02-07-2013, 02:32 AM
#2131 |
Oddometer: 8
They make a little lever that snaps on the "cruise control" star thingy so you can turn it on and off with the flip of your thumb. Makes it pretty functional.
02-07-2013, 12:02 PM
#2132 | |
krunkin'
Oddometer: 145
'09 XR1200 '00 TT600 |
02-07-2013, 12:10 PM
#2133 | |
Oddometer: 68
It shouldn't be so tight that you can't twist the throttle back, either. Just tight enough to hold the return spring.
2008 H-D XL1200N |
02-07-2013, 03:13 PM
#2134 |
Oddometer: 743
02-07-2013, 03:40 PM
#2135 |
Oddometer: 68
This is my first Harley, and the newest bike I've owned. If any of my old UJMs had throttle tensioners, I certainly didn't know about it.
2008 H-D XL1200N |
02-07-2013, 03:42 PM
#2136 |
Oddometer: 308
If you want to make it a lot sharper, raise the fork legs 1/2" up the triple-tree. Mine is an standard '07 - not a lowered one - and has the long RK rear shocks on. Raising the legs is common on VStroms for handling and stability issues, and I tried it on the Sporty more out of curiosity than anything. Works a treat and lightens the feel a lot. Takes about 5 minutes to do, can be done on the side stand, but (carefully) slacken the bolts only enough until the legs just start to move. Tighten the upper bolts first when the levels are correct, then bounce the front suspension a few times and tighten the lower bolts.
02-07-2013, 09:24 PM
#2137 |
Oddometer: 17
Rode the 1200S today
I had a 2000 883C before, but this bike I REALLY enjoy.
02-07-2013, 11:56 PM
#2138 |
Oddometer: 108
I only used (and always used) this throttle tensioner when warming up the bike. Mine was a carb'd Sportster and it always cough when cold. So, every time I started the bike, I turned this tensioner so the engine ran a at a higher rpm than idle, while I put on my jacket, helmet,and gloves. Once I was ready (about a minute), and the engine warm to the touch, I loosened the tensioner and ready to go.
02-08-2013, 09:34 AM
#2139 |
Still gettin faster
Oddometer: 996
02-08-2013, 11:13 AM
#2140 |
Still gettin faster
Oddometer: 996
About that throttle tensioner.
I think all Sportsters have a tensioner. I keep mine set to a neutral tension. Easy to open and close. If I let go of the throttle, it will slowly vibrate closed and begin to slow down. Easy to adjust on the fly. Switching between my other bikes with a return spring, I don't even notice the difference. From a safety standpoint, whether you realize it or not, you always manually close your throttle anyway. Also, the Sportster has a bank angle sensor. Meaning, if it tips too far over it will cut out the ignition. So next time you FF's are out for a ride, play with it. I really like mine.
02-08-2013, 02:12 PM
#2141 | |
Oddometer: 70
They had a solid (not braided) wire inside the throttle cable housing that ran inside the handlebar. It pushed or pulled the carb butterfly open, and had to be twisted closed to close it. Otherwise the throttle stayed where it was. By the early 70's the carb had a light return spring but the friction of the solid cable, by design, was too much for the spring to close the throttle. In 1974 the Feds mandated self closing throttles (and left side shifters, right side rear brake), so H-D complied, but put in the tension screw and it's been there ever since. As stated, adjust it so it keeps the throttle from closing, but not so tight you can't over-ride it and twist the grip. You'll do so not only to close the throttle but the make minor speed adjustments. |
02-08-2013, 03:34 PM
#2142 |
Mindless Wonderer
Oddometer: 202
02-08-2013, 05:43 PM
#2143 | |
Oddometer: 1,611
And all this time I thought it was some sort of cable adjustment! I REALLY should read my owner's manual, huh?? ![]() ![]() But after reading this just now, I went out and played with it a bit... Just seems to make the throttle sticky and sorta notchy to me. I quickly turned it back the other way. IDK, maybe mine's defective or something, but it's not for me. ![]()
"Life is too short to do anything other than that about which you are absolutely passionate."..........."Adventure is a frame of mind, set upon by action, not defined by equipment."..........."I didn't get a Sportster because I wanted a Harley....I got a Harley because I wanted a Sportster."..............."It all boils down to your ability to say "SCREW IT" and really mean it".....Randy |
02-09-2013, 06:20 PM
#2144 |
Oddometer: 108
02-11-2013, 10:26 AM
#2145 | |
Oddometer: 68
I just did a 400 miles highway trip, and had plenty of time to fool around with the thing. I got the hang of it pretty well. I only had a slight issue when a car suddenly decided to merge in front of me, but I forced the throttle closed manually. It definitely saved my hand from getting cramped up. Now I just need something to save my ass. These rear shocks are horrible
2008 H-D XL1200N |
