Old 02-08-2013, 08:34 AM   #1
Bronco638 OP
Nobody Home
Bronco638's Avatar
Oddometer: 3,969
Chemical Engineers: How to Soften Rubber?
I recently read, on another forum site, that a 50:1 mixture of water to wintergreen oil, heated to just below boiling, will 'restore' old rubber (carburetor boots, etc.) to "like new". Another inmate there opined that a mixture wintergreen oil and toluene will accomplish the same thing.
Is this really the way to "restore" rubber or are the chemicals basically breaking down the rubber and the interim state is simply close to the way the rubber was when new? I'm more curious that anything.
TIA.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 02-08-2013, 09:04 AM   #2
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
I really looked at that last year. They were getting good results and maybe too good, leave it in too long and too much softening/expansion then they had to wait until it dried out and shrunk back to normal.
But you should know that there are special rubber greases that will do almost the same. May not work for badly damaged and dried rubber but sure good for slightly dried out stuff. Very good at preventing the drying and cracking, I have been using that for many years.
Big tube was empty after 20-30 years and I found out how difficult it is finding that in Canada/US nowadays, had to order another 20 years supply from the UK. Cheap, less than $20.00 to my door for 500gr.
Google Miller Red Grease....Castrol Red Grease or PBR Rubber Grease.Great stuff to rebuilt brake systems, fully compatible with brake fluids and best of all no silicones. The last is very important if your bike(s) has an O2 sensor and you want to lube any rubber in and around the fuel/air delivery systems.
Have tools, will travel!
Old 02-08-2013, 10:01 AM   #3
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,021
TIA.
I've probably seen those same threads (on sohc4.net?). It would be interesteng to follow up with some of the folks that did this early on, it's probably been a year or two now, and see if the rubber is still pliable.
EDIT: here is the thread I was thinking of. http://forums.sohc4.net/index.php?topic=29707.0
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi screwed with this post 02-08-2013 at 10:07 AM
Dave in Wi is offline   Reply With Quote
Old 02-08-2013, 02:44 PM   #4
74C5
74C5's Avatar
Oddometer: 987
It sounds like you don't really want to soften rubber. You want to return it to original durometer and elasticity.
You can't, in general. As it ages, rubber loses the plasticizers that are incorporated into the chemical mix. Continued cross-linking sometimes also makes the rubber harder as it ages. This is the reverse of men BTW.
You can soften rubber with different chemicals though. Naptha also works for some others, MEK. But, they're being partially dissolved if uncured.
R1200RT (R1100RT gone)
KLR650 - gone
Don't be the guy who needs to pee on the fence to figure out that it's electrified.
74C5 is offline   Reply With Quote
Old 02-08-2013, 05:06 PM   #5
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,868
Originally Posted by 74c5 View Post
you can't, in general. As it ages, rubber loses the plasticizers that are incorporated into the chemical mix. Continued cross-linking sometimes also makes the rubber harder as it ages. This is the reverse of men btw.
You can soften rubber with different chemicals though. Naptha also works for some others, mek. But, they're being partially dissolved if uncured.
+1
Tsotsie is offline   Reply With Quote
Old 02-09-2013, 05:27 AM   #6
kantuckid
Oddometer: 3,085
Seems I read that glycerin was good to wipe down things like door seals on autos .
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Old 02-10-2013, 05:25 AM   #7
Bronco638 OP
Nobody Home
Bronco638's Avatar
Oddometer: 3,969
Yeah, I think that was the gist of the post I read. They were talking about bikes from the late 80s where those rubber pieces are 22+ years old now any are getting harder to find and more expensive.
I figured as much. I guess the key would be to find some way to soften the rubber without causing it to breakdown and (eventually) fail.
Got it, thanks.
Actually, it was on a Honda VTR250 Interceptor forum site but I'm willing to bet the discussion what similar in nature.
Old 02-10-2013, 08:35 AM   #8
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
I used that again yesterday on some older rubber.
http://www.millersoils.co.uk/scripts...dsegmentID=267
Different products....more specs, even a website on rubber greases. Just found that:
http://www.redrubbergrease.com/red-r...l-girling.html
And for some reason, not well known in North America them rubber greases. Been through that somewhere else, sure was glad for some continentals that came on that thread and supported my views on such products.
Not perfect but certainly helps to bring back some of the elasticity. I use it mostly "preventively", never had to replace too many,if any, rubber pieces where I used it.
BTW, gave some of my stash to a friend, he really likes it. As a motorcycle restorer, he is quite familiar with dried out old rubbers.
GM used to sell what we called "Latex" back in the days. Mostly used to maintain weatherstrips when they were still made with real rubber. Whitish liquid that somehow penetrated the rubber. But....that was back then, haven't seen that around for a very long time.
Times are GMT -7.   It's 12:16 AM.
