Old 02-04-2013, 08:08 AM   #481
ElReyDelSofa
Desubicado
ElReyDelSofa's Avatar
Oddometer: 86
Question; I currently have some 35w PIAA's mounted on my F650. As they drain my battery I would like to replace them, do you think the existing wiring harness would work, allowing me to mount your LED's and connect?
Saludos
Martín
Todo es posible nada es seguro
ElReyDelSofa is offline   Reply With Quote
Old 02-06-2013, 06:52 AM   #482
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 857
Originally Posted by goodcat8 View Post
Here we go.
Fender mounted Bullet lights, 06 Vstrom 650.
Many thanks for the follow up
The Toad is offline   Reply With Quote
Old 02-06-2013, 10:51 AM   #483
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 857
Saludos
Martín
Martin,
Either of the light sets (MM10 or MM8) we sell will work with your existing wiring.
Ordering "lights only" saves you a few bucks and will bolt up and wire up in place of the PIAA's (and wont overwhelm your electrical system )
thanks,
-Brian
Old 02-06-2013, 07:10 PM   #484
alfabc
Oddometer: 186
I have a pair of lights from MondoMotors on my BMW 650 and they replaced the PIAA's. They are MUCH brighter, and draw much less current from the charging system. Just cut the wires from the old lights, and splice in the new lights. Meke sure to use heat shrink tubing over soldered connections. The new lights mount up very well in place of the old ones. It's a no brainer!!
Cheers,
Bill
alfabc is online now   Reply With Quote
Old 02-08-2013, 07:44 PM   #485
etingelefunts
etingelefunts's Avatar
Oddometer: 291
Received the MM10's yesterday.
Fab work in process for mounts tonight.
Piloting a bike with its disperate focus awakens clarity, perhaps the wind shews the clutter.
Drawn to this place, I am inspired to share my ride, especially watching others' journeys.
In a little way gregarious again, marveling at the profound experiences of nearly everyone whom I meet. Its like a whole new clan.
Teach me more.
etingelefunts is offline   Reply With Quote
Old 02-11-2013, 11:06 AM   #486
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 857
Like to see some pics once you get them installed
thanks,
-Brian
Old 02-12-2013, 03:53 AM   #487
BrittC
BrittC's Avatar
Oddometer: 182
Finally got around to finishing up my installation on a 2002 Aprilia Caponord. With the PIAA brackets, they went right on my factory crash bars.
And a video of them in action...
2002 Aprilia ETV1000 Caponord
http://britt-motorcycling.blogspot.com
BrittC screwed with this post 02-12-2013 at 06:10 AM
BrittC is offline   Reply With Quote
Old 02-12-2013, 05:50 AM   #488
etingelefunts
Oddometer: 291
thanks,
-Brian
Will do Brian!
Mounts are done. Turned out great.
Busy wiring in a fuse block for heated gear and then I will connect my GPS and lights all at once.
Teach me more.
Old 02-13-2013, 07:09 AM   #489
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 857
Many thanks for the pics and video
-Brian
Old 02-20-2013, 07:13 AM   #490
MooMoo
MooMoo's Avatar
Oddometer: 39
Can they be wired in directly?
I am thinking of getting a set of the MM10 Bullet lights on my Super Tenere for day and night driving lights. I'm also thinking of getting a set of the MM8 Flood lights to light up more of the dark back roads and what little off roading I may do.
Can I wire the MM10's into my running lights and the MM8's into the high beams? That way the MM10's will always be on even when the high beams are on along with the MM8's. Is this not a good idea or should I use some kind of controller and/or a fuse block? Is this overkill? I was thinking that the MM10's would light a bit further and the MM8's would light a wider path. Maybe the MM10's will be all I need?
Does it matter what height you mount them? I was thinking of mounting the MM10's low on the crash bars and the MM8's up by the headlights.
Thanks,
Chris
MooMoo is offline   Reply With Quote
Old 02-24-2013, 06:03 PM   #491
LI LT Owner
Wrong Island, NY
LI LT Owner's Avatar
Oddometer: 1,242
Ordered my set in November and finally got around to installing them on my 2002 R1150R today. In a word- AWESOME!!!!!!!!!!!!!!
Installed them in the bolt hole for the oil coolers:
Clean and elegant design made them fit sweetly in place:
Switch was installed on the inside of left hand turn signal assembly:
Low beam only:
Low and Mondo Lights:BAM!!!!!
Thinking about ordering set for the LT where the Piaas normally go in under the front cowling.
Rob VB
2003 BMW K1200LT
2002 BMW R1150R
My Blog- Kickin' Tires and Telling Lies
LI LT Owner is offline   Reply With Quote
Old 03-06-2013, 06:34 AM   #492
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 857
Thanks,
Chris
Chris,
sorry for the delayed response. Ive been traveling alot lately.
You can wire the lights as described above (directly) no problem. Mounting either of the light sets low will light up the side of the road closer to you.
thanks,
-Brian
Old 03-06-2013, 06:36 AM   #493
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 857
Low beam only:
Thanks for taking the time to post your review and pics
-Brian
Old 03-09-2013, 05:12 PM   #494
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,100
Wink Great Product!
Brian, Thanks for the lights and the great service!!! The new units look fantastic!!
I don't ride much a night.... I run them mostly during the day for visibility for on coming traffic.
....And for setting up camp on the Adventure Rides.
Originally Posted by HighTechCoonass View Post
Here I show how to add "auto off" lights to your GS.
Also the invaluable battery tender power whip (SAE type connection) - also use to power my volt meter and USB power supply - I like this because I can isolate the volt meter and USB if need be. I usually leave connected at all times...
http://www.opto22.com/site/pr_detail...=3&item=DC60S5
here you can see the volt meter LCD (for daylight visibility) and the USB scocket next to the light switch.
NAPA has these....
http://burnsmoto.com/usb-power-socket-weatherproof.php]
The F800gs Snatchy Throttle Fix Boost your Beamer...BMW efi GS Power Controller - l Now the Juice NEW!TheJUICE
HighTechCoonass is offline   Reply With Quote
Old 03-11-2013, 06:37 AM   #495
ChiGuy64
Adventurer-in-Tng
Oddometer: 12
Hi all,
On Jan 2nd we will be launching a new website, with some enhanced features (account creation, product reviews, etc). Our website address will remain the same.
But more importantly, we have been able to renegotiate with a couple suppliers this past month which makes it possible to do price restructuring on a few items.
Meaning: lower prices on our LED lights and light kits.
Effective Jan 2:
MM10 Bullet Light Kits - $136 - with 5% discount = $129.20
MM10 Bullet Lights (pair) - $96 - with 5% discount = $93.10
MM10 Light
We will also be bringing back the MM12 in a slightly revised format within the next month.
Other new products and lighting choices will be added in the coming months and will continue to do all we can to provide the best products and best service at the best prices.
May 2013 bring MANY, MANY two-wheeled adventures your way
-Brian, Kris & Bob
MondoMotos
Are these still being offered with the 5% discount? If so, how do you enter the code (ADV5) when ordering?
ChiGuy64 is offline   Reply With Quote
Times are GMT -7.   It's 10:51 PM.
