38 lbs
brake caliper 18.5 lbs
Ridin w/ a smile
Tony A
02 FLHT, 11 990 adv,13 TE449,
tunp is offline   Reply With Quote
Old 02-08-2013, 04:04 PM   #24737
Aey dubya
Thumper Humper
Aey dubya's Avatar
Oddometer: 356
Originally Posted by 1 lunger View Post
My front brakes make noise too. Did from day 1.
Originally Posted by His Pistolship View Post
Quick question: How do I stop the front brake from squealing? Is this something specific to the 610? I tried some of that disk brake quiet, but it didn't work; perhaps I did it wrong.
Would new brake pads do the fix?
Thanks.
My bike wailed so loud at stop lights it was embarrassing. Three years latter on my third set of pads it stopped. Sorry I cant remember what brand they were. I usually buy a step or two above the cheapest on things.
Aey dubya is offline   Reply With Quote
Old 02-08-2013, 04:12 PM   #24738
His Pistolship
Kp calm, shoot alfas
His Pistolship's Avatar
Oddometer: 417
Alright, ordering new pads. "Wailing.." is a good word for it.
His Pistolship is offline   Reply With Quote
Old 02-08-2013, 04:17 PM   #24739
Aey dubya
Thumper Humper
Aey dubya's Avatar
Oddometer: 356
On the subjected of TE flaws. I upgraded to a hydraulic clutch, and though Georges kit is vary pretty, I just got a universal Magura kit and with about 20min, a drill, a cutting disc, and a pair of vice grips I had my own mount for the case. $$$$
Old 02-08-2013, 04:18 PM   #24740
His Pistolship
Oddometer: 417
Do tell...
Old 02-08-2013, 04:21 PM   #24741
motopreserve
Oddometer: 128
Even new pads can squeak and cause a headache. The sound comes from the the pads vibrating against the rotor at a certain frequency - like all sound, just not as pretty as a piano or guitar (or pan flute if that's your bag) :) That's why people often get new or worse sounds after installing new pads. It's just a situation of a new vibration creating a new frequency. I have even had it happen after removing the wheel and reinstalling it, without changing anything but an inner tube.
There have been many options for trying to control this issue - "special grease" that goes behind the brake pad, and EBC will even send you a free pack of "damnpening pads" that you install with new brake pads. They don't advertise it - but once I heard about it, a simple email request had them on their way from EBC, no charge.
The bottom line is all or none of these things may work. Or, you could remove the pads/wheel/caliper (one or all), reinstall them without changing or adding a thing, and have no sound at all.
Kawasaki Versys**CL360 Project**Honda CB 550**Husky TE610**'72 XL250 for the lady
MotoPreserve -- a blog about wrenching on bikes in Barre, VT...
motopreserve is offline   Reply With Quote
Old 02-08-2013, 04:25 PM   #24742
Aey dubya
Thumper Humper
Aey dubya's Avatar
Oddometer: 356
Do tell...
If your bike doesn't break clutch cables I would'nt worry (or do anything) about it. It seems like they either do or they don't. My friend has a dealership and knocked it out for me so If you want to do this I can get the info from him. His opinion was that the 2oz aluminum piece from George was a rip off. (Just the messenger here George fans)
Old 02-08-2013, 04:29 PM   #24743
Aey dubya
Thumper Humper
Aey dubya's Avatar
Oddometer: 356
There's truth in what your saying But, 3yrs wailing 2yrs quite, says it's worth a shot.
Old 02-08-2013, 04:50 PM   #24744
motopreserve
Oddometer: 128
There is no doubt it's worth trying. I'm an audio engineer, just a peep drives me bonkers. I believe what you say about your experience - but as a contrast, I swapped the silent pads on my 35 year old Honda (I wouldn't be shocked if they were original!), and had the worst racket. Disassembled the caliper, regreased the parts, and they were back to perfect. It's a frustrating mess - but one you can monkey with to eventually get rid of....if you're lucky :)
Old 02-08-2013, 05:00 PM   #24745
Aey dubya
Thumper Humper
Aey dubya's Avatar
Oddometer: 356
I do remember that if I knew I was going to give a ride to a girl I would use light sand paper on the rotor. It would buy you until the next nights bike's rest.
Old 02-08-2013, 05:01 PM   #24746
motopreserve
Oddometer: 128
Now that's smart thinkin'
Old 02-08-2013, 06:38 PM   #24747
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,417
Thank you very much
Does the clutch cable run on the inside of the right Radiator near the frame ?
rear wheel 100lbs
front wheel 38 lbs
ebrew is online now   Reply With Quote
Old 02-09-2013, 07:28 PM   #24748
Taranis
Oddometer: 379
Go back a few pages and look for the discussion of clutch cable alignment. I still don't have enough miles on my bike to prove the longevity, but super-smooth and proper alignment has to be a lot better than feeling the braid of the cable grind past the end of the housing.
DIRT BIKES ARE FUN AND INTERESTING
Taranis is offline   Reply With Quote
Old 02-10-2013, 10:30 AM   #24749
Aey dubya
Thumper Humper
Aey dubya's Avatar
Oddometer: 356
Yup
Old 02-10-2013, 10:32 AM   #24750
Aey dubya
Thumper Humper
Aey dubya's Avatar
Oddometer: 356
I'm hydraulic now. Issues solved.
Times are GMT -7.   It's 06:29 AM.
