Old 02-08-2013, 01:46 PM   #31
craydds
craydds's Avatar
Oddometer: 1,164
Originally Posted by Prutser View Post
Two examples of Rizoma handle bars, one mounted on an R100R the other on an R80.
They are great IMO.
That is a good looking bar! Not much rise - good. Is that the Rizoma MA010? Also, what mounts are required to bolt to the top plate?
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 02-08-2013, 02:01 PM   #32
Prutser
Prutser's Avatar
Oddometer: 1,015
They are the MA005 The MA010 didn't exist when I mounted these. And the little bit of lift helps to keep the switches from hitting the tank.
AZ405 is the type of mount.
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is online now   Reply With Quote
Old 02-08-2013, 02:10 PM   #33
Mr. B.
Climate Controlled
Mr. B.'s Avatar
Oddometer: 149
Another thread
http://www.advrider.com/forums/showthread.php?t=779955
Mr. B. is offline   Reply With Quote
Old 02-08-2013, 02:28 PM   #34
craydds
craydds's Avatar
Oddometer: 1,164
ABC #12947
'75 R90S
Old 02-08-2013, 08:23 PM   #35
supershaft
because I can
Oddometer: 9,116
I like K1 bars on airheads.
Old 02-09-2013, 06:49 AM   #36
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,269
Two examples of Rizoma handle bars, one mounted on an R100R...
Your bike? If so, what did you do with the instruments? I like that.
Old 02-09-2013, 07:00 AM   #37
craydds
craydds's Avatar
Oddometer: 1,164
Originally Posted by JonnyCash View Post
I got a set of drag bars, which have no rise and only slight pullback. They were made by a company called Bikemaster, and were nominally 7/8".
Cash, looks like that bar might work for me - http://www.bikemaster.com/handlebars.html - bar "H" on that bikemaster page. Do your handgrips/controls clear the gas tank at full lock? That is my problem with the RS bar.
ABC #12947
'75 R90S
Old 02-09-2013, 07:37 AM   #38
JonnyCash
turd polisher
Oddometer: 1,598
Very astute there! I did have to raise up the bar clamps to make the Magura (I think you've got the Magura, too) MC. The problem was not the clearance with the tank(I have a toaster tank). There was a clearance problem with the banjo fitting on the MC and the fork spring caps. I made a pair of little spacers out of 1/4" aluminum flat bar which fit between the lower clamp pad and the top plate of the triple. If you go way back to the thread I started a long time ago, you might be able to see the spacers in my pictures, but they hide well.
Oh my God there's an awful lot of snow out there.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 02-09-2013, 08:46 AM   #39
craydds
craydds's Avatar
Oddometer: 1,164
Sounds cool, Cash. I will look at your thread. Please, keep all that snow away from me! brrrr....
ABC #12947
'75 R90S
Old 02-09-2013, 09:22 AM   #40
Prutser
Prutser's Avatar
Oddometer: 1,015
Thank you Anton,
Not my bike. It was my girlfriends bike.
IMO the stock dash was to high and didn't look ok with the old style headlight mounts I used get the headlight a bit lower, and to get rid of the original plastic mounts. Also used an R80 mono headlight to fit the ignition switch and give it a cleaner look.
Ride Report 2012
Old 02-09-2013, 06:28 PM   #41
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,423
I used BSA A10 bars on my old airhead , there are some great bends from the British bikes , the euro Norton Commando bars are nice .
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is offline   Reply With Quote
Old 04-06-2013, 01:53 PM   #42
AirheadRick
AirheadRick's Avatar
Oddometer: 6
Rizoma Bars
I liked the lok of the Rizoma bars and bought a set for my /7. They are labeled as 22mm and they measure as such but the clutch and throttle perches are not going on and I don't want to force them too hard. Prutser just wondering if you had to sand the ends down to mount allow the perches to slide on?
AirheadRick is offline   Reply With Quote
Old 04-06-2013, 02:04 PM   #43
Plaka
Brevis illi vita est
Oddometer: 4,608
Don't sand the bars, open up the perch clamps.
The class tool is an HVAC tubing expander, ideally a live one rather than the hammer-in one.
Old 04-06-2013, 02:10 PM   #44
Prutser
Prutser's Avatar
Oddometer: 1,015
No need to sand down before everything fitted. I mounted about 20 of those rizoma bars.
But I was using the fat bars although it shouldn't make a difference.
You could try to put the controles on the wrong way to check if its the clamps of your controles that is to tight or its the diam. of the handle bars.
Ride Report 2012
Old 04-06-2013, 02:11 PM   #45
AirheadRick
Oddometer: 6
They are cast won't they break if you try to expand them?
Times are GMT -7.   It's 10:55 PM.
